Why clutter up the floors making them more difficult to keep clean? Also, the space beneath seats is for (permitted) large items of luggage.
The LO class 378s seem to cope well enough with a similar amount of hand holds and journeys on them are a lot more erratic in speed and smoothness.
You're probably not going to get too large an item of luggage below them seats, you'd probably get something larger in the overhead racks. Does the roof space literally have electronics for various bits all the way along or just certain areas of the roof space
Currently sat on 377210 and noticing even less grabbing points than the 700s do with just 5 nubs between doors and coach end and only bars to hold around the doors so the 700s are a huge increase in grabbing points with each seat row providing at least two points. In this case the 700s increase in a much bigger % compared to the passenger capacity increase. My example alone going from 5 grab nubs to 16 full hand grips. That's a massive increase when you actually look at it.
short answer yes, bar the connection from pan to motors IIRC. You'd be surprised just how stuff is up there. I know I was.
As I've said before, you cannot have handrails in the ceiling as the whole thing opens out to access the electronics. People holding on would cause the ceiling to come down. The alternative would be to remove seats and put the equipment there reducing capacity.
Standing people better get good with their balancing then....! There must be another way
... Has the Crossrail stock managed to incorporate ceiling-hung grab rails which don't pull the roof down?
not around the doors themselves though.
It's not just about not pulling the roof down, the problem with any stock is access to roof-mounted equipment. If the ceiling has to come down in 20 different panels just to get to the AC etc., there is a severe maintenance hit.
Noted, but - to answer my own question - it looks as though the 345s have ceiling-mounted grabs through much of the carriage length, and they're air conditioned....
I know the theory is that two or three people can use each seat-mounted grab - as opposed to one each on the 377s - but I'm not sure commuters will arrange their bodies in such a considerate way as to allow others access. Even if they do, the number of standees will still exceed the availability of grabs, quite often.
Drivers are getting used to the units now and incidents of delay due to stopping outside the mark are dropping rapidly
Pack in so many commuters that you are wedged upright?![]()
Not all 377s are the same though - the /6s &/7s have the same type of grab handles on the seats as well as other grab rail improvements over the older 377s. The users of the /6s &/7s generally appear to have to used to arranging themselves in mutually beneficial ways.
). Compare the doorways though, the Electrostars have four vertical handrails, located either side of the entrance to the seating area. There is also a high bar across the doorways, only used by taller people who are blocking the doors. The 700s have four vertical handrails located one on each side of the doors plus another four vertical handrails located at the end of the setback area, plus the central vertical pole. So that's nine vertical poles all designed to give standing passengers a safe handhold yet keep the doors as clear as possible.The seats fitted to the latest designs of Electrostar (377/6, 377/7, 387) have similar twin loop handles to the Desiro Cities rather than the inadequate 'knobs' on the 377/1-5s (no, not the passengers). Compare the doorways though, the Electrostars have four vertical handrails, located either side of the entrance to the seating area. There is also a high bar across the doorways, only used by taller people who are blocking the doors. The 700s have four vertical handrails located one on each side of the doors plus another four vertical handrails located at the end of the setback area, plus the central vertical pole. So that's nine vertical poles all designed to give standing passengers a safe handhold yet keep the doors as clear as possible.
Yep. Quite a few standees with not much to hold on too.
It depends on which 700 carriage you are in! If you have the misfortune to enter one of the wheelchair accessible ones then there are large areas with nowhere to grab. Obviously you can't stick extra poles in but some kind of overhead grabs would be very useful here.
How are the 700s grab rails an improvement over the more modern 377/6 &/7s?
Still, some commuter/metro trains (E231, R160) has managed to achieve grab rails on the ceiling.
Good to hear, but I thought that in a few cases it was that the stop markers had been put in the wrong place? Either way, I expect that there will still be a few incidents as drivers learn where the train wants to be on the new routes, although probably less than we've seen recently as they have a better idea of where they need to stop.
Would a good chunk of the electronics now in the roof space on the 700s have been located in cabinets at the ends of the coaches on "classic" units?
It's not that difficult to stay upright on a train without holding on to anything. Even on the Underground.
The Electrostars are particularly 'lively' northbound on the fast at Earlswood, and southbound through Stoats Nest Junction. The 700s might be better: I've only sampled them south of Gatwick.
It's also a matter of driving style. Some drivers favour a sharp initial braking action that catches standees off guard, then ease off before another sharp application, whereas others are more progressive.
To not hold onto anything* is rather to discount the possibility of emergency braking being required.
*Or, alternatively, to prop yourself against a suitable vertical.
The 387s also seen very lively on the ECML too. Probably best to hold on to something.The Electrostars are particularly 'lively' northbound on the fast at Earlswood, and southbound through Stoats Nest Junction. The 700s might be better: I've only sampled them south of Gatwick.
I hardly ever hold on to anything when I'm standing on a train - and I don't even have a good sense of balance ( I'm cloth eared and one ear has been drained as I have an implant ).
I challenge you to stand at the rear of an 8 or 12 car 387 heading north from St Pancras, with the driver on the back end of his shift with his new girlfriend waiting for him at home.
Just before Scratchwood services you will be on the floor.
Or a Pacer, anywhere, anytime......![]()
