SWT Class 158/8 Diagrams
30 Dec 2009
Hi I am visiting Devon for 2 weeks in July and will be spending a couple of days at Salisbury and taking a trip to Lymington Pier, im wanting to see as many of the 158 units as possible. Please can anyone shed any light on which other services use SWT 158s, ive listed the ones below which I know of:
3x 158 units work Salisbury - Romsey via Southampton services.
1x 158 on loan to FGW for the Golden Valley services.
1x 158 works the Lymington Pier services.
which other services out of Salisbury are booked to have 158s attached to them.
cheers in advance.
455driver
10 May 2010
A few are used to strengthen Peak services to and from Waterloo (the 8 and 10 coach trains to/from Salisbury), in between they are stabled on Salisbury depot.
One works a 17 something or other train from Exeter to Axminster, I am not sure what it does before or after that.
TEW
16 May 2008
I believe these are the 158 diagrams, they're quite hard to work out now because a few trains have been, or will be replaced by EMUs.
Diagram 1
Lymington Branch
Diagram 2
5L18 0618 Salsibury Depot-Salisbury
1L18 0550 Yeovil Junction-London Waterloo (from Salisbury)
1L19 0850 London Waterloo-Salisbury
5L19 1026 Salisbury-Salisbury P1
5L85 1059 Salisbury P1-Salisbury Depot
5E91 1311 Salisbury Depot-Fratton Depot
5T92 1622 Fratton Depot-Portsmouth Harbour
2T92 1649 Portsmouth Harbour-Eastleigh
5T92 1738 Eastleigh-Eastleigh Down Sidings
5T75 0023 Eastleigh Down Sidings-Eastleigh
2T75 0030 Eastleigh-Portsmouth Harbour
5T75 0115 Portsmouth Harbour-Fratton Depot
Diagram 3
5E18 0439 Fratton Depot-Totton Yard
5R18 0605 Totton Yard-Totton
2R18 0614 Totton-Romsey
2S11 0707 Romsey-Salisbury
2R30 0815 Salisbury-Romsey
etc
2R99 2258 Romsey-Romsey
5S99 2350 Romsey-Salisbury Depot
Diagram 4
5S97 0516 Salisbury Depot-Salisbury
2S97 0535 Salisbury-Salisbury
2R26 0750 Salisbury-Romsey
etc
2S67 2107 Romsey-Salisbury
5S67 2246 Salisbury Depot-Salisbury
Diagram 5
5E91 1311 Salisbury Depot-Fratton Depot (to Salisbury P1)
5L52 1503 Salisbury P1-Salisbury
1L52 1325 Exeter St Davids-London Waterloo (from Salisbury)
1L53 1720 London Waterloo-Exeter St Davids (to Salisbury)
5L53 1904 Salisbury-Salisbury Depot
5L98 0108 Salisbury Depot-Salisbury
Diagram 6
1L12 0515 Salisbury-London Waterloo
1L13 0710 London Waterloo-Exeter St Davids (to Salisbury)
5L28 0850 Salisbury-Salisbury
1L28 0725 Exeter St Davids-London Waterloo (from Salisbury)
1L29 1120 London Waterloo-Exeter St Davids (to Salisbury)
5L29 1250 Salisbury-Salisbury Depot (ThFX)
5L29 1310 Salisbury-Salisbury Holding Siding (ThFO)
5L48 1359 Salisbury Holding Siding-Salisbury (ThFO)
1L48 1225 Exeter St Davids-London Waterloo (ThFO) (from Salisbury)
1L49 1620 London Waterloo-Exeter St Daids (ThFO) (to Salisbury)
5L49 1759 Salisbury-Salisbury Depot (ThFO)
5L93 2232 Salsibury Depot-Salisbury Holding Siding
Diagram 7
5R22 0616 Salisbury Holding Siding-Salisbury
2R22 0650 Salisbury-Romsey
etc
2S75 2307 Romsey-Salisbury
5S99 2350 Romsey-Salisbury Depot (from Salisbury)
Diagram 8
FGW Hire-In
There used to be another diagram working over electrified lines, but as far as I can tell that is now covered by a 450 in the morning and 159 in the evening. The 1746 Exeter St Davids-Axminster isn't booked a 158 but has quite often been a 158 since the electric diagram ended.
Matt Taylor
31 Aug 2008
Portsmouth
That would be:
5T06 0550 Fratton-Eastleigh
2T07 0702 Eastleigh-Portsmouth
2T28 0805 Portsmouth-Eastleigh
I worked it this morning and it is now a 4 car 450.
The afternoon working is the 1624 Basingstoke-Portsmouth which has gone from 3 159 to 4 450.
TEW
16 May 2008
I thought that was the case. And therefore the 1638 Winchester-Totton is now a 159 instead of a 158.
455driver
10 May 2010
They will make their mind up what is working that train one day!
When I started it was a 170 (from Reading to Brighton)
Then it was a 6x159 (to Portsmouth)
then a 450
then a 3x159
and now back to a 450!
nw1
9 Aug 2013
Presumably that is the one which forms the 1818 Southampton-Winchester and preceding inbound working to Southampton (I guess it goes ECS Totton to Winchester then forms a down Winchester-Southampton service) which stops St Denys around 1800? I quite often see that as it coincides with coming home from work and has been a 159 certainly since autumn 2011.
Strangely this one is advertised standard class only. Why is this? Plans to convert to one of the "standard only" 450s used on the Windsor lines, etc, at some point in the future?
SWT intend these and a few other 'Hampshire locals' as peak extra capacity for busy flows such as school or college finishing times etc, in a web chat a few months back they said that it is better to use the capacity for standard only.
For info, the 'standard only' 450/5s have all been returned to 'near normal'. (There are still a few standard seats less than a 450/0.)
Is the 0751 from Southampton Central to Portsmouth Harbour now worked by a 450 instead of a 159?
I haven't seen any change recently. RealTimetrains still seems to have it running up to Salisbury via platform 3 after the return service gets back to Southampton at around 1035 or so, with the next departure to Portsmouth leaving from platform 1 as now.
It still seems to be the same after the timetable change as well.
Drsatan
24 Aug 2009
Land of the Sprinters
That's odd, RTT shows it's still timed for an EMU, and the 1007 Romsey to Salisbury still has a nine minute wait at Southampton Central (presumably for the 159 to join).
As always, the timing doesn't actually mean it must be operated by an EMU. It might not have even been changed since it was last operated by a 450.
nw1
9 Aug 2013
Not sure if it's the same working as the 0751, but the Portsmouth to Southampton which arrives just after 1030 is definitely still a 159, or was in April (April 8 IIRC), I remember seeing it advertised as a through Salisbury service at stations between Southampton and Portsmouth.
Yes it is, that's the return working of the same unit, and why I referred to it as arriving at 'about 1035' (actually 1038) a few posts ago...
As a peak version of the normal Portsmouth Southampton stopper it runs a bit later than the normal xx44 on the way down to Portsmouth Harbour, arriving at 0857, and departs at 0933. So it has that 36 mins dwell time at the south end of the route, rather than the normal 55 minutes...
Just following this up - as of now (1009 Monday) National Rail LDBs showed it calling at Swanwick as a through service to Salisbury. But with their fairly usual error of noting it as splitting at Southampton Centrtal with a portion going to Salisbury. They often seem to mistake joining for splitting on LDBs...
