SWR Class 458 to be retained
DelW
15 Jan 2015
Ah makes sense, did they not think about that before they decided they were going to run them to Portsmouth? (or maybe they haven't tested it yet?)
Just for context, 458/5s were cleared for passenger service to Haslemere. There was for a time a mid-evening service from Waterloo to Haslemere which used a 458/5 that then went ECS to Farnham. It caused me a double-take once or twice when I encountered it by chance.
AFAIK neither /5s nor /0s were cleared south of Haslemere. That was the limit for the farewell rail tour that used a pair of /0s before their (first) conversion.
Bumpkin
23 Aug 2017
The restriction to 458/4s in passenger service on the mainline is one imposed by SWR, not Network Rail, related to the safety certification of the stock.
As far as Network Rail are concerned, the stock is gauge cleared and can operate with some exceptions on the slow lines between Wimbledon and Clapham Junction.
pompeyfan
24 Jan 2012
The /5s were subject to a modification program within Fratton Depot, and used both routes to get there when various blocks were underway.
I’m also pretty certain they were used to test the current ASDO system and ran over most of the network to do so.
43096
23 Nov 2015
No special permission can be given unfortunately. They are not route cleared for passenger service full stop therefore I would be extremely surprised if someone would have been brave enough to give that clearance.
True and true, but I guess there isn't really a pressing need to get them route cleared as the likelihood of requiring such a diversion is fairly small in the grand scheme of things. Useful but with other more pressing issues to resolve I imagine it just isn't high enough on the agenda list of those in charge.
Although given it ran through fine without the world stopping spinning on its axis, they would now seem to have been cleared, at least on the down fast. ;) :lol:
WimFit
25 Jan 2015
The inclusion of the main lines for passenger service were removed from the vehicle change proposal at the insistence of Network Rail, to avoid any possibility of the units being inadvertently routed via the slow lines at Clapham during perturbation.
Goldfish62
14 Feb 2010
Now the MD of SWR is also responsible for Network Rail on his patch maybe he's overruled this. But probably not!
I'm still surprised that the 458/4s are out of gauge at these platforms when the 458/0s weren't.
WimFit
25 Jan 2015
We were all surprised.
Big Jumby 74
12 Feb 2022
I suspect they will be treating todays 458/4 as a 'new' type for the purposes of clearances, irrespective of how closely aligned they may be to their original incarnation as 458/0.
WimFit
25 Jan 2015
Indeed and the gauging standards have changed since they were 458/0’s too.
Boalbads
7 Sep 2024
Are they worried about their own control swapping a 444 for a 458?
WimFit
25 Jan 2015
The risk is that the signaller could inadvertently route them via the slow lines at Clapham in times of disruption, where they have gauging restrictions. It was agreed with NR that they wouldn’t be used in passenger service on the main line to remove that risk.
43096
23 Nov 2015
I don’t understand why there is a passenger/non-passenger distinction as the airbags adjust for loadings. They get back to Wimbledon depot without issue…
Goldfish62
14 Feb 2010
Would appear to be another reason why they'll never appear on Portsmouth services, or any other mainline service for that matter.
43096
23 Nov 2015
It should have been dealt with long since. It’s a common (both planned and unplanned) diversion for Reading services. A failure to clear them is not acceptable from a customer service perspective.
Big Jumby 74
12 Feb 2022
Not to mention crew related matters. The PDL was/is(?) the domain of several crew depots, but with only a select number of services (IPs) based on stock type, the number of turns involved will be limited. In consequence the number depot's involved will have to be limited to (perhaps?) Fratton and Waterloo (one link at each?). That in itself will have implications, as Woking and Wimbledon (AFAIK) still work the route, but they'd never go to the expense of training those depots* on such a small fleet type that only worked the one core route. Again we are back to the risk to the timetable, when what the industry needs is as much operational flexibility as possible.
PS: * bare in mind this relates to the future when , for the sake of argument, all 458/4 are allocated to 1Pxx PDL services and now't else. If that were the case, any traction knowledge of same currently held by Woking, Wimbledon (and other suburban depots) will have long since elapsed.
Phil R
18 Jan 2020
Guildford
Indeed, 2145 Waterloo - Haslemere in the December 2022 timetable.
Big Jumby 74
12 Feb 2022
That is so, but in the mire of things that need attending to, it may well be lower down the priority list. There are only so many people to deal with these matters, not helped by a change of overall control, which will detract some of those people from their day job initially - believe me! As one small example, when the 456's were re introduced to the SW i/c/w the original 10 car plan, one diagram involving same was required to return to Wimbledon depot via East Putney after the am peak, as part of 3Y81, 08+21 ex Waterloo. For me this was a must, as it provided the depot with the only 456 (for maintenance reasons) on the day shift, but those involved with matters as above were overworked at the time, so the clearance of 456s via the East Putney got pushed back and back. It was done, just in time, but only after some pressing - and that was for a move that formed part of the base plan, not (what some - not me btw) might see as a 'nice to have just in case', sort of thing.
Boalbads
7 Sep 2024
I was doing some looking, does anyone know if the ex-460 coaches kept their original coach numbers when they were in the 460 set? (I presume the fully ex-460 sets had their numbers changed, but for the extra coach that was Inserted into the other /5s)
Peter Mugridge
8 Apr 2010
Epsom
They all kept their original carriage numbers.
In principle, the individual vehicle number is with a vehicle from cradle to grave, and although they will usually be in some sort of logical sequence when first assembled into a class of units, even if they are later inserted into something else, or the parent unit number is changed, then the vehicle number stays the same.
Boalbads
7 Sep 2024
Interesting, I assumed they always changed if the unit number changed.
I’d think of them as being like a car’s VIN, which is stamped into the chassis, whereas a unit number is just a convenient way of referring to the whole consist. Unit numbers can be changed (within reason), examples such as SWT renumbering 10 x 3 car 158s as 159s, and also renumbering 11 x 158s as 158880-890 for little more than ‘neatness’. What those 2 changes achieved was a straightforward way of organising allocations as 159 = 3 car, and 158 = 2 car.
43096
23 Nov 2015
Vehicle numbers can be changed, too. For example the DB Cargo and GBRf Class 66s that are being re-geared. It is easier to change set formations, however.
Yes, I was really thinking of units only. It seems to be done on a different basis for locos for some reason.
28 Jun 2012
Epsom Downs
The numbering is normally amended to reflect changes on the fourth digit of the unit numbers, rather than the carriages.
Locos will be allocated by planners by the painted number of the loco, units will be allocated by unit number, not the carriages individually.
Peter Mugridge
8 Apr 2010
Epsom
I should flag up that this doesn't apply on the London Underground; if two vehicles are swapped between two units, they will nearly always each get renumbered to keep the units in the apparent correct formation - this was a particular headache for keeping track of A Stock carriages and a n umber of 1959 / 1962 Stock carriages got swapped and renumbered as well, in some cases more than once!
bluegoblin7
10 May 2011
JB
Nearly always, except for all the times that this didn't happen - notably with the S7+1 units and the replacement MS cars built as part of that shuffle around.
