TfL order more Electrostars.
332 > 444
22 Feb 2007
So does this mean that there will be 4 carriage trains on the NLL/WDCL/WLL? Sense has prevailed.
Is the 8 class 172 for the GOBLIN true also?
Mojo
7 Aug 2005
I should imagine they'll have a bit of a job lenghtening the platforms at Willesden Jn High Level.
It's not been mentioned anywhere on the TfL website about 172s for London - they're for WM.
paul1609
28 Jan 2006
K
"The next station is xxxxx passengers should note that you cannot allight from the rear coach of this train due to a short platform at this station. This is coach 4 of 4." announcement on thousands of southern, southeastern electrostars at stations per day why can xxxxx not equal Willesden Junction"?
Mojo
7 Aug 2005
I'd say the main reason would be the fact that it would affect a lot of stations if none are lengthened, thus the 4th car would probably never get used!
As for Willesden Jn, the problem here would be the fact that the trains tend to be well loaded throughout the day, thus making it very difficult to move forward in the train once you've heard an announcement. The desired option would be to have one set at the front & back not open, but the starting signal at this station would prevent this as it is located at the platform's end.
