tfl journey planner and specifying travelcard
tannedfrog
26 Jun 2010
I'd like to be able to specify that the tfl journey planner doesn't offer me things which my travelcard doesn't cover, like heathrow express / HS from St Pancras, coaches, and changing trains outside the travelcard area
Is this possible?
Thanks
W-on-Sea
18 Dec 2009
It's easy enough to remove coaches (and for that matter boats) if you select "advanced options" and untick the relevant boxes. Not sure about the other things though.
MikeWh
15 Jun 2010
Crayford
I've just had a play with one example. I asked for Cockfosters to Heathrow 1,2,3 Underground. It gave me a convoluted route finishing with HEx. When I went to advanced options there is a set of radio buttons with "Fastest Route" selected. If you change that to "Fewest changes" then it routes you direct via the Picadilly line all the way. That won't always work, especially if you ask for Paddington to Heathrow! As HS1 is only between St Pancras and Stratford within London I would imagine that fewest changes would probably be quite effective at ruling that out as well. Can you give me an example of when it routes you outside the zones?
I have to agree though, it would seem to be a logical option that they should offer.
tannedfrog
26 Jun 2010
it was from a station on the FCC St Pancras to St Albans line, going to a station further north.
It told me to change at St Albans, presumably because not all the north bound trains stopped at all stations
I forget which stations
