TFW 2024 Timetable consultation.
Jez
22 Jan 2011
Neath
It does seem like TfW want Newport to Ebbw Vale to fail. Half the services are cancelled on a daily basis, the trains they put on the line are 1 coach rust buckets from the 80s and I don’t see how you promote and grow a market by doing those things. It’s all so so sad.
I dont think they want it to fail. But its a new service so makes sense to cancel when there is no other choice due to a shortage of trains at the moment. As there is an alternative service to Cardiff which people managed with for years.
Harpo
21 Aug 2024
Newport
TFW did give me a chuckle a little while ago with this poster at Ebbw Vale, suggesting using the train instead of the car to get to Abergavenny. It would take around 2 hours with the trip south to change at Newport before heading north again.
It’s about 15 minutes in the car.
Dai Corner
20 Jul 2015
Or about an hour on the 78 bus.
Athe
18 May 2022
West Midlands
I've tried to have a look at the draft allocations available via FOI for December. Below are what I think are the number of diagrams each day by type, but I'm not fully sure how many of each type are actually available! I've only included diagrams that are doing service work:
8 x 231 Diagrams (11 in fleet)
16 x 250 Diagrams (30 in fleet)
10 x 756/1 Diagrams
8 x 153/1 Diagrams
4 x 153/5 Diagrams
6 x 153/9 Diagrams
5 x Loco Diagrams
28 x 197/0 Diagrams
22 x 197/1 Diagrams (including SP Diagrams)
2 x 230 Diagrams (5 in fleet)
19 x 158 Diagrams (24 in fleet)
60159
26 Nov 2018
10 x 756/1 Diagrams
8 x 153/1 Diagrams
4 x 153/5 Diagrams
6 x 153/9 Diagrams
5 x Loco Diagrams
28 x 197/0 Diagrams
Very interesting. Assuming no Cambrian units are included that’s 50 out of 56 197s which is pretty steep especially given the current problems. Indeed, it was reported 126 is still in the factory.
Obviously there’s some slack in the 150s.
It would be interesting to know when the C6 overhauls are due as that’s when they will be withdrawn.
Lurcheroo
21 Sep 2021
Wales
10 x 756/1 Diagrams
8 x 153/1 Diagrams
4 x 153/5 Diagrams
6 x 153/9 Diagrams
5 x Loco Diagrams
28 x 197/0 Diagrams
there are:
- 24 x 756’s (none are accepted yet)
For 153’s this is what I can work out, someone may correct me.
- 15 x 153/1’s
- 5 x 153/5’s
- 9 x 153/9’s
-7 x MK4 rakes
-51 x 197/0’s (21 are ETCS fitted so 30 currently in service)
- 26 x 197/1’s (14 have SP and 2 are still yet to be accepted into service making the available total right now 24).
So for the 197’s it seems like the expected level is to only have 2 of each type (2car and 3car) out of service each day, whereas the 231’s are planned for 3 out.
Jez
22 Jan 2011
Neath
10 x 756/1 Diagrams
8 x 153/1 Diagrams
4 x 153/5 Diagrams
6 x 153/9 Diagrams
5 x Loco Diagrams
28 x 197/0 Diagrams
Many Thanks for posting these. 197 availability is going to have to increase significantly to cover all those diagrams. Especially 28 out of 30 2 cars in service.
there are:
- 15 x 153/1’s
- 5 x 153/5’s
- 9 x 153/9’s
-7 x MK4 rakes
Hopefully the remaining 3 car 197s will be in service by December.
I would be interesting in seeing the 153 diagrams. Obviously the 153/5 are for the Heart of Wales paired up with a 153/1 I assume? But what else?
Lurcheroo
21 Sep 2021
Wales
Hopefully so!
Not sure on the 153’s and what the exact plans are but as MP393 said, they will also be doing the Crewe - Shrewsbury stoppers.
nwales58
15 Mar 2022
notsure
Cambrian 2147 Machynlleth-Pwllheli that ceases to run from December for the 'winter': anyone know when it resumes?
30907
Lurcheroo
21 Sep 2021
Wales
Original proposal said cancelled Dec-Mar.
Here is an ECS that runs SX until 28 Mar
https://www.realtimetrains.co.uk/service/gb-nr:W29714/2025-01-15/detailed
I deduce that a late SX service to Mach (and therefore the return working) resumes Monday 31 March, but obviously cannot say what time.
berneyarms has done better though :)
So there is talk that a Pwllheli crew and a Mach crew will have to swap over at Tywyn around 17:30 to allow the 19:20 arrival at Pwllheli to be shunted to the sidings.
DelW
15 Jan 2015
Hopefully not running as a solo 153/5, although knowing TfW anything is possible.
I didn't think that would be allowed?
Posts in this thread:
state that they must be coupled to a /3 to provide the accessible toilet (post 11) and
only one type of cab will be in use (post 22 et seq) - though possibly that could be overridden in some circumstances.
Lurcheroo
21 Sep 2021
Wales
Correct about not being able to run on Their own due to needing a PRM toilet.
I think the idea is that as the 2 cans are rather different, 1 is significantly preferred by drivers so makes sense to bury the 2 that are less preferred in the middle.
No doubt that it won’t always happen for some reason or another.
DelW
15 Jan 2015
I'd thought that if they will always be kept as two coach sets, maybe the inner cabs might be permanently taken out of use to save on maintenance costs. There'd be a loss of flexibility though, and that might outweigh any savings. It'll all become clear in time no doubt, though it's a pity the /5 active cars missed this summer's holiday season.
Lurcheroo
21 Sep 2021
Wales
I don’t believe so.
Yes they certainly have but they should be ready for next year at least!
jayah
18 Apr 2011
Fantasy timetable planning. As I've said elsewhere any timetable planning to couple diesel units in multiple always operates with short formations being routine.
The list of established DMU fleets running at consistent 93% availability is probably a page marked as intentionally blank.
Krokodil
23 Jan 2023
Wales
We told management this when they talked about the amazing new trains they were ordering and we complained that they were predominantly two coach units. "But we can couple them up" - yeah, and you can also uncouple them and we're the ones who get the abuse.
Coupling is justified for situations like the Cambrian or the West Highland Line. Otherwise it's just a random fault generator and wastes space in the units by duplicating facilities which would have been extra seating on a fixed formation four car unit.
anthony263
19 Aug 2008
South Wales
Should havehad Caf build a. I mode version of the 397s for the south wales to Manchester route or of the 185s were available used them on it. Swansea to Milford haven certainly needs 3 carriage trains
Starmill
18 May 2012
Bolton
It's often forgotten that a marginal 16 seats per four car set can actually be quite significant. Even if it's only 5% of seats on the set.
jayah
18 Apr 2011
Only on the day. Too many people ordering slightly higher capacity units e.g. 810 vs 222 thinking this will solve their problems.
The curtailed demand on many of these route is more like half and these 5,10,15% capacity uplifts every 25yrs don't even touch the sides.
Krokodil
23 Jan 2023
Wales
No argument here, the other aspect of relying on pairs of units vice fixed formations that I listed is the ability to short-form and halve the capacity at a stroke. Train doesn't get cancelled so the statistics look good but that's no comfort to the passengers left behind. Whereas with fixed-formation trains the only way to avoid a cancellation is to have a large enough fleet that allows you to have some spare cover for the event of a unit shortage. Unfortunately "sweating the assets" and "providing a good service" are incompatible.
Out of curiosity, what's the typical availability of a DMU? One which has been in service long enough for teething troubles to have been ironed out, but isn't old enough for failures to increase and parts availability to become an issue.
Caaardiff
9 Jun 2019
So you think it's a good idea to spend tax payer money on a more expensive fleet of train, and have several of them sat around doing nothing just in case of failures and disruption?
Instead you can run a larger fleet of trains that has the flexibility to fit your networks requirements, and having the ability to still run a train, albeit short formed, instead if cancelling it completely and making people wait at least an hour for the next service?
It's been discussed to death on here, once TFW has it's whole fleet in service there will be an overall huge lift in capacity, and also greater flexibility in switching untis around to maintain reasonable capacity. Currently that flexibility isn't there because the fleet is stretched by not having them all in service. The overall plan includes having some spare units around the whole network that can step in when needed, and flexibility to call upon some services that have layover time at certain locations. It will never always be ideal but no TOC is going to spend millions on a large 5+car train to have it sat around 'just in case'
Krokodil
23 Jan 2023
Wales
Do you think that it is a good idea to spend taxpayers' money compensating people who have been disrupted due to an insufficient fleet? How much does the railway lose in income because the guard cannot get through to check tickets? How many customers are saying "never again" after being wedged into yet another short-formed train? How much extra cost is incurred in building a driving vehicle vs a centre car (there's a lot of expensive equipment in that cab)?
People are already having to wait an hour for the next service because they either cannot physically get on crowded trains, or the train doesn't even stop in order to avoid it being mobbed. Having two-coach units was idiotic, there is almost no diagram where one is adequate for the whole day.
Yes, around 50%. Roughly equivalent to the amount of demand being suppressed, with little room for further growth. Not that all routes are expected to see any extra capacity.
It's not quite that simple in practice, if you rely on lots of coupling and uncoupling you will have a very fragile operation.
Not forgetting poor reliability and low availability.
Always assuming that the ambitious availability projections work out. 21 197s doing the work of 24 158s? I'll believe that when I see it.
Who said anything about 5+ car trains? I'm talking about using four car units instead of pairs of twos.
jayah
18 Apr 2011
Low 80s.
Of course it is better when you have a decent number of them to start with, these days a large class of DMU is 20 of something and 30 of something else.
Caaardiff
9 Jun 2019
This is based on the current situation. I'm not sure how many times it needs to be said to you, but once the whole fleet is in, that should be very different.
This is based on the current situation...
That's an ambitious forecast of future demand. 5 cars is more than enough for Marches/Manchester. Having the odd extremely busy service due to short notice demand like events or previous cancellations doesn't warrant running longer trains around that most of the time will be fairly quiet.
I do actually agree with your last comment, assuming it's relating to the Cambrian and Birmingham line. Madness that isn't seeing capacity increases.
Because other modern fleets are just as reliable? IET's have their problems, and again, there'll be less of them.
Agreed, madness. It's based on 19 in service each day, whereas 158's used to be 20 for 24 units as there was a Cardiff-Holyhead diagram.
But having a uniform fleet means that non-ERTMs 197's can step in to cover the capacity with swaps to keep them off the Cambrian. It would make more sense to have had more ERTM's fitted units for flexibility.
You didn't specify that, so you're suggesting 4 car 197's? Then you're suggesting short forming the planned 2+3 5 car services to 1 4 car unit? Makes sense. 7 cars are too long for most of TFW's services & stations, so you'd need 2 cars and 4 cars to get 6 cars?
Your argument doesn't make sense, when the plan for most TFW services are to be 5 car (South Wales - Manchester & some North Wales - Manchester services).
