Termini that are really just like wayside halts
Discussion of Aylesbury Vale Parkway on another thread led me to wonder how many stations there are that are like this - stations that really have the feel of quiet wayside halts but are termini, with the much busier main station not being the terminus of the line. (I know some trains do terminate at Aylesbury). It's also unusual in that it was built like that, though I think it was intended that it would see more custom than it actually has seen.
Obviously AVP will get busier as more housing is built in the area and it really takes on more of a role of "Aylesbury North" - but for now what other examples are there of termini where the terminus is really quiet and the main traffic objective(s) are further down the line as simple calling points?
Headbolt Lane might sort of be one? Severn Beach another?
Right now, thanks to the engineering works, Corkickle
I did think of that one.
The terminus of convenience that is Manchester Airport sort of is, but is obviously busy (and increasingly busy) in its own right so probably doesn't count, and definitely doesn't have the feel of a wayside halt. If trains terminated at Ardwick then that would though :)
Chathill might be one perhaps? Stations further south are generally busier and it definitely has the feel of a wayside halt!
THC
21 Sep 2009
Stuck on the GEML
Colne. Rendered a terminus by closure of the line onto Skipton, it feels very much as described. I'm sure there will be other such termini created in similar fashion.
THC
That whole line has a 1990s-like feel of desolation, but Colne is a reasonably sized place and is fairly well used so I'm not sure it is?
Bedwyn probably was when there was the through service from Paddington terminating there?
Farigiraf
23 Jul 2023
Bridge on the River Cam
I can think of a few like this:
Fishguard Harbour, Ardrossan Harbour and Lymington Pier have ferry connections but aren't much more than a halt. The Town / South Beach / & Goodwick stations have more life in them.
Similarly, Heysham Port vs Morecambe.
The other way round, Harwich Town operationally is less relevant compared to International with its longer-distance connections and ferry port. It's got more character than your average halt however.
Sheringham is a bit of an afterthought compared to the larger and busier Cromer.
Shoeburyness has a few platforms and the depot but other than that, there's really not much going on and far less people than Southend Central. Nearby, there's the Crouch Valley line to Southminster, which, if another Beeching were to happen, would likely be curtailed back to Burnham-on-Crouch or South Woodham Ferrers.
cactustwirly
10 Apr 2013
Aren't they just quiet branch lines? I'm thinking of termini where the line itself is busy enough but the terminus is a bit like a wayside halt, with stations with far higher traffic further down the branch?
You named Severn Beach as an example? That is a quiet branch
Marlow gets fairly busy, the peak service doubles
lachlan
11 Aug 2019
Severn Beach is a better example as the terminus is quiet but Avonmouth is significantly busier. Whereas Marlow is a reasonably busy station, and the whole Gunnislake branch sort of might as well not exist?
Indeed I would say the Severn Beach line fits your description as it's relatively busy with a lot of changeover at intermediate stops, but only one train per hour continues past Avonmouth and these are quiet in my experience.
StarCrossing
27 Jul 2015
It's never quiet when I travel on it! Usually very busy between Temple Meads and Clifton Down.
Wrexham would be a good example if you just consider the line to Bidston, with General being the main station and Central the quiet terminus.
Thebaz
24 Nov 2016
Purley
Epsom Downs I would suggest. A single platform in the middle of a quiet insignificant housing estate in the middle of nowhere.
sycns
8 Feb 2021
Doncaster
Adwick probably counts with the Adwick > Doncaster > Sheffield Midland hourly stopping service.
cactustwirly
10 Apr 2013
It provides the suburban service in Plymouth, basically the only service for Dockyard and Keyham.
Bere Alston and Bere Ferrers seemed reasonably busy.
Top half is pointless yes
RailWonderer
25 Jul 2018
All around the network
Stranraer? Almost all trains terminate at Ayr and only two or three trains per day continue further. The station has a metal shed and looks very desolate, even though it serves a small coastal town.
Chathill’s down side station building doesn’t make it look like a wayside halt at all. It’s one of quite a few on the line through Northumberland that was built on the grand scale.
pdeaves
14 Sep 2014
Gateway to the South West
Historically, there was a branch from Harpenden to Hemel Hempstead (not the WCML station) with the line terminating at... Heath Park Halt. There can't be many lines that terminate at (what is generally considered to be) a 'halt'. Granted, there was an intention, never realised, to connect onto the WCML beyond there.
cjw714
4 Nov 2024
South-East Asia
Somewhat surprisingly Gunnislake is the busiest station on the branch with considerably more passengers than even the Plymouth suburban stations.
Falmouth Docks is a possible example, getting just over half the number of passengers as Falmouth Town.
Doomotron
25 Jun 2018
Kent
During engineering works, Minster has been a terminus for trains from London via Canterbury and Dover, despite its small size.
