The next station is...!
Zoe
22 Aug 2008
We are now in a dead end so the goalkeeper is going to be beaten in a few turns time.
Newhaven Town.
Zoe
22 Aug 2008
The goalkeeper parrys it away but it lands in the area right in front of the attacking players.
Bishopstone.
Robinson
1 Aug 2010
Helensburgh
I suppose you would not be too surprised to find you were at...
Seaford, safely delivered by Southern.
Let's now start at Burneside.
Xenophon PCDGS
17 Apr 2011
1. How to play
At the start of a game, the OP(at the very beginning or if necessary) or the player who previously ended a leg of the journey, will choose a starting station (unless the player has called an “open floor”, in which any player can choose a starting station) that adheres to the following criteria:
 It is on NR rails (or Merseyrail)
It has a through line
 It is not the same station as the one which ended the previous leg.
Posted in answer to the query raised by Temple Meads at the start of this current leg, which is invalid as it starts on a short branch line with a terminal station.
There is now even worse news to follow.....
The leg that started with posting # 5730 is also invalid as Wargrave is also on a short branch line with a terminal station.
Robinson
1 Aug 2010
Helensburgh
Thought "through line" merely meant that the station had trains running in from each end of the platforms (i.e. not somewhere like Helensburgh Central, or Brighton, or London Euston). Otherwise you're opening a can of worms as we then have to ask how long the line running through the station must be before reaching a terminal station before being valid.
We've had a whole load of similar starting points all the way through the game... Cardross being another recent example (although that leg was ruled out for reasons unrelated to this particular issue)
Temple Meads
2 Sep 2010
Devon
Posted in answer to the query raised by Temple Meads at the start of this current leg, which is invalid as it starts on a branch line with a terminal station.
The leg that started with posting # 5730 is also invalid as Wargrave is also on a branch line with a terminal station.
Many thanks for this clarification Paul, of course, this now raises the question of what to do with this leg, and the other leg(s) where this has happened..
A clarification from adtrainz would be helpful.
Xenophon PCDGS
17 Apr 2011
We've had a whole load of similar starting points all the way through the game... Cardross being another recent example (although that leg was ruled out for recents unrelated to this particular issue)
One for adtrainz to make a ruling upon, but Rule 1 has always stated what it says since this quiz first commenced.
Robinson
1 Aug 2010
Helensburgh
We've also had legs starting at Scotscalder and Thorpe Bay, just off the top of my head... surely they would also be ruled out if this was our definition of "through line"...
gnolife
4 Nov 2010
Johnstone
I personally agree with Robinson's definiton of a through line. If this wasn't the case, then most stations in areas like Merseyside, Greater Manchester (South), West Yorkshire, Central Scotland, and Greater London (and many more) being barred as starting stations.
