Sounds like Derby - Sheffield is ungated.Did a similar thing happen at one of the EMR stations (Derby or Sheffield?) A few years ago? IIRC the TOC backed down in the end.
Pedestrian access of Guildford Station footbridge is to be withdrawn on a trial basis starting in December.
South Western Railway (SWR) and Network Rail will temporarily withdraw pedestrian access across the footbridge for three months between Monday, December 4, and Friday, March 1, 2024.
The trial follows anti-social behaviour towards station staff by fare evaders over many years. It will be used to collect data before SWR and Network Rail apply to permanently withdraw access later next year.
Currently, pedestrians are permitted to use the footbridge as a walking route between Station Approach and Guildford Park Road. Until recently, they were provided with a paper “bridge pass” that allowed them to enter and exit the station via the footbridge.
It's not a public right of way but a Section 52 agreement.I would have thought it might be possible to divert one of the Platform 1 or 2 staircases to lead out of the station via a new exit into the car park area, and then retain all other platform access staircases with locked doors for crew use. That would retain simple access for staff, maintain the public right of way and allow a reasonably easy transit from the bridge exit, along the station frontage and to the entrance.
It’s worth pointing out that SWR are happy to operate Basingstoke in this way, whereby outside of the peaks anyone arriving on the car park side of the station has to transit via a cramped staircase and subway to the other side of the station, so the there is a precedent for similar arrangements.
The crossing to the car park has been improved to make it better for disabled people and the visually impaired. That happened this year, when the final traces of the start of the old access road down to the Guildford Motive Depot were removed.It's already pretty crowded there though. However I imagine not that many people actually used the footbridge pass to cross the footbridge, given that there is the road nearby, so maybe it won't lead to much of an increase in foot traffic. Wouldn't surprise me if nearly everyone getting a footbridge pass was actually just a fare dodger!
What really needs sorting is the junction and crossings to the south of the carpark/main entrance on the east side of the tracks, it's absolutely lethal trying to not get hit by a car/drivers having to dodge a stream of uni students! If they expect everyone to use Farnham Road then something surely needs to be done to the crossings...
They could simply be made to trek around, as pedestrians will have to do and even customers unless it is manned 20 hours a day.The Guildford traincrew depot is accessed via the bridge so that would make it a bit of a trek to get to and from the platforms.
I have not come across this happening at any SWR station but it does happen at Govia Thameslink Railway stations.It wouldnt need to be staffed, lots of examples elsewhere where secondary exits are gated and controlled remotely.
It takes at least an additional 5 minutes to reach platform 8 when the back entrance is closed.
Guildford Borough Council or it's successor mst well have very different views particularly if it was a condition of planning.... Me learned friends could be out to play....The article states
The requirement to allow pedestrians to walk through the station and over the bridge was introduced following a planning agreement between the British Railways Board and Guildford Borough Council in 1988
I assume SWR believe that agreement can be terminated
Nottingham and Sheffield are the ones most often mentioned.Did a similar thing happen at one of the EMR stations (Derby or Sheffield?) A few years ago? IIRC the TOC backed down in the end.
I can't see much incentive for the local authority to approve the permanent closure. Presumably SWR are free to put additional RPI's at the bottom of the steps on the platform if they feel that strongly about it.
No, it was Sheffield that EMR couldn't get gated. LNER had a similar problem at York.Sounds like Derby - Sheffield is ungated.
This is not correct.Re 1., if the Local Authority refuses permission to vary the obligation, they could also appeal to a planning inspector (formally the Secretary of State).
The local authority doesn’t get the final say on the matter. Hence the possibility of an application to the Lands Tribunal under section 84.Guildford Borough Council or it's successor mst well have very different views particularly if it was a condition of planning.... Me learned friends could be out to play....
Crowthorne, Sandhurst, Blackwater, Farnborough North, North Camp, Ash, Wanborough, and every station from Shalford up to Reigate ungated.As for the North Downs Line, Shalford, although that is further out in the borough.
If commitments made to gain planning permission are as easy to get out as you imply then they are totally worthless.This is not correct.
So only rail passengers matter huh? Conditions of planning permission should never be easily broken.I support them closing the bridge to non rail users.
There have been proposals for a new separate pedestrian bridge for years but funding is the usual issue...
The closure doesn't affect train travellers, can't really see what the problem is?
Godalming up platform has an entry and exit gate remotely controlled from the down platform gate line. That has been in use for two or three years.I have not come across this happening at any SWR station but it does happen at Govia Thameslink Railway stations.
That isn't to say it couldn't happen but they would need to install equipment to make it possible and change working practices.
I understood it was a s52 planning obligation, the forerunner to s106 of the Town and Country Planning Act. The Government’s Planning Practice Guidance advises at Paragraph 020 that:This is not correct.
Can confirm, it's noisy cramped, smelly and overall, very unpleasant to walk through. The station's bridge is far more appealing and inviting.I mentioned this to my mum, who is in her 80s and she said Farnham Road Bridge isn't nice or as safe. She doesn't enoy that route.
Playing devils advocate, surely they would just need to arrive earlier. Like people tell passengers. Of course if they are taking a rest break between services in a shift this doesn't work.Your first point very much points out the issue with the second, which was your response to the post from @lxfe_mxtterz:
Train crew being “made to trek around” would mean more time needing to be allowed in diagrams for this, which in turn costs money!
Well, my mum who is in her 80s doesn't like it and I doubt she is alone. My mum isn't a frequent user of it either, which may partly lead to this. Regular users might get used to it.Am I missing something? You dont walk through the Farnham Rd bridge across the railway, you walk across it. I’ve never had any problems with it personally, even as a kid.
The BBC didn't quote their views but the Guildford Dragon, which is better for local news but alas not mobile-friendly had thisGuildford Borough Council or it's successor mst well have very different views particularly if it was a condition of planning.... Me learned friends could be out to play....
https://guildford-dragon.com/pedest...bridge-to-be-withdrawn-for-three-month-trial/Local Lib Dem ward councillors seemed more sympathetic with SWR’s position. In a joint statement they said: “Antisocial behaviour causes significant harm to railway staff and makes rail journeys for the travelling public deeply unpleasant. The trial closure is a reasonable step in gathering evidence to address this issue. However, residents are rightly concerned, particularly with respect to the safety of alternative pedestrian routes and the potential for increased traffic around the station.
“As local councillors, we will be monitoring the trial closely over the coming months and will be very interested to see the results.”
And their party colleague, Tom Hunt, who has the lead responsibility for Transport at Guildford Borough Council, was even more supportive of the trial. He added: “SWR has shared evidence of the anti-social behaviour (ASB) being directed towards their ticket gate staff by individuals claiming to be accessing the station using bridge passes.
“The level of this abuse is completely unacceptable, and I am consequently supportive of a trial to identify to what extent closing the footbridge to non-travel-ticket holders stems the flow of ASB.
“I am disappointed that the actions of a small minority will impact the decent majority of residents.”
Perhaps they need to close the bus station. The bus station is awful.Social incidents in the Friary bus station, drivers being abused etc.
In recent years the growth of the Royal Surrey Hospital & Surrey University have meant increased bus use picking up/dropping off at the back of the station and it is much busier than it used to be a few years ago.
It is very easy to say to the bloke on the gate (usually agency staff) 'I am just walking over the bridge' and then board a train.
The station has always been a 'bit lively' on Friday/Sat eves/nights with BTP often present.
I'm surprised such a thing hasn't been installed at Guildford then.Godalming up platform has an entry and exit gate remotely controlled from the down platform gate line. That has been in use for two or three years.
Whilst I appreciate the abuse on the flip side I doubt it could be claimed the footbridge no longer serves a useful purpose because it does.I understood it was a s52 planning obligation, the forerunner to s106 of the Town and Country Planning Act. The Government’s Planning Practice Guidance advises at Paragraph 020 that:
Can an agreed planning obligation be changed?
Planning obligations can be renegotiated at any point, where the local planning authority and developer wish to do so. Where there is no agreement to voluntarily renegotiate, and the planning obligation predates April 2010 or is over 5 years old, an application may be made to the local planning authority to change the obligation where it “no longer serves a useful purpose” or would continue to serve a useful purpose in a modified way (see section 106A of the Town and Country Planning Act 1990).
And at paragraph 22 that:
Can there be an appeal against a refusal to change a planning obligation (Section 106 agreement)?
An appeal to the Planning Inspectorate under section 106B of the Town and Country Planning Act 1990 must be made within 6 months of a decision by the local authority not to amend the obligation, or within 6 months starting at the 8 weeks from the date of request to amend if no decision is issued. The Secretary of State also has the power to allow appeals that are out of time.
The pavement is sufficiently narrow that it's often necessary to step into the road to pass a group coming the other way, or even to pass mothers with baby buggies and/or children. For much of the day there's a near permanent stop-start traffic queue heading onto the one-way system. It's certainly not a pleasant walk, and the continuation down Bridge Street isn't much better. Having crossed over the station footbridge, that can be avoided by taking the footbridge over the river towards the Odeon and going into the town centre that way.Am I missing something? You dont walk through the Farnham Rd bridge across the railway, you walk across it. I’ve never had any problems with it personally, even as a kid.
All true but the the station bridge/walkway has stairs at both ends by the Guildford Park Rd entrance and down to platform 2 so it's not exactly friendly to anyone with mobility issues.The pavement is sufficiently narrow that it's often necessary to step into the road to pass a group coming the other way, or even to pass mothers with baby buggies and/or children. For much of the day there's a near permanent stop-start traffic queue heading onto the one-way system. It's certainly not a pleasant walk, and the continuation down Bridge Street isn't much better. Having crossed over the station footbridge, that can be avoided by taking the footbridge over the river towards the Odeon and going into the town centre that way.
You might very well think that. I couldn’t possibly comment.If commitments made to gain planning permission are as easy to get out as you imply then they are totally worthless.
Section 84 applications do not go to the First Tier Tribunal at all. They are directed to the Lands Tribunal which, in England, forms the Lands Chamber of the Upper Tribunal.The "Land Tribunal" - formally the "First Tier Tribunal (Property Chamber)" - is one of the seven chambers of the first tier legal body i.e. it is a form of Court. Its decisions can be appealed at the "Upper Tribunal (Lands Chamber)" i.e. a second tier legal body. How exactly are me learned friends not going to get involved?
A section 52 agreement is not a ‘planning obligation’ for the purposes of section 106A so there is no ability to vary or discharge it by this route and no right of appeal to the Secretary of State.Can an agreed planning obligation be changed?
Perhaps pressure ought to be brought on the local authority to improve the situation then, rather than relying on an obviously unsatisfactory arrangement with the railway.The pavement is sufficiently narrow that it's often necessary to step into the road to pass a group coming the other way, or even to pass mothers with baby buggies and/or children. For much of the day there's a near permanent stop-start traffic queue heading onto the one-way system. It's certainly not a pleasant walk, and the continuation down Bridge Street isn't much better. Having crossed over the station footbridge, that can be avoided by taking the footbridge over the river towards the Odeon and going into the town centre that way.
I've seen staff doing checks right at the bottom of steps at more than one station, and IMHO it's dangerous. You get people piling up coming down the stairs while fumbling with wallets, pockets and bags rather than looking where they're walking, it's an accident waiting to happen.Did a similar thing happen at one of the EMR stations (Derby or Sheffield?) A few years ago? IIRC the TOC backed down in the end.
HM Courts and Tribunal Service would disagree with you over the status of First Tier and Upper Tier Tribunals.You might very well think that. I couldn’t possibly comment.
As this body is not a court, there is no requirement to retain counsel or solicitors, although that is of course fairly common practice.
They are administrative tribunals (which is to say, executive bodies), not courts, even though the work they undertake is in practice very similar to that carried on by courts.HM Courts and Tribunal Service would disagree with you over the status of First Tier and Upper Tier Tribunals.
Tribunals - Courts and Tribunals Judiciary
Find out more about the specialist courts that make up the Tribunalswww.judiciary.uk
"The tribunals are specialist courts whose judges and members hear a wide range of cases, such as tax, employment, and immigration and asylum. The Upper Tribunal and Employment Appeal Tribunal hear appeals challenging some tribunal decisions."
Perhaps the railway could fund a second footbridge, rather than trying to change a long standing arrangement to the detriment of the general public.Perhaps pressure ought to be brought on the local authority to improve the situation then, rather than relying on an obviously unsatisfactory arrangement with the railway.
From an outsiders point of view, it doesnt look like that much of a diversion via Farnham Rd. Surprised it hasnt been done before this
Indeed. Rather than paying for the cost of employing sufficient people to improve security, or building a new bridge, it wants to "have its cake and eat it".Perhaps the railway could fund a second footbridge, rather than trying to change a long standing arrangement to the detriment of the general public.
The problem is part of a much wider issue of pedestrian *and* vehicular traffic, and the interaction between them, in that part of the town. Farnham Road, Bridge Street, Onslow Street and the one-way system are all inadequate for current traffic levels and see congestion throughout the day. The last significant improvement was decades ago (1980s?) when the "new" westbound road bridge* was built so that the High Street bridge could be closed to traffic. At around that time the two pedestrian subways were built under Park Street to improve access to the centre, but the route onward is too convoluted and they've never been popular or seen much use.Perhaps pressure ought to be brought on the local authority to improve the situation then, rather than relying on an obviously unsatisfactory arrangement with the railway.
Thanks, that’s interesting. I’d assumed s106 just replaced s52 but you’re right, it can’t be varied in the same way as an newer s106.You might very well think that. I couldn’t possibly comment.
Not going to happen. Locally it is believed GBC is (allegedly) fast heading the same way as neighbouring Woking BC has gone.....Perhaps a joint funding basis from NR/SWR and Guildford Borough Council
