TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
sd0733
7 Nov 2012
67029 set 5 being kept back till 1W61
1W57 now 197113
Puts everything in place for a hopefully positive day tomorrow:
67016+HD01- Test run, likely repeat of HD04s today
67020+HD03- 1V91 etc, loco and set stop for exam at Crewe so all being well HD01 to replace it for Thursday.
67013+HD04- 1V33 etc
67029+HD05- 1W13 etc
67010+HD06- 1V31 etc
67017+HD07 1W11 etc
37052 xb mr
6 Dec 2023
Stockport
67017+HD07 1W11 etc
Thanks
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (17/12/24):
67025 was connected to HD06 until it swapped with 67010.
67016 connected to HD01
67013 connected to HD04
67025 was then swapped onto HD02.
67025 being the *RR* loco as it still has the sander problems which are stopping it from going out in service.
FrodshamJnct
14 Apr 2019
Cheshire
RTT has 67010 on 1W11 & 1V31
Not sure how :lol:
Plan should be 67017 on 1W11:
D1 - 67020 Set HD03 (Loco CDF end)
1V91 05.27 Holyhead - Cardiff 09.57
1W57 10.53 Cardiff - Manchester 14.13
1V46 14.30 Manchester - Cardiff 17.44
1W65 18.53 Cardiff - Manchester 22.24
1K76 22.32 Manchester - Crewe 23.09
D2 - 67017 Set HD07 (Loco MAN end)
1W11 04.21 Cardiff - Manchester 08.13
1V37 08.30 Manchester - Cardiff 11.38
1W59 12.53 Cardiff - Manchester 16.13
1V50 16.30 Manchester - Cardiff 19.43
D3 - 67029 set HD05 (Loco CDF end)
1W13 06.46 Cardiff - Manchester 10.13
1V39 10.30 Manchester - Cardiff 13.49
1W96 17.22 Cardiff - Holyhead 22.06
D4 - 67010 Set HD06
1V31 05.13 Crewe - Cardiff 07.50
1W55 08.53 Cardiff - Manchester 12.13
1V42 12.30 Manchester - Cardiff 15.43
1W63 16.53 Cardiff - Manchester 20.16
(5K70 ECS 20.24 MAN - CRE CS 21.09)
D5 - 67013 Set HD04
*Via WBQ* Set turns*
(5V33 ECS 05.12 CRE CS - MAN 06.23)
1V33 06.27 Manchester - Cardiff 09.47
1W61 14.50 Cardiff - Manchester 18.13
1V62 18.30 Manchester - Cardiff 21.52
37052 xb mr
6 Dec 2023
Stockport
D4 - 67010 Set HD06
D5 - 67013 Set HD04
Yes I know, thanks
sd0733
7 Nov 2012
All 5 sets behaving so far, path now in for the test run of HD01 to allow it back into service tomorrow.
And also for a loco which has been on maintenance at DB to test before returning too. https://www.realtimetrains.co.uk/service/gb-nr:40741/2024-12-18/detailed
Welshguy1048
6 Apr 2023
North Wales
@sd0733
Hello
Which loco is returning after maintenance?
Thank you
Dave
37052 xb mr
6 Dec 2023
Stockport
Set 1 test now showing as cancelled
37052 xb mr
6 Dec 2023
Stockport
Yes, postponed until tomorrow now.
HD03 now has dispensation to work w55 from Crewe and the rest of that diagram tomorrow but 1v31 will be a unit as a result.
I take it, it’s the same 5 tomorrow ?
Apart from 1V31 as you’ve said
Thanks
sd0733
7 Nov 2012
Thanks
Yes
03 w55 onwards
04 starts 1W13
05 starts 1V91
06 starts 1V33
07 starts 1W11
01 on its shakedown run ATC-ATC via Shrewsbury.
Then 01/04/05/06/07 as the planned 5 for Friday.
sd0733
7 Nov 2012
67014 is now on HD02 and is planned a test run tomorrow following HD04s and HD01s over the past few days.
If successful this gives 6 sets available going into the weekend, HD03 is on an exam over the weekend, once that's released HD04 will stop for its exam so 6 should remain through until Christmas barring any issues.
