Thames - Mersey Route Help
louis97
14 May 2008
Derby
I have the Thames - Mersey Route Version 4.1 and i am having a few error with some files. I have some errors with the files below:
gen_uk_nat1_s.sms
crossing.sms
uk-bogiecoach-15.sms
Does anyone have any solutions?
Thanks in advanced
EDIT:
Another error is occuring now when i try and open a train which uses the Class 158 Sound Pack. The error is below:
Failed to find SMS File
File: C:rogram filesicrosoft GamesrainsimulatorRAINSRAINSETOMMON.SOUND lass15858eng.sms
Any ideas?
heart-of-wessex
11 Jun 2005
Trowbridge
I don't know about the first two, but the third one is a coach sound set you need. Are you signed up with UKTS? If so the file you'll need is:
http://www.uktrainsim.com/filelib-info.php?form_fileid=3824&CUTHERE=fb3000ea1509fcbe9d1643058a5731d9
(or its http://www.uktrainsim.com/filelib-info.php?form_fileid=2807&CUTHERE=fb3000ea1509fcbe9d1643058a5731d9)
Have you got the CD/DVD version or download? if you have the CD/DVD, these CD/DVD patches may help http://www.uktrainsim.com/filelib-d...=951&CUTHERE=fb3000ea1509fcbe9d1643058a5731d9
louis97
14 May 2008
Derby
Thanks, I will download that. Could you have a look at the error i have added!
jv3531
23 Jul 2008
Gloucestershire
Check that the sound file is located where its supposed to be. You may need to change the path specified to get it to work correctly with the unit concerned. By this I mean check the SMS folder in the sound forlder for the unit is the same as that specified in the .eng or .wag files, and then check that the sms files are not expecting to find the sounds within that sound folder. If they are, you will need to copy the sounds into the unit sound folder for them to work, or change the path that is specified in the SMS or eng/wag files to one which they can be found in. MSTS is extreamly fussy about where things are placed and will lock up for the slightest misplacement, its why you need to check and double check readmes etc because it is so easy to miss something...
When you installed Thames mersey, did you have all of the default routes open and did you run the Install.bat file that came with the extraction files? It looks to me as though these have not been copied correctly into the routes sound folder and there cannot find them. If you can locate them in one of the default route directories, a quick fix would be to copy these files from that sound folder into your thames mersey sound folder.
heart-of-wessex
11 Jun 2005
Trowbridge
Did you type that or was that the exact message??
