Thameslink/ Class 700 Progress
Samson
10 Jun 2015
Tonight was a joke. 700106 had ALL 5 toilets locked out of use, many grumpy passengers onboard!
Bornin1980s
4 Apr 2017
I am planning to travel to Horsham on the weekend of 27 to 29 July. Now, the simplest route for the final stage of the journey would be St Pancras to Horsham on Thameslink. Now how reliable do you expect the service to be,considering it is GTR? Also, what might be the best times if I want to get a seat?
mushroomchow
14 Feb 2017
Where HSTs Still Scream. Kind of.
Thameslink is reasonably reliable for the most part, and frequent. If you do end up with your service cancelled or delayed and have a specific ticket booked, you'll get on the next one just fine and won't have to wait more than 20 minutes at all but the quietest times.
As for your second question, you won't have a problem getting a seat at weekends, but that raises the question - why would you want one on a 700? You'll be more comfortable standing or slumped by the door. :lol:
physics34
1 Dec 2013
Remember the disclassifield 1st class in the rear coach. Im not sure the masses are aware of it yet.
Failed Unit
26 Jan 2009
Central Belt
Did you mean 30+? Peterborough- Horsham will only be half hourly. So 30 mins will be the minimal wait for a cancelled train.
DaveN
28 Feb 2009
Also note that engineering works often cause the Thameslink through services to be cancelled especially on Sunday
D365
29 Jun 2012
Good point, Peterborough via Huntingdon is remaining 2tph.
I had no more problems with the seating than on a 365, personally, aside from the airlines being a little tighter.
jon0844
1 Feb 2009
Thameslink services have messages saying where first class is (it doesn't say where first class isn't in the case of the rear being declassified but it's safe to say people DO know as first will likely be full, even with standees, when standard may have room) so I wonder if that'll happen on the GN route going forward?
When the 387s had first class front or back (before they were turned around as needed to be consistent) the screens did start to show where first class was, but it seemed as if it was done manually and was often missed out, or even wrong. At least first class only being at the front stops that problem on the 700s.
The service is normally reliable.
Standing is quite common on Thameslink services on Saturday and Sunday mornings southbound, and evenings northbound between St Albans and St Pancras. However as the Horshams will be off the ECML, I expect seats will be easier to come by.
Regular travellers are very much aware of it, however only a small proportion are able to benefit, and most people can’t be bothered (because, to be honest, most people aren’t worried about the seat comfort). Fewer regular travellers at weekends, so a better chance then.
4 Sundays per year only, for the core from now on. Subject to change of course. However works either side may reduce the service level or destinations, but that is the same as always.
Failed Unit
26 Jan 2009
Central Belt
notverydeep
9 Feb 2014
So if I get a penalty fare should I pay it or give my details for prosecution? I don’t trust the social media team as the cover the whole of GTR and often get their facts incorrect. On the trains I use the loading indicators are red for 6/8 coaches and green for 2. Wonder why. ;)
There is a message that comes round on the Passenger Information System, every couple of minutes (visual only). I have taken the 700 on the 1722 King's Cross to Cambridge twice now since they were introduced and it has played on both units (700050 and 700052)...
jon0844
1 Feb 2009
IF you are given a penalty fare, I'd probably advise paying it and then appealing. I am sure an appeal for that is going to be less pain than if they go down the potential prosecution route. Sure, you'd 'win' that too but it would mean having to wait and fire off letters, wait again...
But this is wholly hypothetical because I am sure no RPI will give penalty fares and will be fully aware.
Failed Unit
26 Jan 2009
Central Belt
I was PF on the 387s in first class before they labelled then properly. I won the appeal as they agreed that from the photos provided it was not possible to tell if you had entered from the next coach considering the seating is identical.
That said. Will try using the rear on 1722. Worse case is I am stood in comfort so no worse than currently.
jon0844
1 Feb 2009
The 387s were a mess when introduced. Barely any signs at all. A bit like the 321s when refurbished, as if someone forgot to put the stickers back (or had replaced the anti-etch film and had run out of stickers).
At least the 700s have first class well marked from the get go.
The 365s have also had their ups and downs over the years. With sensor problems on the doors, it is common to have the doors locked open and there were times that some units had no stickers at all and you had only the antimacassars to tell you. Crazy if the seats you can see are occupied and therefore the seats are blocked.
APUK002
26 Dec 2016
Hmm,well done for appealing,often see 1st class open on 365(doors locked open Why?,bit silly as means they can claim difference refund
jon0844
1 Feb 2009
Why would you be able to claim the difference just because the door to first class is locked open? That doesn't make it declassified.
Skimble19
12 Dec 2009
No, you can’t claim a difference refund for that.. not unless it is officially declassified.
jon0844
1 Feb 2009
There's no logical reason why the 717s wouldn't already be started, they could just as easily have been planned to overlap with, or follow on from the 707s...
I thought so too, but there seems precious little info about them bar a couple of recent photos and, erm, that's it?
Failed Unit
26 Jan 2009
Central Belt
GTR keep saying the expect driver training to begin in May. Saying that never believe anything GTR say with dates. New timetable uploaded Feb 25th....
BelleIsle
24 Aug 2012
They have already started. I have seen pictures of actual bodyshells in unpainted aluminium with the end emergency doors being tested.
There are new pictures, linked to today, of a GN 717 on test over in the main GN 717 thread. Discussing them here in the 700 thread as well could get really confusing...
