SWR Class 458 to be retained
Siemens Staines
30 Jul 2015
10 pairs of 458/4 in passenger service this morning with the extra set coming out for 2U13 0733 London Waterloo to Windsor & Eton Riverside
Perhaps this is associated with a ramp up to 12 pairs in use next week?
458535 is covering for a pair of 455 on the 2J92 Surbiton diagram. Meanwhile 458530 lies dormant.
Nimbus020
7 Mar 2025
SW London
Thanks v much: short-formed suburban services into W'loo seem to be 07:24 from Woking, 07:41 from Chess South, 08:29 from Surbiton (458535 as above) & 08:33 from Hampton Ct - so compared to Monday eve, not too bad?
Siemens Staines
30 Jul 2015
And finally, if the data feed to RTT is correct, 458419 is in passenger service for the first time today
2U09 0633 London Waterloo to Windsor & Eton Riverside
This is the last 458/4 conversion to enter service, 3 years and 8 months since the programme started with 458507 + 458517 last day in service as 458/5 on 23.09.21
Bessie
30 Oct 2017
I’m on a Class 458/4 to Reading. It was 8:18 from Martins Heron. Front unit is 023
Goldfish62
14 Feb 2010
I've just had a look on RTT. Today on Reading services we have (all pairs):
2 x 458/4
1 x 458/5
1 x 455
3 x 450
So not the flood of 455s as weekdays are now.
nctd2306
2 Jan 2024
Berkshire
The introduction of 8419 doesn't appear to have helped much, three short formed 458/4s out today with two (right behind each other) on the Windsor services, let's hope there aren't too many people going to Windsor today :rolleyes:
TT-ONR-NRN
30 Dec 2016
Cambridge
Ah, well if it keeps the forever complaining Reading line lot happy ;)
nctd2306
2 Jan 2024
Berkshire
I'd rather an 8-455 that I can actually get on than a 4 car train with all the gadgets but no room to board!
I think you mean 423? :)
Should be a consecutive pair with 458 422 on the back there. :)
Unfortunately I was due to catch this train on its return run up to London but it got cancelled at Reading due to a fight breaking out on board and injuries being sustained that required medical attention (yes you read that right), these units didn't return to service and got replaced by a pair of 450s on the diagram
SWT_USER
29 Aug 2010
Ashford Middx
Has the rejig of diagrams pushed more short formations on to Windsor services? Two 4 coach trains in the past two days for me. Surely there are spare 450's kicking about on weekends
Invincible
23 Apr 2022
Today from RTT Windsor seems a mixture of 8 car 458, 450 and a 10 car 701.
The Weybridge line via Hounslow, which has been running 458s every 30 minutes , on but normally Sundays goes to Woking hourly rather than Weybridge, and looks like 8 car 458 and 450s today.
cactustwirly
10 Apr 2013
It is justified, you'd be in the same position if short formed 455s started operating on the Alton line
If the service was still operated by 10 car 458s everyone would be happy
43096
23 Nov 2015
Indeed. The peak Reading service has dropped from 4 x 10-car per hour to 2 x 8-car (if you’re lucky). That’s a 60% drop - has anywhere else had a bigger cut?
TT-ONR-NRN
30 Dec 2016
Cambridge
But you (the Reading line, not actually you specifically) want your cake and to eat it. To complain about a reduction in formation aka less capacity, but then say you want the 458/4s, which have lower capacity than the 450s, or complain about getting 701s instead in future, which have the most capacity of all, proves that.
43096
23 Nov 2015
It doesn't "prove" anything. The line has been downgraded from outer suburban (like Alton, Basingstoke) to inner suburban with the 701s. The ideal train for the line is/was the 458/5 fleet.
cactustwirly
10 Apr 2013
I think the Reading line would be happy with 450s
It's the 455s and 701s which are not suitable with the 2+2 uncomfortable seating
LUYMun
15 Jul 2018
Cancelled
Disagree on the 455s, they have a small bit of spacing between the seats which makes it more comfortable not pressing up against someone's shoulder.
Goldfish62
14 Feb 2010
The downside is that the vast majority of the seat cushions have collapsed, not making them particularly comfortable.
2 Jun 2023
Richmond
The 701s have the same thing, it's just the cushion is wider creating the visual illusion that there's no space between.
Picture of seat spacer on 701s
Meanwhile 450s have no spacer:
Picture of the middle of two seats on a 450
Invincible
23 Apr 2022
After Virginia Water to Waterloo the Reading train effectivly becomes a suburban train. Ideally the 458/4s should have kept the handrails when overcrowded with several passengers standing, so eventually will be 701s. (With the refurbished 458/4s deep cleaned and going to the Portsmouth main line?)
Goldfish62
14 Feb 2010
Unless you've carried out a survey of Reading line users you seem to be drawing your own conclusions with little foundation.
For me the 701s can't come sooner enough. As much as I like the 450s they get a little too cosy in the peaks, the 458/4s as nice as they are aren't really suitable for crush-loading suburban services and have far seats, as do the 455s, resulting in standing room only often from Egham inwards towards Waterloo.
