Technical Data from the Channel Tunnel
Gorgi
19 Apr 2025
Mannheim
Hi,
I'm planning to build a channel tunnel simulation, but I want it as best and smooth as possible. I have already get an vertical alignment.
So I actually searching for an horizontal alignment of the rails, best might be with curve radii and data for superelevation.
I also tried to get a lock into old planning documents, but I did not really find anything from that time.
Maybe someone has an idea for it?
I also tried to look at the data from Network Rail, but couldn't find anything about the alignment, only point speed diagramms.
Thx.
Greetings Gorgi
I tried to edit my last post, but not seeing it where it is possible.
So here because of the asking:
It is for a simulation and not for real life. Also it should be possible to drive with simulated trains in the simulation threw the tunnel under TVM 430.
