The next station is...!
Xenophon PCDGS
17 Apr 2011
1. How to play
At the start of a game, the OP(at the very beginning or if necessary) or the player who previously ended a leg of the journey, will choose a starting station (unless the player has called an open floor, in which any player can choose a starting station) that adheres to the following criteria:
It is on NR rails
That section of the rules definitely rules out ANY mention whatsoever of any station on the Tyne and Wear Metro on this quiz
How to play
8. IN THE EVENT OF A WRONG ANSWER:
If a submission to the quiz is incorrect, but there have been no further posts, the author may edit their post, so long as the original is shown as crossed out. After striking through an incorrect entry, you must use reply rather than edit to post your new entry. This aims to prevent confusion to allow for smooth proceedings.
If there have been further posts, either of two circumstances should occur;
i) The author states their position, thus making any posts after the original superfluous. The original incorrect answer should be crossed out. The game is then continued by a different individual, starting from the station before the incorrect submission.
ii) Another individual states their suspicion, which is then confirmed by another player. Anyone is then welcome to continue the game, again starting from the station before the incorrect submission. Again, the incorrect answer should be crossed out.
If you are unable to cross the answer out, due to reasons beyond your control, you should only edit to a statement giving an acceptable reason. You should not make another posting until another person has posted.
If the post is edited, then it will be assumed that the entry has been changed, unless a clear reason is posted in the reason box.
A very recent posting made mention of postings being edited not in accordance with the rules....which are all clearly stated on the VERY FIRST POSTING on this quiz, together with the RED SECTION.
Therefore, not for the first time, I have caused that section of the rules to appear above.
There are times when I am beginning to feel like Michelle in @Allo 'Allo...."Listen, I shall say this only once"....:roll:
