The next station is...!
Xenophon PCDGS
17 Apr 2011
1. How to play
At the start of a game, the OP(at the very beginning or if necessary) or the player who previously ended a leg of the journey, will choose a starting station (unless the player has called an open floor, in which any player can choose a starting station) that adheres to the following criteria:
It is on NR rails
It is not just a terminal station (There are two or more different stations that can be reached from it, on separate lines.)
It is not the same station as the one which ended the previous leg.
In the immortal words of Michelle from 'Allo 'Allo, "Listen, I shall say this only once"....
The emboldened mention of this extract of rule 1 of this quiz clearly states...It is on NR rails.
Have NR suddenly made an overnight takeover of any lines outside the recognised British sea border limit....:shock:
Winchelsea
Doleham
