Stuttgart area loco hauled services.
Mag_seven
1 Sep 2014
here to eternity
Can anyone advise if there are any decent loco hauled trains in the Stuttgart area? I already know about the Oberstdorf to Stuttgart service.
23 Nov 2015
The IRE200 service from Wendlingen to Ulm via the new high speed line is worked by top’n’tail Vectrons leased from ELL; there are two sets in service and both locos power.
If you want to look at what else might be loco powered, try bahn.expert website as it shows allocations for most DB Fernverkehr and some DB Regio workings.
Seehof
1 Sep 2019
Shropshire
Can you use the Deutschlandticket on IRE trains? The Wendlingen to Ulm sounds a good loco hauled one to do!
Does anyone have a list of which Zurich to Stuttgart trains are still loco hauled?
Tester
5 Jul 2020
Watford
Small sample, but today (12/4) the 10:37 dep Zuerich (IC280) was SBB loco hauled, while the 15:23 arr Zuerich (IC187) was a DB unit.
ABB125
23 Jul 2016
University of Birmingham
You may well have already looked on here, but this might help:
Edit: having briefly looked through that list, it looks like a bit less than half the trains on the route are hauled. Of the trains running all the way through (ie: don't start or terminate at Singen), they're mostly run with a DB 101 on the German side and an SBB 420 on the Swiss side. Seemingly randomly, IC285 uses an OBB 1116 instead of a 101, but I couldn't see a corresponding return working. Anyone know anything about this?
A few trains are 420s throughout. I also spotted one of the double-deck DB IC hauled sets (is it IC2?), but that didn't go into Switzerland.
Interestingly, some trains reverse at Singen, but others appear not to (those with a 420 throughout). Is this correct? Why does this happen? And if it's possible to run the train without reversing and also without needing a loco change, why do most of them still change? Especially as 101s can (as far as I'm aware) be used in Switzerland.
rvdborgt
24 Feb 2022
Leuven
All through trains must reverse in Singen, see openrailwaymap.org.
Maybe some 101s can be used in Switzerland (can't recall having seen them there though, other than in Basel) but surely not all of them.
XAM2175
8 Jun 2016
Yes, electric trains from Stuttgart arriving at Singen and not reversing will only be able to continue to Konstanz. To the best of my knowledge none of the 101s are cleared to work on anything other than German electrification and signalling. A handful of Re 420s are configured for use in Germany (and actually classed as Re 421), but AFAIK they don't go any further than Singen, Lindau, etc etc.
I suspect vagonWEB is unfortunately just incomplete as far as those services are concerned.
43096
23 Nov 2015
101s are not cleared for Switzerland except in border areas (eg Basel Bad to Basel SBB). They lack the safety equipment and Swiss pantographs to be able to go any further.
Austriantrain
13 Aug 2018
Cleared in Austria, which of course has the same electrification parameters and train protection systems (and very similar - but not identical - specifications in general) as Germany.
SeanG
4 May 2013
XAM2175
8 Jun 2016
101s are definitely cleared to Austria - here is one at Graz last May about to work EC216 to Saarbrucken, which goes via Stuttgart
I don't know what I was thinking, because you've both just reminded me that I've had 101 haulage in Austria. But I'm going to claim that that's what I meant anyway when I said "anything other than German electrification and signalling" ;)
They definitely can't use Swiss electrification and signalling, though.
Is the locomotive always at the back in Stuttgart?
Stuttgart is a terminal station (for the time being, anyway) and SBB's driving trailers can't be used with German signalling or locos, so the loco that brings the set into the station will be dropped in the platform while another loco takes the set out toward Singen.
Bewgt also have their programme of tourist trains for the summer:
Are regional tickets (such as the Baden-Württemberg-Ticket and Deutschland-Ticket) valid on the Freizeitexpress services, e.g. SVG 19912/19932 Stuttgart <-> Singen via Ulm and Friedrichshafen? The latter is said to be class 218 hauled on the Dreischeibe thread you linked to - does anyone know whether this is still the case?
30907
It is operated on behalf of the Land, according to their website, so yes.
