The next station is...!
Rich McLean
6 Feb 2012
Teignmouth
Newton Abbot
Old Post above, New Post Below
Torre
That's invalid, as you struck through your post, which is correct. After that, you need to check to see if anyone else is made a post, before posting the next station, so in other words, make a new post
Trainfan344
13 Oct 2012
Teignmouth
I did save it, check and then re-edit it to save posts.
Buttsy
20 May 2011
Hanborough
teignmouth
that's invalid, as you struck through your post, which is correct. After that, you need to check to see if anyone else is made a post, before posting the next station, so in other words, make a new post
poor point now deleted
Rich McLean
6 Feb 2012
Have now crossed that out, to give him the benefit of the doubt
Dawlish Warren
Xenophon PCDGS
17 Apr 2011
8. IN THE EVENT OF A WRONG ANSWER:
If a submission to the quiz is incorrect, but there have been no further posts, the author may edit their post, so long as the original is shown as crossed out. After striking through an incorect entry, you must use reply rather than edit to post your new entry. This aims to prevent confusion to allow for smooth proceedings.
If there have been further posts, either of two circumstances should occur;
i) The author states their position, thus making any posts after the original superfluous. The original incorrect answer should be crossed out. The game is then continued by a different individual, starting from the station before the incorrect submission.
ii) Another individual states their suspicion, which is then confirmed by another player. Anyone is then welcome to continue the game, again starting from the station before the incorrect submission. Again, the incorrect answer should be crossed out.
If you are unable to cross the answer out, due to reasons beyond your control, you should only edit to a statement giving an acceptable reason. You should not make another posting until another person has posted.
We now have a number of new players now contributing to this quiz, so I have posted this extract of the rules that are shown in the very first posting of this quiz, which I do ask that all new contributors both read and inwardly digest.
Trainfan344
13 Oct 2012
Sailsbury
In the case of two stations on NR with the same name, don't forget to put the County in brackets i.e. Gillingham (Dorset) to avoid confusion
Ok then, will do, didn't know if i needed to or not.
