SWR Class 458 to be retained
Goldfish62
14 Feb 2010
Can we get over this idea that Reading is a metro route - or rather it shouldn’t be. It has more in common with the Alton and Basingstoke lines and should have similar stock. Inner suburban stock is frankly unacceptable on this route.
Up until the early 90s at least it was classified as outer-suburban, with a mix of CIGs and VEPs.
The rot set in with SWT when they introduced 455s during evenings and weekends and it became a quasi inner suburban route by stealth.
23 Nov 2015
In fairness it largely went back to outer suburban stock (Desiros and Junipers) under SWT. The race to the bottom has really been under WorstGroup control, starting with removing first class.
Not really - 455s were originally introduced on Reading services from some sort of passenger safety angle. It can't be by accident that the Reading line was meant to be where 458s went - the aim being perhaps to get less disruption / fewer delays from slam door stock. However, the fact remains that the Reading services are very attractive at Richmond / Twickenham and less so further out and never could be because of the track capacity.
Realistically, the Reading to Waterloo line is never going to see any substantial infrastructure upgrade that allows the journey from Wokingham or Bracknell to London to fall under 60 minutes. It is very low down the list and consequently the services will be quasi-metro to serve the most passengers.
Wokingham
28 Sep 2019
Wokingham
I don't know what could ever be done to achieve that, possibly put the Virginia water curve back in.
Two tracks from staines to the Hounslow loop?
I always thought if Windsor link happens staines station should be moved to after the bridge.
Indeed, but at present that’s a mix of 444s and 450s. I really can’t see 444s being allocated to the newly split services, so it will almost certainly see 444s freed up. 458s going on the Portsmouth fasts will free up more of them. Presumably that would allow all Weymouth services to be 10 car at least as far as Bournemouth.
Why wouldn’t 444s be used on either service? The Waterloo - Southampton semi-fast will still operate in the opposite half hour to the Waterloo to Portsmouth via Eastleigh, and that service also uses both 444s and 450s all day as well. ISTM that there’s no real need to change the stock used at all.
Wokingham
28 Sep 2019
Wokingham
Doo should claw back some minutes from dwell time.
Without a dispatcher at busy stations will be interesting to see how fast the driver can pull away.
Goldfish62
14 Feb 2010
That was the claim at the time, but quite how moving the guard from an accessible location in the middle of the train to being locked behind a door at the end of the train is supposed to improve passenger security I cannot fathom.
The fact is that removing toilets and 1st Class and substituting high back seats with low back inner suburban seats for much of the time was a downgrade.
Having travelled regularly on the line for the best part of the past 30 years I'm certainly well aware of the near-impossibility of significantly speeding up services.
Journeyman
16 Apr 2014
The 701s have high-back seats and toilets.
43096
23 Nov 2015
You will note the proposal in the timetable consultation for all Reading services to call at Vauxhall. Yet another slowing down of the service. They might just as well make it all stops.
I will be complaining to SWR about this planned change and the consistent downgrading of the service that has been effected under their time.
dingdinger
25 Jan 2021
Isleworth
DOO will not claw much back at all. Seconds if that. Experienced guards will be no slower than drivers operating. Having trains which have quick doors and fast acceleration will claw the time back. I.e. a 707 on a Reading would perform better than a 455/450.
davews
24 Apr 2021
Bracknell
I can certainly remember the days when Bracknell to Waterloo was under 60 minutes - under 45 minutes if I recall on some semi-fast diagrams. Mind you they didn't stop at Twickenham and it is now going to be even slower by stopping at Vauxhall.
Goldfish62
14 Feb 2010
When I first moved to the area in the early 90s there was an hourly off peak service which called at Clapham Junction, Richmond, Ascot then all stations.
spark001uk
20 Aug 2010
I remember those days. They used to leave some suburban stops to local services more back then. Like the stoppers up the main not calling at Earlsfield or Vauxhall for example.
Sean Emmett
9 Mar 2015
Before that, in 1977 there were half hourly fasts which ran fast Waterloo - Feltham - Staines - Ascot, then alternately all stations to Reading or Guildford (via Aldershot). With stoppers that were caught up, and offered cross platform interchange at Ascot with the following fast train. No concerns about stepping over the live rail in those days. The up fasts tended to be routed via Hounslow, but disappeared in the early 1980s.
Then in the mid 1980s some fasts were re-introduced, stopping at Clapham Junction, Richmond, Ascot then all stations to Reading as you say. On Sat 23 Aug 1986 I timed 4VEP 7772 from Ascot to Waterloo in 34m 33s inclusive of the two stops, including Ascot to Richmond in 18m 59s, under even time.
Ocassionally, following disruption, trains run fast from Ascot to Staines, Richmond and even all the way to Waterloo. But even with a clear run, no 458 has come close to matching that time, even with the faster start out of Ascot. But I like the 458s (and 450s) and see the 701s as a step backwards.
All the previous talk about speeding up Reading line services is completely absent from the latest timetable consultation. Even worse, a Vauxhall stop is to be added to all Reading trains. How much slower can it get?
Goldfish62
14 Feb 2010
Remember also that Longcross is also now a stop on everything except late evening services.
TEW
16 May 2008
Yes but the same document says I’m the intention is all metro routes are operated by ‘metro guards’ having one pocket on guarded operation on the Windsor lines doesn’t seem sensible.
Some remaining 450 work on the Windsor Lines has always been part of the plan from what I understand. Suburban routes will see a mix of Metro and Commercial Guards so it shouldn't pose any paticular issue.
Well they could consider adding Putney, Whitton and Ashford...
HamworthyGoods
15 Jan 2019
A Vauxhall stop may actually speed up people’s journeys as the interchange to the Victoria Line is very easy and that’s a quick route to the West End and North London.
It’s all very well measuring journey times to/from Waterloo but very few people actually start/end their journeys at Waterloo.
Just a gentle reminder this is a Traction & Rolling Stock thread to discuss SWR Class 458 to be retained by SWR.
Feel free to create a new thread (if there isn't one already) to discuss anything else :)
Bayum
21 Mar 2008
Why are the 458s being re-reduced to 4 car? Doesn’t the PDL have some 444 allocations?
Covered up thread - a 458 has 20 metre vehicles, a 444 has 23 metre vehicles - 12 x 20 = 240, 10 x 23 = 230 which fills the platforms. A pair of 5-car 458s would only be 200m long.
Goldfish62
14 Feb 2010
Actually 204m long because the end coaches are 21m.
The 458s are restricted to 75mph with the additional trailer due to potential traction equipment overheating issues.
Bayum
21 Mar 2008
I though they were regeared because Reading didn’t require 100mph units?
43096
23 Nov 2015
No. For the reason stated. This was covered in Modern Railways by Ian Walmsley, who ran the project.
Both, actually. The duty cycle doesn’t need more than 75mph and the stop-start nature of their workings (which in part dictates that 75mph is sufficient) meant that leaving them as 100mph geared could have resulted in over hearing. By gearing for 75, the motors spin faster at any given track speed, which draws more air into the motor keeping them cool.
Bigfoot
2 Dec 2013
They are being re geared to 100mph again when the additional trailer is removed.
