First time poser here.
Would someone please tell me, what are the diversionary routes undertaken between Swansea and Paddington. Thank you
Thank you kindlyWelcome to the forum!
Normally via Lydney / Gloucester if the Severn Tunnel is blocked. Adds about 35-45 minutes to journey times.
Via Newbury, Westbury and Bradford-on-Avon to Bath and then onwards to Bristol and South Wales. Normally when the line between Didcot and Swindon or Wooten Bassett is blocked
There will be no direct train services between Bristol or London and South Wales due to track renewal work in the Severn Tunnel.
Replacement buses are planned between:
Trains will still run from Bristol Parkway towards Swindon, Bristol Temple Meads or Gloucester, plus between Patchway and Bristol Temple Meads (Saturday only).
- Bristol Parkway and Cardiff Central (non-stop)
- Bristol Parkway and Newport (non-stop, plus some services stopping at Patchway and Severn Tunnel Junction)
GWR will also operate trains between Newport and Swansea or Carmarthen.
Being pedantic, but the diversions miss Westbury (go via Heywood Road Jn to Hawkeridge Jn) and also miss Bristol TM by taking the Rhubarb Curve.Via Newbury, Westbury and Bradford-on-Avon to Bath and then onwards to Bristol and South Wales. Normally when the line between Didcot and Swindon or Wootton Bassett is blocked
Plus the loops at Ninian Park and Margam.There is also the Vale of Glamorgan diversion via Barry which ISTR is regularly timetabled for route retention purposes.
Yes ofc, although I swear some call at Bristol because they become extensions of the Bristol service?Being pedantic, but the diversions miss Westbury (go via Heywood Road Jn to Hawkeridge Jn) and also miss Bristol TM by taking the Rhubarb Curve.
Think that tends to be when the block affects via Chippenham services as well (ie everything going via Newbury). Of course, the first down weekday service does that anyway (reversing at both Temple Meads and Parkway having come via Chippenham)Yes ofc, although I swear some call at Bristol because they become extensions of the Bristol service?
This would usually be accessed by running via Filton and Charfield, to reach Gloucester then continue via Lydney. Diversions via Bristol and Gloucester aren't mutually exclusive, albeit very rareOf course there's lots of diversions on the English side by going via Bristol one of two other ways, but won't help if the Severn Tunnel is out of action & the standard route is via Gloucester / Hereford as above.
This weekend though, there are no diversions: https://www.gwr.com/travel-information/travel-updates/planned-engineering/bristol
