Suggestions for Dawlish avoiding route(s)
6 Mar 2010
The likes I Olaf and 47802 are really clueless. I am not some weekend fantasy hobbyist and I'm sure other contributors aren't either. I've recently been involved in tendering for the Wessex Capacity enhancements for Waterloo (10-car mainline suburban and full reinstatement of International platforms).
For a tiny fraction of the cost of that project Plymouth and Cornwall can reliably be connected to the rest of the rail network at all times pending longer term Dawlish solutions.
A few facts:
- nobody cares at all about journey times if there is major disruption and you can get home by rail rather than bus
- a minimum cost solution with just 16 miles of reinstated infrastructure between Tavistock and Meldon will do fine providing loops allow 2tph
- Current London centric UK economy is an implosion waiting to happen and yet Crossrail 2 comes next (I'm involved with that project too) with more investment thrown at what is essentially a service economy with no real wealth creation. Why do you think all the commentators (deputy Head of BofE this week) are suddenly wakening up to the fact that zero is the new norm base rate? It's because London and alike have sucked the life out of the real economy for 20 years now without any real added value - the western world is broke. Yet cost benefit analysis still reckons more of the same will work. It won't. It's time for smaller investments that can make a start on rebalancing our country.
Yes I'm sure passengers do prefer to travel by train and will accept an increased journey time up to a point, however the Fact is that many TOC would now rather run a bus even when a diversion exists because its cheaper and less hard work, eg. Virgin would rather run buses than an S&C diversion no doubt its cheaper and less agro than changing the voyager diagrams, and hiring 57's, granted its less of a problem with purely diesels, however what's the betting that with your limited capacity solution many passengers still end up going by bus.
Ok maybe I'm clueless but I certainly skeptical you can build your minimalist railway for the figures that seem to be quoted or that its the right solution, again its more like a solution for a local service under the guise or resilliance for the mainline.
The line at Dawlish was closed by the worst winter in 250 years- if that becomes the "norm" over the next decade then that changes things significantly, but we can't base everything on "freak" results
The fact remains that the route tends to be quite severely affected by extreme weather every twenty to thirty years or so, so having an alternative helps.
Why are you so obsessed with dragging the "Waterloo to Barnstaple" stuff onto every thread?
It's quite a sensible point in as much as the NR study included significant costs for strengthening the route around Cowley bridge junction. The fact is that those works would significantly benefit travelers in North Devon, so that should be captured in the analysis of any benefits.
Does it matter whether a service in the 21st century runs on tracks that "belonged" to the GWR or LSWR generations ago?
Of course not. But it does help those with an agenda against re-openings to paint every reopening proposal as a nostalgia exercise.
Yup - if you don't like a BCR (which doesn't agree with the fantasy of re-opening some scenic line closed fifty years ago) then just keep moving the goalposts until you get the answer that you want!
Well done, you've just illustrated my above point splendidly !
Why can't we use the same BCR that other schemes are assessed against?
As I've said on this thread a few times, the money that could be used on a scenic route via Okehampton could be used on many other railway schemes (redoubling parts of Exeter - Salisbury, electrifying the B&H etc) - if the evidence about sea level rises is used in the calculation and the Okehampton route still has a poor BCR then that's the facts.
(and if the sea is going to rise sufficiently to close the line at Dawlish, then the Okehampton-supporters seem happy enough to abandon Torbay - how come Cornwall deserves a "resilient" service to Exeter/ Bristol/ London etc but Torbay doesn't?)
The same mumbo jumbo could be said of any project though (don't like the BCR? just find some random numbers to throw into the equation to give the answer you want)
True - if we have to add in all of these other factors in the Okehampton BCR then it's only fair that we use them to assess other projects too - no point in having BCRs if we aren't going to use them sensibly.
Seriously, you go on about the BCR analysis as though it is some totally objective be all and end all, handed down from on high to Abraham on tablets of stone. It's just a set of numbers that somebody's come up which leaves some things out and adds others in. What you call "mumbo jumbo" is the ability of people to go about their business and undertake economic activity. It's astonishing that this isn't captured in the methodology, yet a ten minute saving out of a journey of several hours (I've had longer trips to the toilet) can be calculated to add up to millions of pounds.
I wouldn't have a problem with an improved BCR methodology being used on other projects as well, as you say, it's only sensible.
But these individual bits should be treated individually - not lumped all together to suit the nostalgia for bringing back a line closed fifty years ago
You're laying the old nostalgia spin on with a trowel.
They should be lumped together. Cowley Bridge is a case in point. Improvements there would benefit North Devon, so it would be foolish to count the costs but not include this benefit.
As an individual element, a branch to Tavistock would be of great benefit to those travelling to or from Tavistock itself, but as part of a through route there are far greater benefits, including to residents diverted at times of disruption and residents travelling to other places in central Devon. Why wouldn't you logically want to capture all of these.
Not sure I share your enthusiasm for Scotland having things so much differently btw. They couldn't get the Glasgow Airport link built, they couldn't get the Edinburgh Airport link built...
...A2B had a decent enough case for reopening, so the only oddity was the Tweedbank line which was a purely political decision (to keep the LibDems in coalition at Holyrood) - but that's a one-off.
Maybe it's something in the water, but the fact remains that Scotland has achieved some notable reopenings during the privatised era while the record in England has been, frankly, lamentable.
Plenty reasonable sized places in Scotland remain without a train station (Grangemouth, Levenmouth etc) - so it's not like they get everything they want.
With a decent BCR methodology, perhaps we could see to get those linked up as well.
The idea of building a 30mph single track line sounds realistic for the kind of marginal market you are going to get on the Okehampton line - it's hard to argue against something this modest...
...but we can't pretend that a 30mph single track line (built to accommodate a bi-hourly service taking over an hour and a half from Exeter to Plymouth) is going to be any use as a diversionary line if the route at Dawlish closed - people would be dumped on replacement coach services rather than trying to run HSTs this way.
30mph is too slow, however, I'm not against a single route with loops. There's no reason to massively over-inflate the costs, however there should be enough loops to ensure that two or three trains an hour can get through in times of disruption..
You should know as well as anyone that the single track WOE mainline has proved its value as a diversionary route time and time again (as one of your alternative funding suggestions is to improve this capability).
The benefits of a faster route from Cornwall/ Plymouth/ Torbay to Exeter/ Bristol/ London would benefit large numbers of passengers day in day out.
A route via Okehampton would only benefit some of those people (i.e. not the Torbay ones) and would only be a benefit to them a few days a year.
Well, there are various ways in which the Great Western mainline could be speeded up by ten minutes. Sober analysis would suggest that those which are a lot cheaper than one and a half billion pounds should probably take priority.
Some people seem quite happy to abandon South Devon entirely (until, no doubt, the moment that the line is closed and then we'll see enthusiasts desperate to re-open it because of... y'know, the "social costs" and all that...)
The reality is that Plymouth is the main economic centre of the region. It's also a reality that Torbay is rather closer to Exeter and the rest of the network than Cornwall, so bustitution, whilst not ideal, is a shorter experience.
Putting my strategic hat on, I am very concerned with the potential social costs of losing stations in places like Teignouth and Dawlish permanently which is why I am very keen for them to retain a main line.
It's true, Virgin haven't been covering themselves in glory of late in this respect ! One thing to bear in mind is that even without diversions, people would still have the option of changing to the scheduled service trains.
The Ham
6 Jul 2012
Let's assume for a moment that the old route was reopened and FGW opted to send everyone by bus when Dawlish was closed. Guess what would happen if passengers had a ticket that entitled them to use a train which went via Okehampton?
On a related note, the chances are that there will be 3 ticket types. The first being the existing which will become any permitted. With the other 2 being via a set route, although via Newton Abbot would likely be only on advanced tickets.
Olaf
29 Mar 2014
The likes I Olaf and 47802 are really clueles...
You are deluded and probably being humoured by your colleagues; the suggestions you came up with do not belong in the current millennium.
You forget that not only do Tavistock and Okehampton benefit from greater connectivity with the rest of the South West, but other communities on the network also stand to gain from greater connectivity to Tavistock, Okehampton and the hinterland of Devon.
Numbers relative to traffic between Plymouth and Exeter?
Well said.
Unfortunately one of the sad things about the way the country has gone in the last 30 years is a growing unthinking intolerance of anyone who dares to challenge the prevailing orthodoxy in all walks of life. People prefer to keep their heads down and just follow the group. They then attempt to deride and shout down anyone who challenges them.
It is not a matter of orthodoxy or not; it is about reasonable and realistic options to a given problem. NR has obligations to meet that a boy-scout troop have no need to take into consideration. Not only is there the initial capital funding, but funding for on-going maintenance and a requirement to meet real needs, not some hobbyist fantasy.
The objective is to provide an alternative to the route via Dawlish; that has been demonstrated to be of insufficient merit as a standalone deliverable. The alternative is to build the case as part of a wider value analysis.
Rapidash
3 Sep 2013
Torbaydos, Devon
I'm not entirely sure this is true anymore. Whilst it does have the largest population, Plymouth has been been sliding for a while now, whilst Exeter is getting more and more investment, prestige projects (like John Lewis) and more business parks opening - there's a reason why there are 3 new stations being built there, after all.
Just looking glancing at the comparable numbers - Plymouth vs EXD and EXC shows that Exeter is now seeing roughly a third more pax per year than Plymouth, and this goes up again even more when the likes of Digby and Sowton are added into it.
In my fairly generic industry, I now have colleagues commuting into Exeter from as far afield as Launceston, Bodmin, Charmouth, Sidmouth, Weston-Super-Mud, Torbay, Newton Abbot and, uh, Plymouth itself. Thats just in one small part of healthcare, I wouldn't want to guess about other sectors.
The only 'big' job sinks that Plymouth has these days are the Uni (30k students need the odd drink I guess!) the dockyard, which is forever on the cusp of downsizing or shutting down and the fact its the closest thing Cornwalls got to a big shopping centre.
PS, stop forgetting Torbay!!!!!!:roll:;)
The only ones that consider BR of notable achievement are the railway insiders that generally contributed to the fiasco.
As I mentioned before, the Selby diversion was a large engineering project which provided a realignment solution similar to some of those proposed in Devon. Unless you can explain why you believe this piece of infrastructure to be not up to standard, then I will have to assume your assertion that "BR was not up to the job" in terms of infrastructure projects doesn't come from a position of knowledge.
Olaf
29 Mar 2014
At present, Tavistock passengers will simply be loaded on an already crowded South Devon main line and subject to the same resilience issues of everything west of Exeter.
Tavistock (pop 11k) will be provided for by the appropriate level of service for a very small country town if the extension to Tavistock goes ahead. It hardly justifies the expense of a connection to Oakhampton for such a small back-water while a town such as Newton Abbot (pop approx 25k) is cut off by an event at Dawlish.
As it stands, there is no merit in any of the alternative routes as a standalone project.
21C101
19 Jul 2014
I'm coming to the conclusion that "Do Not Feed" is probably the best way forward in this case.
Olaf
29 Mar 2014
Well, they say that, but if the cost becomes too much, I could well forsee circumstances in which that branch might be closed. The fact that those stations have a main line running through them make it a lot less likely that they will be sacrificed in the future.
Any of the alternative routes, apart from that by Oakhampton, are likely to host the mainline traffic with Dawlish served by a branch service. I think there are a number of other stations that would lose their service first. As it stands I think that argument has no merits, other than the usual scaremongering.
Well, I don't have figures for Devon, but Appleby and Settle are both settlements in an area of outstanding natural beauty with a combined population smaller than Tavistock and Okehampton and not only do they benefit greatly from the railway, but areas such as West Yorkshire and Carlisle benefit from quality public transport access to them.
Then you're more trusting of the powers that be than I am.
21C101
19 Jul 2014
Funnily enough, during the last few years it was open, weekend trains, especially Sundays, were rammed with "tourists" travelling on the line for exactly the same reason that people travel on Settle - Carlisle now due to the spectacular wild Dartmoor scenery it passed through and access it gave to Dartmoor.
Olaf
29 Mar 2014
I agree; Exeter does stand-out as a notable destination these days.
The last time I looked at the numbers, the IC traffic from Plymouth had dropped off, in part due to chape air tickets, but I do not know how this might have changed in recent years.
Olaf
29 Mar 2014
There is nothing to answer as far as I see; you are stuck scraping the bottom of a less than mediocre barrel.
21C101
19 Jul 2014
Quite drastically since Plymouth Airport closed in December 2011.
Ah thanks, much as I would have expected. I could see it really being a great asset to the Devon economy were it still here today (or reopened). There's also the shopping opportunities in Exeter and potential for small business and industry mentioned by Rapidash that would be served all week round nowadays.
21C101
19 Jul 2014
Indeed, however I think it would be better off built and operated privately (perhaps by the Dartmoor Railway operators?), sponsored by the County Council with some government funding.
There are precedents, Hertfordshire County Council are the promoters and funders of that scheme (with Hertfordshire receiving a large grant from the Department for Transport towards it)
It would be much cheaper that way and, from everything I have read above it seems Network Rail clearly are not interested and would build it to such a high standard that it would never get funding. Get it done as a semi-preserved line and let it be successful and grow from there, otherwise it will clearly never happen.
I agree it could be worth looking at other ways of funding and building a project. I'm reminded of the Worthing commuters who got so tired of long winded reversals at Brighton, they formed their own company to promote the Cliftonville spur !
Operating the route would be tricky though. I can't help thinking that this would need to be embedded in the existing railway to work.
21C101
19 Jul 2014
Sometimes its the only answer, don't wait for someone else to do it, find some like minded people and get on and do it yourself, might take a lot longer but you will get there in the end. To be honest what has already been achieved at Okehampton, Meldon and Sampford Courteney including through summer services to Exeter, with daily services and a new parkway station east of Okehampton is most impressive and unthinkable 20 years ago.
We now have the North Yorks Railway a registered TOC operating services to Whitby and will shortly have the Swanage Railway joining them and operating "non preserved" services to Wareham. Neither would have happened if people had not taken the bull by the horns themselves.
Indeed. Some very impressive work going on there !
Xavi
17 Apr 2012
No delusion here my too young to know BR friend. It's called reality, like Network Rail's responsibility to maintain the existing network west of Exeter. I am advocating investigating the minimum possible to ensure a rail link is available 365 days a year to Plymouth and Cornwall whilst continuing to maintain the existing Dawlish route as long as it remains viable.
Doing nothing off the back of BCR numbers is not an option.
There's much more than dreaming up rail lines to build at stake here. It's the whole fundamental of Westminster supporting England's economy outside of London and the south east. Something that hasn't happened since before you were born.
Far from being humoured, my broad-based views have received support. The Scots want recognition, though they wisely chose to stay in the UK, and it's time there was similar recognition for the rest of England.
Ash Bridge
17 Mar 2014
Stockport
Would I be right In thinking that the owners of the Dartmoor Railway purchased the station buildings at Bere Alston some time ago? Iam sure I read this somewhere.
21C101
19 Jul 2014
Funnily enough I remember hearing about that too and was going to post something along those lines earlier, but couldn't find anything to link to on the web to confirm it.
Would be interesting to know who has bought the station houses at Brentor (whole station) and Tavistock (down side) which both went on the market in the summer.
tbtc
16 Dec 2008
Reston City Centre
6/10/14 - not the best day for passengers travelling between Cornwall and London. Apart from the well-covered (on here) severance of cables overnight by electrification contractors there was also the HST from Paddington stranded for hours outside St Austell with adhesion problems which, of course, meant everything behind it in the same boat
Funnily enough, despite the long sections of single track through Cornwall, the "traditional" enthusiasts don't seem bothered about "resillience" through Cornwall - probably because there's not a nineteenth century "solution" to any disruption!
In this case, mainly to tease those who took such great exception to me suggesting Waterloo - Barnstaple services on previous threads.
However, never underestimate the PFLWA*
* (Popular Front for the Liberation of the Withered Arm).
Why have a shuttle to Exeter with 2 car DMUs? Few would use it if they had to change at Exeter, they would just continue to drive up the A30.
Extend the Waterloo - Exeter service to Plymouth (with a North Cornwall Parkway station at the A30/A386 junction at Sourton near Okehampton (using 2 or 3 car class 158/9 DMUs) and you will get plenty of use.
This will no doubt attract the same derison from some quarters that my previous suggestions to extend the Waterloo - Exeter service to Barnstaple have acquired (in fact extension to both would be quite easy, with 2x3 car class 159 sets splitting/joining at Crediton).
I'm coming to the conclusion though that a lot of the derision is from Great Western enthusiasts who don't want to see a Southern rival re-emerge (after its rapid rundown and closure at the hands of former GWR employees within a couple of years of their getting their grubby hands on it on 1st January 1963);
and from (F)Great Western enthusiasts who don't want the competition, given how many of the Exeter/Taunton - London service users SWT have already taken since Waterloo - Exeter went hourly, giving regular clockface times 7 days a week (with no two hour gaps, cough..Taunton.. cough), with consistent journey times (rather than journey times that vary by the best part of an hour depending which train you get) and comfortable seats that line up with the windows (and lots of facing seats with tables)
Then there is much cheaper fares eg:
05:14 Exeter Central to Waterloo, arrive 08.46 Anytime Return £69 (3h 36m)
05:46 Exeter St Davids to Paddington, arrive 08.38 Anytime Return £118 (2h 52m)
Despite the 40 minute longer journey time to Waterloo, from City Centre (Exeter) to City Centre (City of London) it is faster via Waterloo and only with the Waterloo service is is possible to be in the City by 9AM. (via the drain)
Yes, my posts are about as welcome as Posts about Chilterns Evergreen 3 plans were at Euston a few years back in some quarters.
:roll:
While I think the Okehampton route is the wrong solution, if it were to be rebuilt then it needs to be rebuilt as substancial mainline route, the idea of building it as some kind of cheapo glorified preserved railway is ridiculous, paying what would still be hundreds of millions for 1 train an hour and a slow ramble around Dartmoor is crazy you may well just catch the bus on the A38, and in any scenario the investment required to reinstate Tavistock to Okehampton will be massive relative to current proposals to reinstate Bere Alston to Tavistock
If your going to build any kind of diversionary route then it needs to have capacity to deal with it without major disruption to the timetable, not lets build this line as cheaply as possible so it gets our main objective of reinstating the Okehampton service, oh and by the way there might just be capacity to send the odd diverted mailine train this way, ridiculous.
True.
The idea that we can build a 30mph/50mph (predominantly) single track line on a shoestring *and* have something capable of being a diversionary route for HSTs etc is naive.
Can't have it both ways.
Fundamently it doesn't solve any of the problems of the main line and still causes considerable disruption to the timetable, which comes back to a proper solution of diverted mainline between Exeter and Newton Abbot, which has Zero impact on Intercity services, in the event of a Coastal Route closure, either Temporary or eventually Permanent
I agree - an Okehampton route should stand/ fall on its own merits - trying to piggyback upon the Dawlish issue is desperate - if Okehampton is to go ahead then it needs to be based upon what happens 99% of the time (regardless of the line at Dawlish)
Tavistock is already being addressed as a separate project and the rest of the argument for Oakhampton/Tavistock is based on weekend hobbyists fantasies.
Reopening Bere Alston to Tavistock is going to annoy the "traditional" element because the Tavistock to Plymouth market is the cherry on the cake of full reopening. Take that away and the remaining "cake" isn't that remarkable.
I know that in this dumbed down UKIP environment, it's fashionable to rail against "big bad London" but Crossrail and Crossrail2 (son of Crossrail) are mass transportation projects that'll attract millions of people.
In comparison, Okehampton has a population of around five thousand.
There's an argument about how fairly investment is distributed around the UK, but that doesn't justify the Okehampton railway.
Assuming you're basing that on a position of knowledge (rather than ideological guff), perhaps you could provide us with a technical and engineering critique of the Selby diversion. This was a major engineering project undertaken by BR during the early 1980's which was similar to some of the options proposed for Dawlish.
Selby is a great example.
British Rail decided to solve a problem by building a new alignment that gave longer distance passengers a faster journey (than the existing service through Selby).
If this Forum had been around in the 1980s then we'd have seen people suggesting that the best way of dealing with the Selby subsidence would have been to re-open the line from York to Teesside via Pickering and Goathland instead (and said that no long distance passengers would be bothered about the time saving of the route that BR chose) :lol:
Agreed - replacement bus services are a fact of life - whilst they aren't ideal, we can't justify hundreds of millions of pounds for the sake of avoiding them once in a while.
I'm relaxed enough about "every twenty to thirty years" - if we have hundreds of millions to spend on a diversionary route that'll be properly useful once a generation then there are hundreds of more pressing projects that we could be spending the money on (which will benefit large numbers of people on a daily basis).
If every winter is like the one we've just experienced then of course I'll change my mind, but even if the "worst winter for 250 years" becomes something that we experience every 25 years, that's no reason to panic.
The froth about LSWR/ GWR just makes the Okehampton supporters look like they are more interested in fighting historic battles than providing modern solutions.
I really don't care whether the current Exeter - Plymouth line was built by the GWR or LSWR (or UKIP or HSBC or anyone else) - it matters not, in terms of "solving" the Dawlish issue.
Given that there are dozens/ hundreds of investments that we *could* be making, the BCR is the best benchmark that we have for some sober comparison/ analysis.
If you don't want to trust the analysis then fair enough, but we need to find a way compare the various different projects - otherwise we get into an emotive mess where everyone wants their own pet project to have some special case.
...because there are low hanging fruit and ones that are harder to reach. If you can get the majority of the benefits (Tavistock to Plymouth) for a fraction of the total cost of the full line then the marginal cost of those "greater benefits" are much harder to justify.
Tavistock to Plymouth is the main attraction - if you can do that fairly cheaply (seven miles of single track) then the central section is fairly high cost for fairly low benefit.
There's a lot of "spin" about how much Scotland has achieved, but (since re-openings appear to be your "thing"), there's only been a little in around fifteen years of devolution (around a dozen miles from Caldercruix to Bathgate, half that distance for Stirling to Alloa), plus stations on existing track (Newcraighall etc).
In northern England in the same period we've seen the Brighouse line reopened to passenger traffic, the "big bang" expansion to Manchester Metrolink...
...plenty more to come in the next five years too (Ordsal Chord etc)
Yes - and it serves a decent number of people day in/ day out (given the population of Yeovil etc) - which is why I think that it'd be more useful 99% of the time than the Okehampton route.
Providing the capacity to allow the full half hourly Waterloo - Salisbury service to extend to Exeter would benefit a large number on a regular basis (the diversionary benefits are a bonus, but not the main reason for redoubling).
Compare the numbers you'd get through Yeovil to the numbers you'd get through Okehampton.
Ah, so Torbay doesn't justify this much vaunted "resilience", let them use replacement bus services - whilst Cornwall cannot possibly suffer in this way?
Torbay to Exeter is a busy market - one that FGW seem much more interested in throwing any "spare" DMU resource at than trying to serve Okehampton during the week.
Yup
Yes.
The fact that some insist on Okehampton having a year round service, but are happy for South Devon to be abandoned at times of disruption is a strange thing.
Appleby only gets around eighty departing passengers a day - whilst it "benefits" from the railway, I wouldn't get too excited about those kind of numbers.
Settle is on the fringes of the Leeds commuter belt, so sees more passengers (as Tavistock would for Plymouth, no doubt) - but the numbers for stations north of Settle are pretty thin.
Busaholic
7 Jun 2014
Life's too short to wade through tbtc's thread to pick the relevant bit to highlight, but apart from the far ends of the county the Cornish main line is double track throughout, the redoubling around St Austell occurring many years ago, so your point is? St Austell isn't by the sea and so is not in jeopardy of being washed away other than by a tsunami of biblical proportions.
Why this obsession about Okehampton supporters 'denying' South Devon anything? The Dawlish route is being rebuilt and, according to you, we needn't expect anything adverse to happen to it for another 250 years, so that's alright then. In the meantime those of us who can see beyond the ends of our noses will seek better alternatives in the sure knowledge that the 250 year solution won't last 25, so, given how long plans take to come to fruition, we'll bang on for what we believe in.
People seem to be proceeding under the illusion that the railway's position is untenable.
It is not untenable if the flood defences are properly resourced - and properly resourcing them for a long time will cost a lot less than this absurd diversionary route. Any attempt to reopen the other route will make the railway at Dawlish 'expendable' - essentially abandoning Torbay - otherwise would you back it?
Take a look at the Zuiderzee and Delta Works - that is the sort of thing you could buy for the pricetags people are proposing.
The sort of thing that prevents areas several metres below mean sea level from flooding - let alone somewhere above sea level.
SpacePhoenix
18 Mar 2014
On a semi-related note, if the Dawlish route ever were to be electrified with overhead, would sea spray, or watch crashing over the sea wall cause any problems with the overhead, such as short circuits or any safety issues?
21C101
19 Jul 2014
I think it is fairly safe to say that it is unelectrifiable.
Meanwhile I can't help thinking that this story has some relevance to the NR costs element of the alternative route issue.
  • Road collapses in Landslide.
  • Council still hasn't fixed eight months later while it finds £500,000 to set aside to repair it.
  • Locals get fed up and get local builders to fix it for £2,500.
  • Council angry and warns those responsible may face penalties for trespassing
http://www.dailymail.co.uk/news/art...l-penpushers-accuse-trespassing.html#comments
Actually I believe that to be precisely wrong. I'm firmly of the belief that the Okehampton option is the only one that guarantees the survival of the route through Dawlish precisely because it could only complement, rather than replace the GW mainline. The idea that its existance would lead to the whole of Torbay neing cut off is absurd.
