TfGM Bee Network - fleet discussion
14 Jul 2017
Manchester
Buslistsontheweb shows three unregistered BZL single decks owned by TfGM - entries shown below. Is this a mistake or are there three more BZLs in store somewhere ?
BU26Vo BZL YV3U1W126RA217708MCV NB1716B38F/2026TfGMIntended as BD74WLG, BU25YXS and BU75WUT
BU26Vo BZL YV3U1W122RA217706MCV NB1714B38F/2026TfGMIntended as BD74WLE, BU25YXO and BU75WUP
BU26Vo BZL YV3U1W124RA217707MCV NB1715B38F/2026TfGMIntended as BD74WLF, BU25YXP and BU75WUR
mattyharding
14 Dec 2024
Stalybridge
Hmmm no idea where they could be going but I'd assume either Hyde Road or maybe Oldham
DDJohn
19 Sep 2024
Sandbach
These could be the three that are currently in store in Hyde Road Depot. I've heard they could be for a new/extension of a route around Hyde (Could be wrong)
Class 466
5 Mar 2010
Atherton, UK
there's a PVR increase coming to Ashton that'll require more (presumably) BZLs
mayneway
29 Mar 2024
Manchester
The PVR increase from September will mainly see an increase in double decker BZL’s for an uplift on the 219, and the start of new service 388.
These 3 singles are most probably also for Ashton. There’s constant issues with the 382 and the double deckers being too big for the route so TFGM agreed to provide some small single decker BZL’s - the same as used on the freebus for this service.
M60lad
31 May 2011
Apart from interworking with School duties I've never understood why 382 is a double decker route as there are parts of the route where a decker sometimes struggles getting round, I'm pretty sure when 382 first started it was always operated with E200s.
I still find it odd that its operated out of Ashton Depot despite the fact it goes nowhere near the Depot.
Class 466
5 Mar 2010
Atherton, UK
Is there any clarity on the routing of the 388? Is it as it used to be?
It feels like the “across the board” BZL decker policy at Ashton is a bit excessive on a couple of routes - the 389 definitely doesn’t need deckers, it’s empty whenever I see it :D
mattyharding
14 Dec 2024
Stalybridge
Personally what I would do is move the 348 to Ashton and the 382 back to Stockport
py_megapixel
5 Nov 2018
Northern England
A good few routes were removed from Stockport and transferred elsewhere when franchising started. 313/370/371 to Wythenshawe, 368 to Sharston, 382 to Ashton and probably a few more I've forgotten.
I would have assumed this was because downsizing the depot a bit would make it easier to relocate the operations - but then for whatever reason they transferred the 330 (which I think was originally going to be an Ashton route) into Stockport, hence the relatively small fleet of nonstandard Wright Streetdecks there. So I'm really not sure what the logic was (if someone could enlighten me that would be appreciated).
Before franchising the 382 was mostly short single deckers such as Enviro 200s and Solos, but it was not unknown for Stagecoach to put a double decker on it occasionally
I also don't understand why Stockport has a tiny fleet of only a few Enviro 200s when the rest is double deckers. There's not enough of them to be the full allocation for any given route so they seem to just show up at random on any of a few different routes. They seem like obvious candidates to run the 382 if it came back to Stockport.
mayneway
29 Mar 2024
Manchester
All we know is it’s going to be similar to the 389 but extend to Hyde and also interwork with the 389.
I’d disagree regrading loadings and the use of deckers on the 389, it’s an incredibly busy route and daytime trips can leave Ashton with near enough full loads, but once it’s gone round ridge hill it’s virtually empty.
What you’ll also find is when there’s a 348 or 237 loading in the bus station at the same time the 389 is quieter as the punters wanting Stalybridge will use one of them instead.
Realistically the 382 should have been grouped with the small Stockport contracts won by Diamond as it would make more sense to run mellors on it but I understand it went to Ashton because there was a desire to extend it once again to Hyde, although that’s not happened as yet.
But on the same argument you could ask what’s the point in go north wests Denton depot when that work could have realistically been run out of Ashton with a few extra vehicles.
mattyharding
14 Dec 2024
Stalybridge
Ashton depot does not have the capacity for the Denton routes
M60lad
31 May 2011
In regard to 382 from what I remember before franchising started during the week most duties were operated by double deckers as they interworked with Schools at certain points of the day whereas at weekends I think it was a mixture of double and singles.
Now the only reason why 382 is double deck operated is due to the fact as I've mentioned its run out of Ashton and Ashton haven't got any single deckers in their fleet.
mattyharding
14 Dec 2024
Stalybridge
Ashton should have some BZL single decker buses as well
mayneway
29 Mar 2024
Manchester
Because TFGM felt it could be run with deckers. Now they are not happy that most days at certain times part of the route are missed due to badly parked cars so have deceived to allocate some small singles to Ashton soley for the 382.
mattyharding
14 Dec 2024
Stalybridge
I read something earlier that Oldham's electric fleet is due to arrive in August at some point, I wonder if this is just the Wrightbus order or a full depot replacement
MCRTransitYT
15 Nov 2024
Bolton
Only 64 Streetdeck Electroliners are due for Oldham (55 + 9) with 16 GB Kites. So they must have around 64 diesel deckers, whether thats Tridents or Enviro400 MMCs, to replace
jeffery9098
16 Sep 2023
Manchester
As it was confirmed that Hyde Road + Oldham would be fully electrified by the end of 2026 so :D
If done wisely, Oldham may retain those AD Enviro400EV from Metroline!
mattyharding
14 Dec 2024
Stalybridge
And this will probably mark the end of B5LH operation in Oldham as well
So the 25 that are at Hyde Road could be moved over to Oldham you think
Dallamlad
13 Dec 2008
Manchester
Latest fleet card shows Oldham’s new ones allocated with the following numbers/regs
MANCHESTER P02
on order
82451 MF26EBN
82452 MF26EBO
82453 MF26EBP
82454 MF26EBU
82455 MF26EBV
82456 MF26EBX
82457 MF26EBZ
82458 MF26ECA
82459 MF26ECC
82460 MF26ECD
82461 MF26ECE
82462 MF26ECJ
82463 MF26ECN
82464 MF26ECT
82465 MF26ECV
82466 MF26ECW
82467 MF26ECX
82468 MF26ECY
82469 MF26ECZ
82470 MF26EDC
82471 MF26EDJ
82472 MF26EDK
82473 MF26EDO
82474 MF26EDP
82475 MF26EDR
82476 MF26EDU
82477 MF26EDV
82478 MF26EDX
82479 MF26EEA
82480 MF26EEB
82481 MF26EEG
82482 MF26EEH
82483 MF26EEJ
82484 MF26EEO
82485 MF26EER
82486 MF26EEU
82487 MF26EEV
82488 MF26EEW
82489 MF26EEX
82490 MF26EEY
82491 MF26EEZ
82492 MF26EFA
82493 MF26EFB
82494 MF26EFC
82495 MF26EFD
82496 MF26EFE
82497 MF26EFG
82498 MF26EFH
82499 MF26EFJ
82500 MF26EFK
82501 MF26EFL
82502 MF26EFM
82503 MF26EFN
82504 MF26EFO
82505 MF26EFP
M60lad
31 May 2011
Am I right in thinking the Wright Kites will be replacing the E300s at Oldham Depot?
mattyharding
14 Dec 2024
Stalybridge
Most likely yes
MANCHESTER P02
on order
82451 MF26EBN
82452 MF26EBO
82453 MF26EBP
82454 MF26EBU
82455 MF26EBV
82456 MF26EBX
82457 MF26EBZ
82458 MF26ECA
82459 MF26ECC
82460 MF26ECD
82461 MF26ECE
82462 MF26ECJ
82463 MF26ECN
82464 MF26ECT
82465 MF26ECV
82466 MF26ECW
82467 MF26ECX
82468 MF26ECY
82469 MF26ECZ
82470 MF26EDC
82471 MF26EDJ
82472 MF26EDK
82473 MF26EDO
82474 MF26EDP
82475 MF26EDR
82476 MF26EDU
82477 MF26EDV
82478 MF26EDX
82479 MF26EEA
82480 MF26EEB
82481 MF26EEG
82482 MF26EEH
82483 MF26EEJ
82484 MF26EEO
82485 MF26EER
82486 MF26EEU
82487 MF26EEV
82488 MF26EEW
82489 MF26EEX
82490 MF26EEY
82491 MF26EEZ
82492 MF26EFA
82493 MF26EFB
82494 MF26EFC
82495 MF26EFD
82496 MF26EFE
82497 MF26EFG
82498 MF26EFH
82499 MF26EFJ
82500 MF26EFK
82501 MF26EFL
82502 MF26EFM
82503 MF26EFN
82504 MF26EFO
82505 MF26EFP
Have any arrived to England yet
18 May 2009
Bolton, Lancashire
A question for Mr Leyland Bus
Been meaning to ask since last week!
Do you know why 4136-4140 appear to be off the road, all 5 haven't tracked since 16th June. (Well their ticket machines haven't).
Thank you!!
Leyland Bus
20 May 2021
York
Thank you!!
Currently laid up at Wigan, can't say why as yet.
jeffery9098
16 Sep 2023
Manchester
There's a possibility they might considering they are owned by TfGM and with Hyde Road getting it's whole depot "cleaned out" allegedly with new electric buses then it'll would make sense to move them ADE's to Oldham rather than to let's say Ashton or Sharston. As with the small amount of streetdecks went to Wigan from Hyde Road + the two single enviro200mmc's then TfGM can to do it to any vehicle they 'own'.
