SWR smartcard/underground etc
Lifelong
1 Apr 2019
Evening all
I am shortly to take a job in zone 2 in London. My commute will be from Cobham to Earls Court (so not zone one, usually) via Wimbledon.
The last time I had a season ticket was a long time ago, and I am trying to work out benefits and not of the smartcard system on SWR/interoperability with the underground etc. In fact I'm getting pretty confused with the best ticket for the above journey full stop (in my previous life, I just got a season to London Terminals, no tube etc, so much simpler).
Any help gratefully received...
Cheers
MikeWh
15 Jun 2010
Crayford
The ticket you want is a Cobham to Zones 2-6 travelcard season route "Any Permitted". There is a more expensive version which can also be used at Weybridge (route "AAA Weybridge") but only get that if you'll use it. You can also travel via Clapham Junction and West Brompton using that travelcard which may be helpful.
Joe Paxton
12 Jan 2017
An annual Cobham to London Travelcard zones 2-6 is £2,972.00.
An annual Cobham to Wimbledon season is £2,092.
Peak single journeys between Wimbledon and Earl's Court are £1.70 each, so say 49 weeks of travel (assuming a commute each weekday) would cost £833.
The zones 2-6 Travelcard is probably worth it for the added flexibility.
[Edit - MikeWh pipped me to the post!]
Belperpete
17 Aug 2018
They should be all interoperable now.
So, given the advice seems to be to get a Cobham to Zones 2-6 travelcard season, would the OP be best getting it loaded onto an Oyster card or onto a SWR Smartcard? I suspect it would be best on an Oystercard, as that would make it easier for him to travel to other destinations, such as if he wanted occasionally to travel from Cobham to a zone 1 station?
bb21
Emeritus Moderator
4 Feb 2010
Cobham is not in the Oyster area.
Lifelong
1 Apr 2019
Thank you for your responses. I will get the Z2-6 travelcard season. Are there any advantages/disadvantages of Smartcard v paper ticket (aside from the practicalities of ticket barriers)? Cheers
Surreytraveller
21 Oct 2009
The problem with a Smartcard is you've got no evidence on your person that you've got a valid ticket should the Smartcard be defective. You don't need to do any swiping at Wimbledon, only at Earls Court (don't know about Cobham). So, if the price is the same, I would personally play it safe with a paper ticket.
K.o.R
6 Dec 2017
In this case you're in the Gold Card area, so an annual smartcard season ticket will come with a Gold Record Card that, while technically not valid as a ticket in and of itself, is suitable evidence that you do have one.
Haywain
3 Feb 2013
For anything other than a 7-day season, a separate record will exist to confirm what is held on the card. Not that I have seen anything to suggest that defective smartcards have been a problem of any significant volume.
Goldfish62
14 Feb 2010
I had an annual season on an SWR smart card for a couple of years and never had an issue at Oyster-enabled gates in London. The problems were generally with the standalone card readers outside London, which rejected the smartcard at intermediate stations.
Surely that’s a problem common to magstripe, ie not programming for break of journey? Was it a travelcard season?
Goldfish62
14 Feb 2010
Smartcards don't have magstripes. No, point to point season. The whole thing is that the smartcard system seems very flaky as borne out by comments on twitter in the past.
Joe Paxton
12 Jan 2017
I imagine what swt_passenger meant was "Surely that's a problem in common with magstripe [tickets]..."
Goldfish62
14 Feb 2010
Yes that’s what I meant. Sorry for any confusion...
Ah yes. I understand what you meant now.
It seems to be only a problem with the standalone readers. My SWT/SWR smartcard worked fine on gates at intermediate stations where my paper season was previously rejected, just not on standalone readers.
Joe Paxton
12 Jan 2017
Did this include gatelines at intermediate stations outside of the London (Oyster) area?
