TASS, its purpose and and its future
are these such minor reductions from the Pendo speeds that they could be observed and obeyed by just reducing speed on sight of a restriction sign - or a warning sign - at a suitable distance?
TASS (Tilt Advisory and Supervision System, I think!) is more about preventing a tilting train hitting things as it tilts than about the speed. You could make one that wouldn't but it would be very cramped indeed, as indeed the APT was.
The speed part is purely about comfort (and luggage and drinks not flying everywhere) were the train not to tilt.
Tilting007
21 Oct 2024
Rugby
No - standard signs, drivers will need to know the locations of the changes.
TASS is more about preventing a tilting train hitting things as it tilts than about the speed.
Thats not quite right.
The TAD (Through Alignment Design) manages the ATG (Absolute Track Geometry) position. This confirms the train will safely pass structures and other trains. The position of the track is maintained by design tamping.
If there is a hard tilt failure of a 390, the signallers, controls, driver and everyone else involved will know what action is needed.
TASS purely confirms to the train what it should expect between each balise, that have a 40m tolerance from the exact location they should be. Normally no more than 5k apart although can be much closer.
It also manages the speed, although not in the same way as TPWS etc.
Carlisle
26 Aug 2012
It was also originally to ensure a 390 couldn’t go above 110 mph without the tilt activated .
The Bear
11 Sep 2019
Cumbria
TASS - Tilt Authorisation and Speed Supervision.
Correct, and 221s.
I think it'll have very little future beyond the life of the Class390s on the WCML, it's now 20+ year old technology.
I'm under impression that it's more hassle than it's worth, certainly where 221s are concerned.
The section that I think most perceive it to be the most beneficial is on the northern WCML, where even class350s (when they were operated by TPE) where matching and in some case's bettering the 390s performance.
Tilting007
21 Oct 2024
Rugby
The angle of tilt and rate of change through transitions is the passenger comfort part.
Russel
30 Jun 2022
Lichfield
It may just be perception, but the tilt on the 221s never seemed to be as noticeable as on the 390s.
Tilting007
21 Oct 2024
Rugby
Their angle of tilt was 6 degrees where a Pendolino tilts at 8 degees.
That is why some curves had a lower speed for a 221.
TASS (allowing 390/221 operation up to 125mph) was one of the features of the WCRM project that RT/NR/VT got absolutely right.
It might be "old" technology, but it works well - it was the only way to get a consistent 125mph on the WCML.
The sawtooth MU speed profile for 80x is the penalty for non-tilt stock.
Presumably HS2 trains will be subject to the same MU profile on the WCML, now that the notion of high speed by-passes north of Handsacre is in the bin.
We'll probably never know how the 390s would have fared if the specified 140mph with tilt had been allowed.
Tilt is in retreat outside the UK too, although Alstom's new Avelia Liberty trains in the US will tilt.
Sorcerer
20 May 2022
TASS/ Tilt will remain as long as the increased revenue from the faster services can cover the cost of maintaining it and the 390 fleet. The problem is that the UK specifies TASS as a requirement for tilt where continental loading gauge doesn't require it - at least in Italy/France.
This is part of why I don't expect any more tilting trains in the UK after the Pendolino reaches retirement. Once they stop making up the bulk of intercity traffic then TASS will be redundant, and tilting trains were already something we probably wouldn't have seen a continuation of anyway, especially with new MU profiles.
dk1
2 Oct 2009
East Anglia
I am still very impressed that we ever got TASS in this country and that it and the Pendolinos have proved their worth in reliability. It’s a credit to Alstom and Virgin Trains and that vision well over 20 years ago.
Russel
30 Jun 2022
Lichfield
Very true.
Also, in 20 years of using the WCML, I cant recall ever having a 390 fail on me, same goes for the 221s...
I know the Virgin brand was a bit Marmite like, but they ordered some solid trains.
dk1
2 Oct 2009
East Anglia
Very true.
It very did my friend and I fear we’ll never see the likes again. With so much to go wrong many (and not just the usual doom mongers) thought it would be a poisoned chalice but it has proved them wrong.
Russel
30 Jun 2022
Lichfield
They certainly had a vision for the future.
Even the 220/221s that transferred over to XC and have taken an absolute hammering every day for the last 15 years are still going strong, if looking a little rough around the edges.
Wilts Wanderer
21 Nov 2016
TASS may be specifically for tilting trains, but it provides overspeed protection for 125mph running as well. ORRs view is that removing a 221 (fitted) and replacing with a 80x (not fitted) was therefore a reduction in safety - however marginal - which is why the 80x have been unable to use the upgraded linespeed profiles specifically designed for them.
Its an argument based on technicality and nuance but it gives an idea of how it’s necessary to consider the widest picture when proposing a rolling stock change on a route, rather than rely on a narrow rules-based assumption (I.e. in this case, ‘TASS is for tilting stock and therefore not required for 80x.’)
This is going to be the difficulty on GWML when ATP reaches the end of its life as well - in theory 125mph running is perfectly safe without enhanced protection but the change from ‘having ATP’ to ‘not having ATP’ will similarly be seen as a deterioration of safety margin if there is nothing comparable such as ETCS to replace it.
RailWonderer
25 Jul 2018
All around the network
Is this just about cost, or are there reasons to consider the technology obsolete?
Faster acceleration and deceleration and shorter door open-close cycles on more modern rolling stock has reduced the need for tilt on regional and intercity lines around Europe as well. SBB deactivated their tilting Bombardier Twindexx IC and IR trains in 2022 despite taking delivery of the first ones in 2018.
The Western Swiss Transport Conference is therefore calling for a new, efficient infrastructure. The Geneva–Lausanne–Fribourg–Bern axis should be given top priority so that a sustainable solution for the expansion of the route can be found quickly.
It was a bit controversial over there as tilt was meant to reduce journey times, and Switzerland for obvious geographical reasons has a lot of curvy track, but they've deemed infrastructure upgrades and even building new bits of track is better than tilt.
Roast Veg
28 Oct 2016
Am I correct in saying that TASS uses eurobalises at track level? Would these be useful for a future ETCS installation?
DaveyJones
12 Mar 2023
At risk of too detailed an answer, both ETCS and TASS use the same type of Balise, but each Balise can/will have a data type, and if the train isn't looking for that type, it will ignore the message.
A prime example is Edinburgh Haymarket where there are ETCS Balises for Hitachi Units, TASS Balises for Avanti.
I don't know if Balises can have more than one message type?
One of the factors will be the new straight base tunnels, which wipe out many km of curving mountain track (Lötschberg, Gotthard, Ceneri etc), plus NBS lines like Ulm-Stuttgart-Mannheim and Frankfurt-Köln.
Vienna-Frankfurt remains tilt-operated with ICE-T for now, particularly for Wels-Passau-Nürnberg.
We actually haven't got the excuse of new infrastructure.
Arguably tilt should have been fitted to the MML and TPE routes as well, but non-tilt stock was ordered.
Brubulus
13 Oct 2022
Cambridge
The time benefit of tilt has always been quite small, and the costs it imposes quite large, long term. With some works, I do think HS2 trains will be able to keep to similar timings (maybe losing 1-2 mins) from Handsacre to Edinburgh/Glasgow as pendolinos on any given stopping pattern, given how the north WCML speed profile is less aggressive than the ECML.
HS2 predicted 3h56 to Glasgow under phase 1, with stops at Preston and Carlisle only.
23 Nov 2023
Grimsby
Don't get me wrong, I'm no fan of the IEP's, but the acceleration (on electric power) is another level. As @RailWonderer says that and improved braking allows faster timings without the complication of tilt equipment.
Unobrow
19 Nov 2024
Manchester
Commenting as a regular user of the 390 vs 805/7. I find the Pendo a very comfortable train to travel on thanks to the tilt. BR had it absolutely bang on with the APT theory, it provides a much more comfortable high speed travel experience than non tilt. I find any 110mph more uncomfortable through the same curves than a 390. It’ll be a massive retrograde step backwards in my view to lose this technology.
Id love to see the times of a 390 vs 807 on the same Glasgow-Euston run though as they do accelerate noticeably quicker.
nwales58
15 Mar 2022
notsure
It really varies outside the UK.
Bayern is ordering new tilting trains, multi-mode, for the Allgäu services replacing the 612s. Talgo’s offerings are still passive tilt though probably only wanted in Spain.
james_the_xv
29 Oct 2019
West Midlands
The good news is that 390s still have another 15 years left in them, so that gives the industry at least 7 years to come up with a replacement... right? right????
Russel
30 Jun 2022
Lichfield
Sounds too much like forward planning!
That said, if the replacement was due within the next couple of years, I'd say just do a bulk order for more 805/807s, the Avanti IET's seem really nice, in comparison to the GWR units.
bahnause
30 Dec 2016
bülach (switzerland)
That is not entirely correct. The TWINDEXX do not have tilting technology, but WaKo (roll compensation). This is technically a completely different system and is only designed for a very limited tilt of two degrees instead of eight degrees. Tilting technology would also not be feasible for a double-decker train.
Neither Bombardier nor Alstom have managed to put this system into operation with acceptable ride comfort and reliability. The system has not been switched off, but the higher speeds are not used. When the system is switched off, ride comfort is even worse and there are operational restrictions.
Travel time reductions are not being implemented. Infrastructure investments have not yet been decided.
The 807 would lose by a fair margin if you talking about the Trent Valley service.
Pendomonium
24 Aug 2024
Tring
On a delayed Up Liverpool service, this is where a 390 really claws back time from the 80x friendly timings. Especially on the 80x "corridor of death" through Stafford.
Not entirely. With tilt isolated a Pendo could go as fast it could get, when originally introduced. In fact im sure even with the initial TASS software, there wasnt much of an upper limit ! With TASS active there were areas of plus 110mph tilt inhibited running, mainly due to tight load gauges. It was only in fairly recent memory that the Train Management System software was altered to give a warning when operating at 113mph non tilt & when creeping above 127 in tilt. There has been so much fettling in the years since introduction, the memory gets a bit fuzzy.
Carlisle
26 Aug 2012
Something similar might’ve been achievable with the 390s had their 140 mph capability been fully exploited.
Brubulus
13 Oct 2022
Cambridge
Something similar might’ve been achievable with the 390s had their 140 mph capability been fully exploited .
3h56 to Glasgow is entirely possible today with 390s, just with no stops, no TSRs and no allowances whatsoever. 140 would have enabled a couple minutes to be saved, but not enough to get even a routine nonstop London-Glasgow under 4h, with the normal allowances. 125 isn't possible for a 390 on much of the northern WCML.
