SWR 455 twilight diagrams/workings
nobbyzack3
27 Feb 2023
Romford
21:12 Shepperton, been stock changed to 455721 and 732!
First 455 of 2026!!
Andy1673
10 May 2019
I wonder what will be booked on next weekdays diagram starting as 5J97 off Wimbledon depot (formerly 455s)?
11 May 2022
Guildford
5721+5732 are planned to be out all day today. First run is 2M11 0808 Wimbledon - Chessington South 0826
Siemens Staines
30 Jul 2015
This diagram is also shown 8v10 on journeycheck
08:08 Wimbledon to Chessington South due 08:26
08:39 Chessington South to London Waterloo due 09:15
09:32 London Waterloo to Guildford due 10:42
11:20 Guildford to London Waterloo due 12:31
12:51 London Waterloo to Chessington South due 13:25
13:39 Chessington South to London Waterloo due 14:15
14:32 London Waterloo to Guildford due 15:42
16:20 Guildford to London Waterloo due 17:31
17:51 London Waterloo to Chessington South due 18:25
18:39 Chessington South to London Waterloo due 19:15
19:32 London Waterloo to Guildford due 20:42
21:20 Guildford to London Waterloo due 22:31
22:51 London Waterloo to Chessington South due 23:25
23:40 Chessington South to Wimbledon due 23:59
Will be formed of 8 coaches instead of 10.
Nimbus020
7 Mar 2025
SW London
5712+5717 due to work 2J47 1636 W’loo to Hampton Ct today - not sure if they worked earlier today? - when I looked earlier, they were also allocated to 1D46 1532 Dorking to W'loo (taking over a 701 diagram?)
Siemens Staines
30 Jul 2015
5712+5717 due to work 1D46 1532 Dorking to W’loo today - not sure if they worked earlier today?
According to journeycheck all Dorkings are currently cancelled as a result of
"Due to a signalling problem between Earlsfield and Wimbledon some lines towards Surbiton are blocked.
Train services running through these stations may be cancelled, delayed or revised. Disruption is expected until 16:00 05/01.
Engineers arecurrently on site and carrying out testing to investigate the fault. In order to allow Engineers to access to the railway, one of the lines towards Surbiton is blocked.Train services running through this area may be delayed, revised or cancelled at short notice.
As a result:
- London Waterloo to Shepperton services will be diverted between Clapham Junction and Fulwell, calling additionally at Richmond, Twickenham and Strawberry Hill.
- London Waterloo to Woking (stopping services) will be unable to serve the stations from London Waterloo to Surbiton.
- London Waterloo to Guildford via Cobham & Stoke d'Abernon services will be unable to serve the stations from London Waterloo to Surbiton.
- London Waterloo to Guildford via Epsom services will be unable to serve the stations from London Waterloo to Raynes Park.
- London Waterloo to Dorking services will be cancelled.
- London Waterloo to Chessington South services will be unable to serve the stations from London Waterloo to Raynes Park.
- London Waterloo to Hampton Court services will be unable to serve the stations from London Waterloo to Raynes Park.
- London Waterloo to London Waterloo via Kingston services will be unable to serve the stations from London Waterloo to Raynes Park."
Nimbus020
7 Mar 2025
SW London
As a result:
Thanks Mr Staines - I've updated the earlier post
SWR are rotating their 'hot spare' 455s? - 5721+5732 the other day, 5712+5717 today - does anyone know how many units they have for these duties? - thanks!
Southern
19 Jun 2005
Folkestone, Kent
Excellent, cheers for the heads up! Been a busy afternoon, otherwise would have caught them earlier but hoping to see them on the return from Hampton Court, all being well.
Nimbus020
7 Mar 2025
SW London
5712+5717 worked 5J47 from W'don depot earlier so they're "good to go" to Hampton Ct from W'loo Plat 5 @ 16:36 (they're then due to see out the day doing the remainder of the diagram, including the 'peak' 1809 W'loo to Guildford semi-fast)
w11_supremecy
17 Oct 2024
2J47 is indeed formed of 5712+5717.
thetraingirl
1 Jan 2026
Hampshire
I went up to Waterloo on Saturday hoping to catch some 455s but alas, no luck! Saw them sat Wimbledon Depot as I went past which was lovely. Really hoping to catch a ride on one before they are gone for good!
Siemens Staines
30 Jul 2015
And also
5721 + 5716
2C59 1850 London Waterloo to Reading
2C70 2039 Reading to London Waterloo
Nimbus020
7 Mar 2025
SW London
Good idea! - keep checking each day (on RTT, for example) & something may turn up - I just searched some of the remaining unit numbers on RTT earlier today and found out about 5712 + 5717’s workings
Southern
19 Jun 2005
Folkestone, Kent
Caught up with them at Wimbledon at 1743, 1724 off Hampton Court and had a ride into Waterloo. Potentially the last time unless I can get up to London again soon
Nimbus020
7 Mar 2025
SW London
5716+5721 are out this morning (worked 0520 to Woking) - presume will stick to diagram all day?
11 May 2022
Guildford
Yes... here's the full diagram for the rest of today...
5716+5721
2J11 0736 London Waterloo to Hampton Court
2J18 0823 Hampton Court to London Waterloo
1D17 0923 London Waterloo to Dorking
1D26 1032 Dorking to London Waterloo
2J27 1136 London Waterloo to Hampton Court
2J34 1224 Hampton Court to London Waterloo
2F33 1320 London Waterloo to Woking
2F42 1433 Woking to London Waterloo
2G43 1533 London Waterloo to Guildford (via Cobham)
2D54 1659 Guildford to London Waterloo (via Epsom)
1D53 1823 London Waterloo to Dorking
1D62 1932 Dorking to London Waterloo
2J63 2036 London Waterloo to Hampton Court
2J70 2124 Hampton Court to London Waterloo
1D69 2223 London Waterloo to Dorking
5Y58 2325 Dorking to Wimbledon Park Depot Sdgs (ECS)
Nimbus020
7 Mar 2025
SW London
5716+5721
Many thanks - the diagram was worked by 701 035 y'day
Siemens Staines
30 Jul 2015
Reading & Hounslow loop this evening;
5716 + 5721
2C55 1750 London Waterloo to Reading
2C66 1939 Reading to London Waterloo
2S73 2222 London Waterloo to Weybridge
11 May 2022
Guildford
* Class 455 Allocations - Wed 7th Jan *
5716+5721
5J97 0523 Wimbledon Park Depot Sdgs - Hampton Court (ECS)
2J08 0554 Hampton Court - London Waterloo
1D07 0639 London Waterloo - Dorking
1D16 0748 Dorking - London Waterloo
2G17 0903 London Waterloo - Guildford (via Cobham)
2G28 1034 Guildford - London Waterloo (via Cobham)
2F27 1150 London Waterloo - Woking
2F36 1303 Woking - London Waterloo
2G37 1403 London Waterloo - Guildford (via Cobham)
2G48 1534 Guildford - London Waterloo (via Cobham)
2F47 1650 London Waterloo - Woking
2F56 1803 Woking - London Waterloo
2G57 1903 London Waterloo - Guildford (via Cobham)
2G68 2034 Guildford - London Waterloo (via Cobham)
2F67 2150 London Waterloo - Woking
2F80 2304 Woking - London Waterloo
5Y68 0007 London Waterloo - Wimbledon Park Depot Sdgs (ECS)
Diagrams do change, often at short notice - please check Realtime Trains or an equivalent website before setting out to see them!
Steven Taylor
2 Oct 2022
Battersea
5716+5721
0903 Waterloo departure to Guildford passed my house (Clapham Junction) at 0910, and it is a 455. Good to see the `red train` again.
Fingers crossed for the 1150 Waterloo departure
11 May 2022
Guildford
* Class 455 Allocations - Thu 8th Jan *
Same as yesterday!
5716+5721
Nimbus020
7 Mar 2025
SW London
Same as yesterday!
5716+5721
Many thanks for this - if I'd been more "eagle" eyed this morning, I would've aimed for 1D16.......
Surrey David
31 Dec 2013
Redhill
Adding my thanks to Rich the Eagle for posting all this info. I was able to plan a devious route this evening which took in 2G57 end-to-end. A big nostalgia trip - I was a regular on the Cobham route about 45-50 years ago - all EPBs and some VEPs back in the day!
Bikeman78
26 Apr 2018
Same as yesterday!
5716+5721
5712+5717 allocated to this diagram today.
