Taunton connection time query
M60lad
31 May 2011
I know someone who's booked on the following services:
12:07 Piccadilly-Taunton XC service
15:50 Taunton-Penzance GW service
I was wondering what the connection time is like for these 2 services and would the person I know catching 15:50 make it in time and what would happen if say 12:07 runs late, is there a chance that the 15:50 would be held so they could catch it
tsr
15 Nov 2011
Between the parallel lines
They may do if they move quickly. Why did they not choose to change at Exeter St Davids? Am I missing something? It may be worth amending one of the tickets or buying a Taunton-Exeter St Davids single, I suppose.
gnolife
4 Nov 2010
Johnstone
That depends on whether the Taunton to Penzance ticket is an advance (or indeed, if the whole thing is one advance ticket) -if its an advance saying board at Taunton, they must board at Taunton, no ifs, no buts.
tsr
15 Nov 2011
Indeed. I am simply suggesting a solution which may be appropriate, but I should have been clearer!
CBG2KGX
15 Jan 2011
Cambridge
The XC looks to be booked for platform 3 with the GW being on 2. This entails a walk via the subway which can generally be done is less than two minutes unless the lift is required which can slow things down a tad.
455driver
10 May 2010
Do both trains stop at Tiverton Parkway?
That would be the same platform.
What day would be nice because we could look at the calling patterns.
louis97
14 May 2008
Derby
The 1207 from Manchester terminates at Exeter. Therefore if an easier connection is wanted changing at Tiverton Pathway if your ticket allows is what I would recommend this as it is same platform and both trains do call.
Furthermore should the train from Manchester run late and miss the connection. I would imagine the way forward would be continue to Exeter and take the following XC service to Plymouth and then take the 1755 from Plymouth to Penzance. The connection at Taunton Will not be held as there are later trains available.
Goatboy
23 Jun 2011
It would take a very very harsh member of traincrew to penalise you for chosing to change at Tiverton Parkway for accessibility reasons if these are Advance tickets. As mentioned above Tiverton will give you a guaranteed same-platform connection which you cannot miss.
