SWR timetable refresh - consultation in Autumn 2026
London Trains
9 Oct 2017
southern used to run peak time services to Guildford plus the 2tph via Epsom and cobham
I could be wrong, but I'm fairly sure each Southern service to Guildford was reciprocated by an SWR service terminating at Effingham Junction.
moley
12 Jun 2011
Happy to be wrong but that wasn’t my recollection for most of the 2010s when I commuted to London Road. Admittedly it may have only been one hour which maxed out at 6 stopping plus two fast Pompey directs.
London Trains
9 Oct 2017
Seems we're both right - looking at the May 2019 timetable, there seems to be some occasions where a Southern service to Guildford results in an SWR service terminating at Effingham Junction, and other occasions where both services run through to Guildford.
Theoretically it should be easier to path Portsmouth services via Clandon now (even if 2tph Guildford via Epsom is rightfully restored), as there aren't any Southern services that way.
Recessio
4 Aug 2019
As a London Road resident, I would love to see more trains on the New Line. Getting Guildford via Epsom to 2tph would be fantastic.
moley
12 Jun 2011
I had forgotten that Southern no longer run through to Guildford. Should make pathing easier. In which case, I’d support routing 2 tph fast services that way. Push the stopper and the Haslemere terminator via Woking. Provides lots of opportunities for Pompey Direct folk to get to Woking, and anyone from Pompey itself still has a direct service via Eastleigh.
Side note, the service via Eastleigh stopped at both Surbiton and Wimbledon pre 2004 outside of the peaks from memory.
There was a period when it was treated as an extension of the Basingstoke stopper, broadly coinciding with when the Reading to Brighton service ran.
London Trains
9 Oct 2017
Absolutely. Its notable that passenger numbers between Guildford and Epsom have actually increased since 2019/20, despite the fact that the frequency has been halved, and I suspect there is quite a lot of untapped demand (I know for a fact there is some) because of the poor frequency.
Good connections between the Guildford via Epsom services and the London Bridge to Epsom services also need to be restored, which existed until SWR halved the frequency of services via Epsom.
boiledbeans2
15 Oct 2020
So, the latest DfT figures include 2 Pompey Direct services and 1 Alton line service in the top 10 most crowded services yet SWR management deny there is a need to strengthen services. These services are booked 10x444, 10x444 and 12x450 so maximum formations.
My bold. A polite reminder that this is the exact same scenario that the previous SW incumbent was faced with on the Pompey direct, but got slated for trying to deal with the issue by increasing certain over crowded services to the true maximum of 12 car 450. One should be careful what one wishes for!
Pompey direct users complaining about 12.450?
Send them the 10.701! It's fine, they have toilets.
moley
12 Jun 2011
No one was moaning about rolling stock. More a comment about it not being possible to run as 15.444 or 16.450. Presumably it’s a 444 service because there isn’t a bunch of spare 450s sat round idle. There are more 444s available than what are needed for the Weymouth’s - they have to be used somewhere.
swr444
26 Aug 2008
12x450 is only 10 metres longer than a 10x444. So there’s not much difference apart from the seating capacity. Pompey direct users prefer a 444 over a 450 as it’s less cramped
HamworthyGoods
15 Jan 2019
Unless the train is very busy; 444s are far less suited to standing in than 450s.
moley
12 Jun 2011
All users prefer a less cramped train. I used to know people who specifically aimed for the shoulder peak 444 service to Alton that used to run.
As I have said to others, the real issue was an expectation set many years ago by senior management that should not have been.
Passengers will make a choice where they can but they much prefer trains which reliably run over which stock is used.
A lot of those who made the original noise no longer commute. It largely is a matter of forum legend now.
Cookie10
26 May 2026
Farnham
I must be imagining the number of full & standing reports from the Waterloo - Salisbury trains...
Yes you are correct in this statement, however this is because these services are formed of 3 car services. If you look at total passenger numbers, London-Salisbury is one of the least used services on the mainline network.
