It was gross misconduct (using a device listening to music). He could prove he was not using it for any contact at all (texts and calls). So many of his colleagues use their phones. His record is exemplary and he is not a young man. Driving is his dream and he knows it was his error completely. The appeal union rep is on his holidays currently.
This was during prep time and he can be seen placing his phone away before starting a run.Assuming he was using a device whilst operating the train then it may be pretty slam shut case especially if they had an earpiece on.
Hmm could be a chance but I'm guessing they'll lean on the fact the key was in the master switch and most likely in the on position.This was during prep time and he can be seen placing his phone away before starting a run.
Thank you so much. I think we will prepare for the worst.Hmm could be a chance but I'm guessing they'll lean on the fact the key was in the master switch and most likely in the on position.
Prep is a pretty important phase.
Run it through the Union first and see what the odds are.Thank you so much. I think we will prepare for the worst.
I'd imagine driving days are over, although I'm surprised he has been dismissed - unless he has prior incidents, warnings etc or he has tried to hide/downplay the incident, it seems a harsh sanction.
If he has gone in there trying to justify it by claiming his colleagues all do the same etc, then that is definitely not the correct approach and could tip the balance into dismissal. Disciplinary hearings are looking to hear that there is total acceptance of wrongdoing, not pointing fingers elsewhere etc. These disciplinaries often go seriously wrong when the union rep and employee try to make out that the company is overreacting and looking for loopholes etc
I suspect the best that he can hope for, if he wins his appeal, is a permanent reduction in grade and salary. There are quite a few former drivers now working in ticket offices or administrative roles either through sickness or incidents - but it would be exceptionally unlikely that he will be driving again.
There would have to be some very dodgy dealings going on in the background for that sort of thing to not go on their safety record!Question is if it goes on the SOL form, Drivers may know more if so on here.
Assuming it goes on a SOL then yes it will definitely affect applications onwards as a Qualified assuming he's kept the license.
