SWT - Alternative commuter map
waterboo
24 Jul 2013
Hi guys, I currently have an unfinished SWT alternative commuter map that I have made.
Red represents services diverging to Wandworth Town and green is for services via Earlsfield.
Black is for services through both destinations.
Any comments will be appreciated.
bb21
Emeritus Moderator
4 Feb 2010
I think you may need to stick the stations names into the map which would make things much easier for others.
I *think* I know what the map shows, but can't be sure without the station names.
455driver
10 May 2010
You might want to move the 2 legs for the Shepperton branch to the left a bit as they divert near Strawberry Hill not Twickenham, that would also make it look like a proper branch and not just 2 other services on the Windsor side.
bb21
Emeritus Moderator
4 Feb 2010
Also what is it that you are trying to show? Is it service frequency? Is it service pattern? Is it stock allocation?
waterboo
24 Jul 2013
Yep, I just wanted to vectorise the image, then I can add the station names, and hopefully it would be readable.
Good point actually, yeah I will move them.
It shows the individual services of trains, instead of just a large map.
455driver
10 May 2010
Its a good start but a few questions if I may-
What are the 2 black routes that go across the top, I am not familiar with them?
You are showing 4 lines (stations) at the bottom, the only shared stations are Waterloo, Vauxhall and Clapham jn where the lines diverge. Queenstown Road is only on the Windsor lines.
waterboo
24 Jul 2013
Hi 455 driver :)
- I do apologise, Queenstown road was purely a mistake, I will correct that.
- Correct me if im wrong, I have never had time to see, but I was under the assumption that SWT services to Addlestone (Weybridge) return to waterloo via Walton on Thames and Berrylands.
Many thanks!!
Seeming that Ive got a whole Sunday free, I can do this to my hearts content!!!!!
455driver
10 May 2010
No need to apologise its a good start.
Weybridge services are all routed via the Hounslow loop and not direct up the Windsor side and they terminate in the bay at Weybridge and return back to Waterloo via Virginia Water and Hounslow. The stopping trains through Weybridge run to/from Woking (with some extended to/from Guildford.
The last service terminates in Platform 2 (up slow line) but then runs empty back to Wimbledon Park depot.
Windsor services run direct up the Windsor main lines and not via the Hounslow loop.
These help form the semifast services with the Reading services.
It might be worth adding the Chessington, Epsom and Dorking services off to the left as well but it might make it a bit complicated.
Hope that helps, it is still a good map and quite easy to follow and I am looking forward to seeing this develop.
waterboo
24 Jul 2013
Thank you very much - enough there to keep me busy and content.
455driver
10 May 2010
I have tried to think of everything that you could usefully put on the map without it appearing that I am berating it, thart most certainly isnt my intention.
Sorry to add more but-
What about the Guildford via Cobham and via Epsom services that join up at Effingham jn and then join up with the via Woking services at Guildford.
Also the Dorking services that diverge from the Guildford via Epsom services at Leatherhead.
From the mainline-
The Chessington, Dorking and Via Epsom services all diverge (to the left) at Raynes Park.
The Chessingtons then diverge (to the right) at Motspur Park.
That is all I can think of for the normal weekday peak, promise. ;)
waterboo
24 Jul 2013
From the mainline-
Affirmative, currently adding some branding to it, but I will be sure to send you a copy nearer to completion, many thanks!
bb21
Emeritus Moderator
4 Feb 2010
What is the big loop? Is that the Kingston Loop?
455driver
10 May 2010
The one in the middle is yes, the top one is via Weybridge and Virginia Water but is going to be altered.
Edit-
Just seen another one (sorry), I see you have got the Raynes Park starter on there so adding to this, in the evening there are a couple of fast trains from Waterloo to Surbiton only so you could add them if you want (or leave them out if its too much).
waterboo
24 Jul 2013
Sorry 455 driver, I have not yet made the line and station adjustments, but I have just worked on a few design elements first.
I know the oyster zoning is wrong, but I don't have a map handy atm so will correct tomorrow.
Trust me I will not ignore your ideas atall!!!!!
455driver
10 May 2010
Stop apologising, there is a lot of work and time you have put into this already.
Cant help you with Oyster as I dont use it on our network, sorry.
I am sure there are many people on here that can help you with that though.
bb21
Emeritus Moderator
4 Feb 2010
I see, but then is Shepperton not on there?
Hang on, I think I have it.
Shepperton is not shown as the end of the line on there I guess.
455driver
10 May 2010
The Shepperton route is there but it is beside the Windsor lines, Waterboo is going to move the Shepperton line to the left a bit to make them clearer.
hassaanhc
5 Jan 2014
Southall
For the Oyster area use this map: http://www.tfl.gov.uk/assets/downloads/oyster-rail-services-map.pdf:
In general, boundary stations are:
Feltham (Hounslow/Reading/Windsor lines)
Hampton (Shepperton line)
Surbiton (Main Line; Woking via Weybridge and Guildford via Cobham stoppers)
Epsom (Dorking line and Guildford via Epsom stopping service)
The whole Chessington South and Hampton Court lines
Of course all stations in the "up" direction from these have Oyster valid.
berneyarms
26 Nov 2013
Dublin
You need to remove the ":" at the end of your link as it's not working.
It should be:
SWT used to (before the 2004 timetable major re-write) do this map, seems exactly what you are trying to achieve.
  • suburban.pdf
waterboo
24 Jul 2013
Hey guys, I have made some updates, im hopefully getting there - see the attatchment below.
I am going to pretend that I have never seen this :oops:
bb21
Emeritus Moderator
4 Feb 2010
I think the revised design is very good. Personally I would prefer that a few more 45 degree lines are used so that what is effectively two branches coming out of Waterloo are shown as such, but that is not a major problem.
greatkingrat
20 Jan 2011
You have missed off Whitton station. Also I think you need to indicate that the service to Shepperton via Richmond are peak-only.
