Tap in, tap out...
Western Sunset
23 Dec 2014
Wimborne, Dorset
Was visiting London's northern termini (Padd , Marylebone, Euston , St Pan and KX) on Saturday and noticed all now have gatelines except (I think) Padd plat 1 and the high-numbered platforms at Euston when Avanti staff aren't around. What would happen if I tapped-in with my contactless card at say KX to access the platforms, trainspotted for an hour or so, then tapped-out again without travelling anywhere? Would I be charged a min/max fare?
Likewise if I tapped-in at an intermediate station (say Iver), spent an hour or so on the platforms and tapped-out, would I receive a max fare?
Just a wondering...
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
TfL said:
Same station exits
If you touch in when you enter a station and then touch out to exit it within a short period of time, you'll be charged a same station exit charge. These are:
  • Between 0 - 2 minutes: a maximum fare. If you re-enter the same or a different station within 45 minutes, you'll be refunded. This doesn't apply if you take a bus or tram before re-entering a station
  • Between 2 - 30 minutes: the minimum pay as you go fare from that station
  • More than 30 minutes: two maximum fares. We'll assume two separate journeys have been made and both will be incomplete
We apply these charges to discourage fare evasion.
Source: https://tfl.gov.uk/fares/pay-the-right-fare#on-this-page-3
WelshBluebird
14 Jan 2010
I do find it interesting (and not great for the passenger) that some of the different schemes in place have different rules around this.
TfL (as above) charge you a max fare, but GWR in their payg schemes in Bristol and Cornwall do not charge you if it is less than 30 minutes between the tap in and tap out.
I guess it is because TfL assume you would still travel when your intended train is cancelled due to how frequent services in London usually are, but out West a train being cancelled after you have tapped results in a higher chance you will just abandon your journey. But the same could be said for some of the less frequent services in the Oyster / Contactless area too!
18 Mar 2007
North Oxfordshire
I found it much more civilised in the Netherlands. Tap out within 60 minutes of tapping in and you get no charge.
Means you can still access shops/facilities etc behind the gatelines, and use the station as a through pedestrian route where it makes sense to do so.
If your plans change and you decide not to travel, or use an alternate mode, no need to chase for a refund.
