Sussex Coast Statesman 14th August 2026
leomartin125
15 Nov 2015
North West
Due to the derailment at Lewes (thoughts to those affected), the tour today is due to head through Lewes en route to Eastbourne. I assume this will be diverted now? Any idea which route this will go?
MTIA
SECR 65
2 Apr 2026
East Sussex
I provide what I've just posted on another thread, which I think is about the same tour.
I haven't been closely following this thread, but if trying to divert around the incident area at Lewes, and keep the lead engine leading, you could run like so:
Haywards Heath
Keynes Junction continue towards Brighton
Preston Park
Spur to Hove
Reverse at Hove
Brighton platform 3
Reverse at Brighton
East Coastway to Lewes
And continue towards Eastbourne or wherever the tour heads
You could also go:
Redhill
Tonbridge
Then down to Hastings
Reverse and back to Eastbourne
Northampton
The link at Brighton Platform 3 between the West Branch and the Main or East Branch is only 4 cars long so they won't do that.
Mcr Warrior
8 Jan 2009
It's going via Brighton
Noted. Are the higher number platforms at Brighton not capable of accommodating an 8 or even 12 car train off the Brighton main line before it then reverses out via London Road / Moulsecoomb towards Lewes / Eastbourne? How long is the Statesman, BTW?
Northampton
The East Branch junction is well off the end of the platforms so trains to/from Lewes can use the full length of 3-8, all of which are 240-250m long. It's only trains to/from Hove in P3 that have a particular issue.
SECR 65
2 Apr 2026
East Sussex
I feel fairly sure that you could run an 8 car Electrostar in the manner described into a platform such as 7 or 6.
LA50041
20 Feb 2017
You can run up to 12 cars from the main line (Preston Park) to platforms 3-8 and reverse out to the East Branch
Peter749
27 Apr 2016
Salford
Today 47712 worked 1Z58 05:34 Derby to Eastbourne Statesman
The train was booked via Keymer Jn to Lewes which did not happen due to yesterdays derailment
On the Liverrail page the train went via Preston Park to Hove where it reversed but was next reported at Lewes - how did it get thru Brighton?
Haywards Heath212:46½12:16 30 Early 2
Keymer Junction12:19 Off route
Preston Park12:30 12:29 Off route
Hove Signal T67412:33 17 Early12:38 12 Early 7
Keymer Junction12:50½No reportPath: 4½
Lewes113:0512:53 12 Early 3
Southerham Junction13:0812:56 12 EarlyPath: 5
Polegate13:2213:10 12 Early 2
Willingdon Junction13:2613:13 13 Early
Hampden Park213:26½13:16 10 EarlyPath: 3 2
Eastbourne313:3313:21 12 EarlyTrain finishes. 3Terminated
PP57601
3 Jun 2019
It reversed in Brighton (12:33 - 12:38) according to accurate industry [rather than online spotter] sources.
Not sure what you are using above for timings?
SECR 65
2 Apr 2026
East Sussex
Using platform 7 at Brighton, I don't believe it could have come from Hove.
If it did come from Hove, it would have had to have used Brighton platform 3, which I understand to be 4 car maximum for the crossover.
8ace
25 Dec 2019
Brighton
The only reason it would need to go via Hove would would be to turn a kettle via the triangle, but as it was duff-hauled (apparently) it would just complicate and lengthen the journey.
Dave61
8 Mar 2026
Long Eaton
I was on this trip and on the way to Eastbourne is reversed via platform 7 (Platform 6 had a "DONT USE" berth code at the time) and then platform 5 on the way back.
We got a really fast and clear run down to Brighton and despite the diversion managed to arrive at Eastbourne slightly early
