SWT have introduced a new UO restriction code to many off peak day and period return tickets
The UO code is valid Out after 0930 and back after 1000.
In the case of Exeter to East Croydon route Honiton Not London it was US which is arrive after 1000 and depart after 0900 (+0820 allowed)
That means before you could travel out using the 0641 now you can't travel till 1026. Return you could travel from Clapham on the 0827 now you can't travel till the 1027.
This UO code seems to be used for many fares from numerous SWT stations to stations between London and East Croydon.
They have also changed many other tickets to UU which is also more heavily restricted.
Apparently the May fare change is now worse than January. You can get around this change by buying tickets beyond East Croydon or splitting en route as by doing this you normally get the normal US or UT restriction codes. Does anyone know why have they targeted just these few stations with such draconian and COMPLETELY unpublicised additional travel restrictions?
