Robinson
Wadhurst
Tonbridge?
See posting # 37296
HALT.....Adjudication requested.
Re-commencing from '96 - Tonbridge's next station options are either
Hildenborough
Leigh
As stated - From #37296 your options, per the sectional appendix, are Leigh or Hildenborough.
I therefore propose that I make the next station Hildenborough, and further stations are welcomed.
But I have already posted Hildenborough on posting # 37300
This is why we are awaiting for an adjudication to be made before any more postings are made.
Plus #37297 was a valid move, so why eliminate that?
It has NOT been eliminated...the last three valid moves are:-
Posting # 37296.....Tonbridge
Posting # 37297.....Sevenoaks
Posting # 37300.....Hildenborough
Therefore, since Hildenborough is the only station in-between Tonbridge and Sevenoaks, I was asking for an adjudication as to what service from Hildenborough that does NOT stop at either Tonbridge or Sevenoaks.
deleted
8. IN THE EVENT OF A WRONG ANSWER:
If a submission to the quiz is incorrect, but there have been no further posts, the author may edit their post, so long as the original is shown as crossed out. After striking through an incorect entry, you must use reply rather than edit to post your new entry. This aims to prevent confusion to allow for smooth proceedings.
If there have been further posts, either of two circumstances should occur;
i) The author states their position, thus making any posts after the original superfluous. The original incorrect answer should be crossed out. The game is then continued by a different individual, starting from the station before the incorrect submission.
ii) Another individual states their suspicion, which is then confirmed by another player. Anyone is then welcome to continue the game, again starting from the station before the incorrect submission. Again, the incorrect answer should be crossed out.
If you are unable to cross the answer out, due to reasons beyond your control, you should only edit to a statement giving an acceptable reason. You should not make another posting until another person has posted.
If the post is edited, then it will be assumed that the entry has been changed, unless a clear reason is posted in the reason box.
Any entry that has been edited or deleted without good reason will lose 10 points from that leg.
Duplicate posts (Castle Cary...and Castle Cary) are not affected by this amendment.
Please can you 'strike-through' a duplicated move rather than change it to 'deleted'?
Already been pulled up, I had forgotten how to strike through
Hindley
No worries. I take it you know now![]()
