SWR outgoing Metro fleet withdrawals (complete)
swr444
26 Aug 2008
There are certainly some diagram changes on the Reading line from today (2 x 455 out all day for example). I expect the 1750 Waterloo to Reading and return is no longer 2 x 707.
Must be a shortage of 458s which is worrying as more and more are leaving to be refurbished, with the 701s nowhere to be seen still
Goldfish62
14 Feb 2010
The diagram the 455s are on is/was one of the three 458 diagrams on the Reading line. I assume that a pair of 458s has been shifted elsewhere because that's where capacity is most desperate.
swr444
26 Aug 2008
Last minute set swap with a 458 earlier going onto the sheppy line with the sheppy 455 going onto the Reading. Both were originally booked as 458s
Bigfoot
2 Dec 2013
Once 707s are all gone some 12 car 450s will be reduced to 8 cars to help fill the gaps in the fleet until the 701s make it into service.
Are there that many trains on midweek peak hour workings where can lose third of the capacity.
You can't fix a gap in the fleet, by creating a hole elsewhere in the fleet. There are certain trains which operate as 10 or 12car and they are close to leaving people behind.
swr444
26 Aug 2008
Pretty much what they did when they thought all the 707s were going last time. The 2G/F/M services had a few 450 diagrams on them, but I believe there are more 455s available this time around
43096
23 Nov 2015
That’s called reshuffling the deckchairs on the Titanic. All it does it create gaps elsewhere.
43096
23 Nov 2015
With a steadily reducing fleet that's all they can really do.
They ought to be pausing the 458/4 programme until the 701s come in.
This is entirely self-inflicted by SWR, with the connivance of DfT.
Goldfish62
14 Feb 2010
Indeed its not as if SE need the stock currently all they will do is stand down some more 465/66 which are cheaper to lease
Yea, you'd think that the DfT would have blocked the transfer of the remaining 707s. Until of course you realise that this is the same DfT that is content to force rolling stock shortages on GWR and Cross Country.
The transfer happened something like 18-24 months ago. It was agreed by DfT then.
SE have been leasing them, but renting them back to SWR. I suspect SWR had max timescale for retaining them and simply ran out of time.
Goldfish62
14 Feb 2010
But given that TOC managers can't sneeze without first getting permission from the DfT I'm sure it would have been well within the DfT's powers to block the final move.
After all, the DfT runs the railways these days, not railway management.
As I said I think it's more simply that the DfT really doesn't care about causing capacity problems.
Juniper Driver
17 Jul 2007
SWR Metals
15/16/17/22/24/30. Not sure if the daily diagrams drop from 4 to 2 tomorrow or next Monday.
My last working on 707s was on 28th and 29th August.I said on my traction exam there was no point doing anything on 707s as I'm very close to my last working that's if I haven't worked them for the last time anyway.So how many left now?
47444
10 Aug 2019
707020 and 707021 were being shunted around Clapham Yard this lunchtime in unbranded condition.
Goldfish62
14 Feb 2010
I guess I've already had my last journey on an 707, at least on SWR. It was on the Reading line a few weeks ago. Coincidentally it was the same line where had my first trip on one back in 2017.
Useless fact there for you on this fine Friday morning. :)
They go tomorrow. 5Z19 Clapham to Waterloo and 5Z20 Waterloo to Grove Park on Saturday early doors.
Now showing on RTT. In the case of 5Z20, do a limited number of SE staff maintain route knowledge of the flyover route, or does some other organisation provide a driver?
28 Jun 2012
Epsom Downs
My understanding is that the Waterloo to Grove Park via the flyover is driven by a DI or DM from LSER. They've kept the competency up no doubt as we've had a fair few visits of LSER 707s at the Park for the wheel lathe which come via Waterloo.
Thanks. Sounds as if it’s a well trodden route then.
Juniper Driver
17 Jul 2007
SWR Metals
I may just squeeze one more working in...My last working were on 28th and 29th August.I have one scheduled for next Friday on a Sheppy.
One traction which was pointless me doing on my traction refresher course recently.
ComUtoR
13 Dec 2013
It's an SE Driver **edit** reading comprehension test.. "LSER" apologies but yeah, 'tis an SE person
... as we've had a fair few visits of LSER 707s at the Park for the wheel lathe which come via Waterloo.
Wheel lathe at The Park ?
**edit 2** FYI Slade Green's lathe is getting an upgrade to fit the 707s
ComUtoR
13 Dec 2013
The 707s are all still visiting Wimbledon Park Depot Wheel Lathe when attention is required.
Ahhhh I was confused as to which 'Park' was being referred to. Edited previous post as it makes more sense on a second read.
