I hear it a tiny bit on the 168s. Not much thoughIf you stand in the vestibule of any electric or loco hauled passenger carriage you'll definitely hear that noise when it gets up to speed. You can't really hear it too much of a DMU. Reminds me of the old days where you could spend the whole journey with the drop light open on a MK3. Just enjoying the 110mph goodness on the WCML etc
Corrugation. Trains travelling over track cause specific wear and tear. When wheels ride over this, particularly at speed, it makes a high pitched sound, similar to how a vinyl works if you imagine the grooves etc.
My instinct is the rail grinder / milling machine has been over this track recently.
701s take this a bit more further. Very auidable whine when the regen engages.I’ve noticed on 444s when braking there’s a high pitched whine on board when sat in one of the motor coaches. It’s noticeable but not unpleasant.
I remember seeing somewhere that electromagnetic interference with something like the PA system could cause this, but I am not sure at all. On the 777s you can hear both this sound and the traction motors at the same time or you hear the traction motors first and then this sound or vice-versa. I think it only happens on the higher speed sections.701s take this a bit more further. Very auidable whine when the regen engages.
Ah I did wonder if it was interfering with the PA.I remember seeing somewhere that electromagnetic interference with something like the PA system could cause this, but I am not sure at all. On the 777s you can hear both this sound and the traction motors at the same time or you hear the traction motors first and then this sound or vice-versa. I think it only happens on the higher speed sections.
Do you mean the "mechanical" noises, like moving parts or the "electronic" noises like motors? I think the noise in discussion here is a mechanical "whine" noise made by the wheels on the track (@Bald Rick will correct me if I'm wrong, I always thought that noise was more to do with air pressure but apparently not, it's the rails?), but perhaps you're used to hearing the traction motor sounds which are quite distinctive on the Desiro City units?Can I piggyback on this thread to ask why 700s/717s make a very distinctive sound when stopping/starting?
It is a normal train sound. Nothing wrong with your ears.It just sounds like a normal train to me. It would have been helpful if you posted a time stamp of where the different sound is heard.
Same on the 700s701s take this a bit more further. Very auidable whine when the regen engages.
