TGV/EC Connections at Genève.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Planning our next trip to Italy - with the direct line via Modane still closed - I see that the connections at Genève from the TGV ex-Paris to the EuroCity Pendolino for Milan are only nine minutes. While I have changed there many times over the years, I have never had such a tight connection....so do you fellow continental travellers think that this is doable, or advisable?
yoyothehobo
21 Aug 2015
I certainly wouldnt go with advisable.
Its certainly not far to go between the platforms, but i wouldnt take the risk, a couple of minutes delay could really scupper you.
D6130
12 Jan 2021
That's what I was thinking....but the connections at Zürich are even tighter at seven minutes and the trains from Paris are only every two hours. If we missed the connection, would we be entitled to use the next available service - if necessary changing at Brig - under CIV regulations....or do they not apply to on-line advance tickets? I notice that the nine minute connection is shown on the InterRail/Eurail journey planner app.
YorkshireBear
23 Jul 2010
I'd just spend two hours at a station and grab some food. Too much potential for problems.
yoyothehobo
21 Aug 2015
And check your mobile phone roaming before getting to Switzerland as when i was there last month it very much wasnt part of my contract, whereas France (and the rest of the EU was)
D6130
12 Jan 2021
Yes....I always try to remember to switch off data roaming when passing through Switzerland.
And indeed many Swiss trains (even new ones) lack WiFi, which seems a bit of an omission. Still, free WiFi is available at most larger stations.
signed
13 May 2024
ROI
The Giruno have.
Why there isn't WiFi is mostly linked to the fact that they implemented FreeSurf, which is a weird thing.
Which is a app that checks with Bluetooth whether you're in the train. And while you're in the train, it tells your Swiss ISP not to cap/charge your data.
SBB is basically telling that WiFi with that many people is dumb (reasonable) and that 4G coverage is much more suitable. Which is fair, seeing as train WiFi is usually nothing more than a 4G hotspot.
DanielB
27 Feb 2020
Amersfoort, NL
The Giurno have.
Giruno it is.
Switzerland also has really excellent mobile coverage, another reason not to bother offering wifi. My Dutch mobile plan does include roaming in Switzerland and must say there hardly is any place without signal. Even in a tunnel below a high mountain you'd have signal.
SW19Traveller
28 Apr 2015
Access from the TGV arrival platforms to the rest of the station is a bit of a bottleneck too as it goes through the Customs corridor. You could easily lose a few minutes getting off the platform when there's a train load all coming through the narrow corridor (though it doesn't look like customs themselves often stop people).
rvdborgt
24 Feb 2022
Leuven
Check the SBB planner. The Rail planner app should never be used to plan.
Whether a 9-minute connection in Geneva is doable depends on what plan B is in case it fails. If you can reach Milan with a later train, then I'd say book it. Under the AJC you should be rebooked free of charge on the next service.
D6130
12 Jan 2021
OK. Thanks.
D6130
12 Jan 2021
Thanks for the advice and suggestions. We've now decided on - and booked - a safer itinerary:
TGV 9203, 07 22 Paris Lyon-Basel SBB, arrive 10 26
EC 151, 11 06 Basel SBB-Milano Centrale, arrive 15 50 (now via Zurich instead of via Luzern as in the past)
FR 9551, 16 10 Milano Centrale-Firenze SMN, arrive 18 04
....connecting nicely into the last bus to our village, which departs from outside SMN station at 18 20. In the event of a major delay, we have a fall-back of the 19 14 Regionale Veloce to Arezzo, arriving 20 16....giving a tightish connection into the last train for our village, departing at 20 25.
Gordon
11 Feb 2011
Your latest plan looks good. I would not have gone via Geneva at the moment as the Italians keep closing the Domo - Milano line for upgrade work. And 9 minutes is not enough because TGVs often arrive late into Swiss stations.
