TFW removing off peak day returns
Kite159
27 Jan 2014
West of Andover
Northern do still push them quite hard for local journeys. There are lots of ads for an Advance ticket to Manchester for £2.50 in Bolton, for example. It's just that there's now a 2359 booking deadline on them.
So back to how advance tickets used to be, mostly booked by the day before with no 'on the day' sales. Which for something like Bolton to Manchester makes sense with multiple trains per hour. Where the single leg pricing makes it better for those travelling to Manchester during peak hours and back to Bolton during off-peak etc.
pokemonsuper9
20 Dec 2022
Greater Manchester
That's disappointing, I hope other operators don't follow suit.
It wasn't done by Northern, it was a TfGM decision.
The advanced tickets are just arbitrary routes (e.g. most places have them to Manchester, but few do to Wigan), the single leg pricing has fixed the problem they barely solved (since previously the only singles were anytimes just below the return cost, with advances being about the price a single should have been).
route101
16 May 2010
Advance tickets on such short trips shouldn't be a thing. For short trips what is wrong with flexible tickets?
I know some people who use the apps even if they are using a a flexible ticket, think you have to travel on service listed on the app.
Coleridge
14 Mar 2023
Penarth
I know many people who think that you have to travel on the booked train even if you have an off-peak or anytime return. The ticketing system confuses and even frightens them, which is a massive fail on the part of the train operating companies.
Belperpete
17 Aug 2018
TfW seem to push Advances quite hard, similar to the way Northern use them (though no longer do within the Manchester local area). They are available right up to departure even for very local journeys. I've had one purchased standing on the platform from Dolgarrog to the Junction, for instance.
The Advance Flex tickets do seem to be good value. I use them for my trips to Chester. They are more "flex" than "advance". They are effectively walkup tickets, as they are available until time of departure, with no time restrictions, at a set price for all trains (no tiers). Available for return on any TfW train on the same day, again without time restrictions. Effectively they are an anytime day return, except you are restricted to your booked outward train (which is no problem if you buy your ticket at the station). Importantly, they are significantly cheaper than Avanti's CDR, on a route where Avanti usually do the undercutting.
They don't seem to be available on all routes though. I can't find them on the Cambrian, for example. BRfares show them HHD-CDF, so I presume this means they are available between any two stations between HHD and CDF? Are they available on any other routes?
positron
18 Oct 2022
Cardiff
Advanced Flex Return sounds great but they are really badly labeled in the app to the point that I've never purchased one.
I've attached a screenshot that makes me think it's specific train only for both outward and return journey. Now I know that doesn't make sense that would be 2 advanced singles but the railway has a way of being dumb like that sometimes.
If someone could confirm the app is just wrong that would be great.
All that said if it is indeed a specific outward but a flexible return, I think that's actually a pretty acceptable replacement for off peak day returns. I've seen many routes where advanced Flex return is offered and I often know my outward journey way more than my return. They already got rid of peak Vs off peak on the valley lines years back and obviously PAYG is often much cheaper for that area.
Obviously I resent the simplification label as others have said it's just a way to make a bit more money. But also it's not a simplification as the alternatives involve stuff such as TOC restrictions which exactly what nationalisation should be doing away with.
Belperpete
17 Aug 2018
Not only is it badly labelled on the app, but both outward and return tickets also state only valid on booked trains. However, if you look up the restriction code (eg on BRfares) you will see that the only restrictions on the return is that it must be a TfW service, and no break of journey.
Hadders
27 Apr 2011
Presumably quota controlled so they can sell out, meaning that you might not always be able to purchase one?
py_megapixel
5 Nov 2018
Northern England
I'd agree there aren't many CDRs though. On the rural bits there aren't really peaks as such, so it's all Anytimes and 8A ("not really off peak") Off Peaks*. Chester to Manchester is probably the reasonably big loss here as most people will do that as a day trip.
* The reason for keeping these is often cited as the risk of people using Anytime Returns with their 5 day outward validity as de-facto season tickets, particularly when purchased on paper for cash as some staff don't bother marking them. But there is now the Anytime Short Return as pioneered by Northern which only has one day outward validity, so goodness knows why they keep this confusing and misleading name which just originates from them being Savers, a name which actually made sense in the context because they were cheaper than two singles.
It also allows them to have break of journey restrictions on return tickets.
Does anyone have any idea why they do this? It reduces flexibility for passengers and I can't see how it benefits the operator to tell passengers they can't get off the train early.
Generally it is done so they can price journeys at their market rate, in some cases due to competition the market rate for a longer journey may be lower than a shorter one.
LowLevel
26 Oct 2013
No change up here. We lost our CDRs many years ago. A lot of the SDRs went as well, plus some of the group tickets, forcing large numbers of passengers to be stuck with the SVR for all purposes.
I well remember the joy of finding that it was functionally impossible back then to buy a return with my priv in North Wales back then before you could use it on off peak tickets!
Mcr Warrior
8 Jan 2009
Presume this now means that break of journey at an intermediate station will likely mean that split tickets will possibly be required?
Envoy
29 Aug 2014
With the ability to buy an off peak return and travel back on any train - plus the option to hop off if so desired en route - is switched to buying Advance tickets and being forced to guess which one you will return on becomes the new policy (except in the Contactless areas) at TFW, then I will be switching to using the car which gives me the freedom to do what I like.
Mainline421
7 May 2013
Finland
Most TfW routes already use Anytime Day returns exclusively, and nothing has changed regarding period returns. So there is not any impact on BoJ except a small increase in fare on an even smaller number of routes.
No criticism of the OP since the titles is accurate, but highly misleading
Dr Day
16 Oct 2018
Bristol
Maybe more focused on those where there are other operators, hence it is more important to get 100% of the revenue rather than the case with the interavailable off-peak return which goes into a pot and the revenue shared? I can see TfW v GBR being quite competitive (which may or may not be good news for passengers), whilst GBR v GBR may be under more pressure to minimise net subsidy and be seen to 'simplify'.
LlanishenBull
3 Nov 2023
Cardiff
They removed longer off peak day returns last year. For example, my most regular journey outside the south wales payg area is Heath High Level (or Cardiff Central) to Hereford and that option was removed. So I split at Newport or hopped off and on to tap at Abergavenny. More of the latter in future.
Yes, they removed it for several of the corridors where you could split to save money on day-trips along the Marches line. The fares along the Marches line are really rather eyewatering, especially considering the level of service. They're more in keeping with what you'd expect on the WCML or ECML, not a secondary line with 1 (and a bit) trains per hour.
LlanishenBull
3 Nov 2023
Cardiff
My split tickets this Saturday (hhl to Buxton) is £63 with a railcard (without would perhaps be prohibitively expensive). 4 different returns, only 2 are off peak day returns.
Wallsendmag
11 Dec 2014
And this will cease to be an issue once CCST (Credit Card Sized Tickets-the old magstripe ones with no usefully scannable barcode) is fully phased out in favour of PRT (Paper Roll Tickets-the new barcoded till roll style tickets, scanned the same way E-tickets are).
Is PRT still new after 10 years?
Kite159
27 Jan 2014
West of Andover
I would imagine so. I.e. on a Saturday where there is a large event happening at the Millennium Stadium (6 Nations etc).
Although those sort of events are ideal for something like the Advance Flex ticket, as generally you will know what time you plan to head to Cardiff, but the return time could vary depending on the length of queue.
Farigiraf
23 Jul 2023
Bridge on the River Cam
Should just be a fair flexible ticket, than another more restrictive ticket.
It's not even necessarily about distance - if a flow has at least 1 train an hour, then providing an affordable flexible option should be standard, and if it has at least 4 trains an hour (of similar journey times) then fixed-train advance purchase is total nonsense. But in most cases yield management takes priority over logic, and TFW's Manchester-Marches route is one of those where filling up the limited capacity with long-distance travellers is deemed more important by TFW than those pesky short distance travellers.
That's not to say that there isn't a place for advances - certainly if the short journey leg were part of a longer journey (e.g. Northern Rochdale - Manchester then Avanti/EMR/TPE) then it makes sense to offer a cheap option for advance booking, that's common practice. But releasing advances with a limited quota is not a suitable substitute for an affordable walk-up fare on commuter routes. If Northern offers advances on sub-1h routes, and they are used a lot, that's not a success of advance tickets and an indicator of passenger preference, it's likely a result of an expensive walk-up fare.
Belperpete
17 Aug 2018
You may be right, but I have yet to find a TfW train on the North Wales coast where the Flexi Advance isn't available, including trains that have been full and standing. Although that may be because they aren't selling many, because people don't understand them.
They could only ever quota restrict the outward portion, as you are free to use the return portion whenever you want.
Starmill
18 May 2012
Bolton
Depends on the part of the country I suppose-TfL seem to be just realising the existence of barcode ticketing as a norm rather than some new-fangled niche option...
Barcode tickets will always remain a very niche option on TfL services as barely anyone is left using ccst today. That has been the case for a long time.
kieron
22 Mar 2012
Connah's Quay
Until TfW decide to get rid of those tickets as being confusing and only have anytime returns available for those wanting a return fare and not to be tied to a particular service.
TfW can't do that. The only anytime return tickets they price are "via Hereford" and "via Shrewsbury" ones which exist to undercut fares via Birmingham.
Chester-Manchester return will be a popular fare (wholly in England).
All three operators run essentially hourly services (Northern has 2tph if you include the slower route via Northwich).
TfW also provide a slower route between Chester and Manchester, theirs with a change in Crewe. There's no discount, though.
Do they mean Monday the 31st August as the 13th August is Thursday
Either way, brfares.com shows TfW-priced off peak day returns as being very much alive in September. Perhaps some will vanish then, I don't know.
If it's that insignificant, why do it in the first place ?
Are the anytime returns elsewhere equivalent in cost to a cheap day return elsewhere ? If they want to simplify, shouldn't they at least offer an anytime return on the routes affected, which would achieve consistency across their fares ?
