SWR Class 458 to be retained
gazr
24 Mar 2014
Sorry if this has been asked before, but which vehicle is being removed from the formation? 744xx, 740xx or 741xx. Thanks.
fgwrich
15 Apr 2009
Hampshire
I can’t remember which number, but it will be the ex Gatwick Express vehicle (744xx I believe).
43096
23 Nov 2015
Correct, it is the ex-460 car (744xx). The other two cannot be removed as they either contain the PRM toilet and wheelchair spaces or are motor cars.
28 Jun 2012
Epsom Downs
Yes the ex-460 ‘BZ’ car will be removed, as stated in the 744xx series.
Formation returns to :
DMCO 676 BJ car
TOSLW 740 BK car
MOSL 741 BL car
DMCO 677 BM car
(460 cars were AA to AH, 334 cars I believe are CN/CO/CP)
TT-ONR-NRN
30 Dec 2016
Cambridge
I get the impression that hapt1n's source might have conveyed that information to them separately. The wink face is probably not meant to be read as a "look harder" jibe.
Oh right. That’s usually what people mean by that on this forum :lol:
47444
10 Aug 2019
On the subject of which, did 74425 of 458505 go to Widnes with the rest of the unit? Whether it did or not has it been dispatched for scrap?
CR165022
12 Nov 2019
Buckinghamshire
It went with the rest of the unit, whether it's been been scrapped since then I don't know
Cheg1
7 Apr 2023
I posted the picture for general interest following the earlier comment 'I have not seen any photos'
For clarity, it was taken a few months ago and I do have the owners permission to upload it.
Who was the photo owner ?
Reliable source?
Jturner98
2 Jan 2021
Kent
Saw this on YouTube, not my video so credits go to the creator. Look at about 7:40 and you’ll see 2 ex 458/460 carriages.
Cletus
11 Dec 2010
Dover
You never know your luck.
It has donated some parts that were on long lead times but they have to be refitted for handback or return to service whichever way it pans out.
Well you said this about 458534 in January and today being in London I spied it on RTT and so managed to clear the class :smile:
antharro
20 Dec 2006
So let me get this straight. The purpose built GatEx 460s were withdrawn so that the 458s could be extended to 5 carriages, with the remaining 460 carriages being scrapped. They're now removing one GatEx carriage from each 5 carriage set to reduce them back to 4 carriages? Apart from the benefit of the extra complete trains that were primarily comprised of 460 carriages, what a waste.
Yes but only 28 of 36 units.
The quantity is derived from substitution of the planned 442s in the 2017 Franchise Award (although questionable if still sensible)
2 of the original SWR units and the 6 that were rebuilt from class 460 Gatwick units are not being done.
Appears to be no long term plan for the remaining 8 units, or the 28 spare intermediate cars. Probably be stored for a while.
No idea if someone could make up 8 x 8car and haul (or push-pull) the spare ones, having modified to work with a class 67, 68 etc to provide relief trains on non electrified diversions, but do not want to go speculatively off topic.
Roger B
16 Jun 2018
Gatley
No idea if someone could make up 8 x 8car and haul (or push-pull) the spare ones, having modified to work with a class 67, 68 etc to provide relief trains on non electrified diversions, but do want to go speculatively off topic.
I suspect you intended to insert a 'not' between 'do' and 'want' in your final paragraph - but if I'm wrong you certainly achieved your objective of going speculatively (even spectacularly) off topic!
Wolfie
17 Aug 2010
As l recall the 460s had been withdrawn well before the extension of the 458s. That was, at least in part, done to utilise assets which were otherwise of no use.
cactustwirly
10 Apr 2013
They were withdrawn because they were surplus to requirements, having been replaced by the 442s.
They were then used in the 458 project, because they are very similar mechanically and SWT needed 10 cars on the Windsor lines.
Times change and they are being replaced by 701s eventually. They need to be 4 car lengths on the Portsmouth line
They need to be 4 cars to have capability to run at 100mph.
There is nowhere on Portsmouth direct line (via Petersfield) where they could do 100mph. But there are 100mph sections via Basingstoke & Fareham which are currently 444 operated.
However SWR published Info suggests they are for Portsmouth direct. So not clear why they need 100mph capability unless they are expected to work both routes.
moley
12 Jun 2011
They need the 100mph capability for Woking - Waterloo where sections are above 75mph on the fast.
pompeyfan
24 Jan 2012
They’d also need 100mph capability to circulate via Bournemouth depot on some Poole services.
XAM2175
8 Jun 2016
The 460s were withdrawn between 2010 and 2012, replaced by 442s because the 460 fleet was not large enough to support the 4tph GatEx service after it started to be extended to Brighton. This would have happened regardless of what happened to the 458s.
Porterbrook, who owned both the 458 and 460 fleets, proposed the idea of making up the 458/5s to SWT and the DfT because it was a win-win: SWT wanted more capacity on suburban services and Porterbrook didn't want to get stuck with a useless fleet that nobody else wanted.
Not quite; the conversion project was agreed in January 2012, before all the 460s left GX. Some might have been sitting around for a year or two, but in overall terms it was virtually back-to-back.
fgwrich
15 Apr 2009
Hampshire
And of course the idea put forward by Angel of more 450s (or was it extended 450s?) was deemed too expensive.
XAM2175
8 Jun 2016
IIRC they wanted more units. I suspect they proposed that because it would be easier than having to deal with a small subclass of five-car units, but yes, either way, the DfT weren't having it.
southern442
20 May 2013
They'll probably end up needing to milk those extra 8 for as long as they can given how the 701 introduction is going (or more accurately, isn't going). I'd suspect the 707s go first, then the 28 458s, then 455s, then the last 8 458s.
What the DfT eventually agreed to is in the SWR agreement (pages 70-71)
Class 458. 180 vehicles in 5car
270 seats, 2 wheelchair, 279 standing
Leased from Porterbrook to 21 August 2027
* 112 vehicles will be retained, being reconfigured during 2022 and 2023 to make up 28 4-car units with reconfigured interior and a different capacity that includes first class. Remainder of fleet will only stay on lease until they are cascaded out during 2021/22 (the lease allowing for redelivery in line with cascade requirements).
