TfW class 398 Stadler Citylink tram trains
chrisjo
18 May 2024
Llanishen
Nice line up of 398028 Myddfai, 756110 and an unidentified 756 at Cardiff Queen Street :)
Photo taken 25/8, 19:15, so:
398028 - 2J52 19:08 Cardiff Bay to Pontypridd
756110 - 2F58 18:10 Treherbert to Cardiff Central
and
756001 - 2F60 18:59 Caerphilly to Cardiff Central
ABB125
23 Jul 2016
University of Birmingham
What class 398 services can I expect to be running today? It looks like two Cardiff Bay diagrams according to RealTime Trains, but I haven't been following this thread so don't know if I'm missing something. Thanks
Cardiff123
10 Mar 2013
South Wales
It looks like one of the 398s has failed today and it's not been replaced, either by another 398 or a 150.
Are there only 3 x 398s still available for passenger services?
trainspotter4
24 Jul 2025
Cardiff
Seems like 398022 failed early on in the day but absolutely no attempt to swap this out so far, first time we've seen this.
Usually they are swapped out within an hour or so max by part-running to Taffs Wells and unit swapping there, maybe limited units today...?
Just looking about on RTT, seems like there is a few mainline diagrams requiring 197s/Sprinters which isn't happening because none available so can't see a 150 swap coming, will be another 398 if anything or cancelled for rest of the day similar to mainline services currently. Ebbw <> Newport, one diagram is uncovered/cancelled and Cardiff <> Cheltenham one diagram is uncovered/cancelled. Interesting why another 398 hasn't come in though?
Cardiff123
10 Mar 2013
South Wales
Meanwhile there's luxury on the VoG today with 2 double 150s on 2 different diagrams, when other services are being cancelled.
Sometimes TfW's allocations make absolutely no sense
trainspotter4
24 Jul 2025
Cardiff
Yeah, their allocation/swap decisions are strange at times, interested to see if that double-up lasts the rest of the day; looks like a 197 was taken off Cheltenham for Pembroke (first I've seen this, usually Chester).
It highlights the absolute need for the 398s to continue progressing so 231s can move to mainline, as to be fair Canton/Barry-maintained units seem to be the only thing not in short supply (minus 153s coming out of storage).
Photo recently posted around showed 398022 still in Cardiff Queen Street (Platform 1) so seems like the first unit to have got stuck in service, as usually they head straight back to depot.
positron
18 Oct 2022
Cardiff
Wonder what's wrong with 398022. Will it have the battery to make it back to Taffs Well?
Though I'm guessing one reason it's not been rescued is because platform 1 at queen street is a bit of a pain to rescue from. You can't get from there to the other running lines without going via the bay line. So you'd presumably have to get another 398 behind it connect up shunt down to the bay line at least a bit and then decide how you're going to get it back to Taffs Well, presumably you'd need to rescue unit in front so going via city line is probably easiest but longer off wires during a rescue?
spaniel
14 Oct 2025
Caerphilly
I saw 398022 stranded on platform 1 earlier today as described above, unmanned by the looks of it, I couldn’t see any engineers or anything. I just passed back through QS and it is still there.
Attached is a photo from just before 1pm today
trainspotter4
24 Jul 2025
Cardiff
Just had a look now, seems 398022 is still on Platform 1 as of writing this; the rescue attempt is planned for near end of service (23:40 leaving Taffs Wells, https://www.realtimetrains.co.uk/service/gb-nr:11838/2026-08-31/detailed and sending down to Cardiff Bay to reverse for 23:59, https://www.realtimetrains.co.uk/service/gb-nr:11842/2026-08-31/detailed), will be interesting to see how they manage this as it's the first rescue we've seen whilst they've been in service and maybe even testing (I do recall one failing in Aberdare with brake issues but believe this was fixed at the station not requiring rescue during early testing)? Does only appear to be using one unit based on diagraming but maybe they'll send out a double unit and de-attach if either side is required, will also prove an early comment if 398 rescues absolutely require a functioning unit on either side (so three total) or not.
positron
18 Oct 2022
Cardiff
Any idea how the rescue went?
Edit: looks like it might be ongoing two separate entities are dancing around on Traksy right now. 5Z21 and 5Z22
AdamWW
6 Nov 2012
Presumably dealt with as this morning there seemed to be a 398 in service in platform 1.
MikePJ
10 Dec 2015
Definitely in service as I saw it running on the Bay line.
RealTimeTrains also notes that the route timings for the rescue train was for a maximum of 33mph (about 50km/h in metric), and it didn't keep up to those timings, so was definitely going pretty slowly. https://www.realtimetrains.co.uk/service/gb-nr:11841/2026-09-01/detailed
Lurcheroo
21 Sep 2021
Wales
It was done with 2 units. One front, one rear and 5mph max. Not sure if the 5mph max is necessary for all rescues or if there was something specific with this one for the speed restriction. There was a long list of faults displayed that couldn’t be rectified so hard to know.
chargesmith
14 Nov 2023
South Wales
It will be interesting to see how long until 022 is out again.
By my memory, with previous unit in service failures the failed unit has been able to return to the depot under its own power and is usually back out in service the next day.
Given this is the first unit that has needed to be rescued then this may not be the case this time.
Peter Sarf
Croydon
398025 making it's debut in service today
Working alongside 028 and 031
Thanks - my list duly updated :-
I feel a list coming on :-
398001
398002
398003
398004
398005
398006
398007
398008
398009
398010
398011 Testing from 15/08/2026
398012
398013 Testing from 19/08/2026
398014
398015
398016 Testing
398017 In service on 28/07/2026 6th, two in service 03/08/2026 (398017 and 398029 not coupled)
398018 In service on 10/08/2026 8th, Testing (multi ?) before
398019 Seen at Merthyr on 22/08/2026, presumably testing ?.
398020 Testing (multi)
398021 In Service on 18/08/2026 9th
398022 In service on 03/07/2026 4th (all day 23/07/2026)
398023 Testing
398024 In service on 25/06/2026 3rd
398025.In service on 02/09/2026 10th
398026 Testing from 18/08/2026
398027
398028 In service on 23/06/2026 1st
398029 In service on 31/07/2026 7th, also did first weekend service (Saturday 01/08/2026), two in service 03/08/2026 (398017 and 398029 not coupled)
398030 In service on 14/07/2026 5th
398031 In service on 24/06/2026 2nd
398032.Old Dalby
398033
398034.Delivered on 14/05/2026 ?
398035.Not yet delivered
398036.Not yet delivered
First day with two in service 03/08/2026 017 & 029.
First day with three in service 19/08/2028 017, 029 & 031.
First rescue of a 398 (022) by two other 398s (possibly T&T as reversal required) 01-02/09/2026 - successful.
That is all the past dates (before 01/08/2026) I can unearth.
Below is a list of 398s in the order they entered service (I have decided to make life more complicated !).
Unit, date, (days elapsed)
01 398028 23/06/2026
02 398031 24/06/2026 (1)
03 398024 25/06/2026 (1)
04 398022 03/07/2026 (8)
05 398030 14/07/2026 (11)
. . . Milestone : First all day service on 23/07/2026 (398022)
06 398017 28/07/2026 (14)
07 398029 31/07/2026 (3), also did first weekend service (Saturday 01/08/2026), two in service 03/08/2026 (398017 and 398029 not coupled)
. . . Milestone : First day with two in service 03/08/2026 (398017 and 398029 not coupled)
08 398018 10/08/2026 (10)
09 398021 18/08/2026 (8)
. . . Milestone : First day with three in service 19/08/2028 (398017, 398029 & 398031).
10 398025 02/09/2026 (15)
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
Thanks for letting us know :)
The entry-to-service of 398025 'today' (Wed 2/9/26) now means that 10 (of 36) 398s have been in service:
398017-018, 398021-022, 398024-025, 398028-031
The number of 398s still to enter service is down to 26:
398001-016, 398019-020, 398023, 398026-027, 398032-036
The overall number of new Transport for Wales (TfW) trains that have been in service is now up to 121 (of 148):
76 (of 77) 197s
All 11 231s
10 (of 36) 398s
All 24 756s
This leaves 27 new TfW trains still to enter service:
1 197
26 398s
nigelsporne
20 Dec 2012
Coleshill
If two units, one each side of the failed unit, are required to allow removal how will this work on the single line sections of the network?
AdamWW
6 Nov 2012
Call in Allelys?
(Or, more seriously, perhaps it doesn't have to be one on each side)
positron
18 Oct 2022
Cardiff
They'd presumably just pull it to a section where they then can connect the other train on the other side. For example they pulled the unit to the Bay before the other unit then went down and connected up to pull back to Taffs Well.
6opher
4 Jul 2016
No they do not always need 2 units to rescue 1. On this occasion it was needed but for normal bog standard rescues, 1 will do.
