Stockport Platform Zero Closed
Peterthegreat
22 Feb 2021
South Yorkshire
A few years ago an additional platform was added at Stockport and became platform zero. This was mainly used by services heading towards Hazel Grove and beyond.
However since Covid it has remained closed. This in turn is adding several minutes to most trains heading towards Sheffield.
So does anyone know the real reason it is no longer used?
Its not closed. It has several trains booked into it, part of the issue is staffing it.
Fokx
19 Jul 2019
It hasn't been continuously closed since 2020, it was utilised last week infact
It requires a 3rd dispatcher when open
A quick scan on real time trains shows it was last used on 28th August (yesterday)
Revaulx
17 Sep 2019
Saddleworth
It was a legacy of the half-baked and never completed Stockport resignalling scheme from WCML Upgrade days.
The plan involved changing the existing paired by direction layout to paired by use, with the existing up fast and slow island becoming the up and down fast. The Hazel Grove line would conflict with this, hence Platform 0.
It all ended up on the too hard pile, which is why we still have all those lovely LNWR lever frame signal boxes on Britain’s premier main line :D
jfollows
26 Feb 2011
Wilmslow
It’s used frequently, as others have said, but it’s difficult to access and difficult to staff.
It’s not too bad when all the services to a particular destination use it, but when they’re split across other platforms it’s a right pain; for a short while the Alderley Edge terminators used it which made getting to Wilmslow from Stockport frustrating when trains ran late.
It’s also impossible to use from the up fast - all trains using it have to use the up slow from Slade Lane Junction, which is a pain if it’s a non-stop service put behind a stopper there - and the Altrincham line isn’t accessible from it.
So it only really gets used infrequently, but not never. And the Alderley Edge terminators currently use platform 1.
dcbwhaley
4 Aug 2018
It is still in occasional use. On Monday I boarded the 1643 to Buxton from platform 0. No ticket checks
I've a feeling the original intention was to lay an extra track to the south so trains could get from platform 0 to the Hazel Grove line without going back onto the Up Slow (expected future Up Fast). This would have made it much more useful.
But it didn't happen, possibly because of the difficulty of putting into the signalling once this wasn't being replaced but perhaps they decided there wasn't enough space.
It was a legacy of the half-baked and never completed Stockport resignalling scheme from WCML Upgrade days. The plan involved changing the existing paired by direction layout to paired by use, with the existing up fast and slow island becoming the up and down fast. The Hazel Grove line would conflict with this, hence Platform 0.
It got removed as the cash ran out, not because it was too difficult.
CHAPS2034
13 Mar 2018
I would suggest more than occasional. As was mentioned up thread, it is dependent on a dispatcher being available.
On Friday I was waiting on P0 for a Norwich train. Needless to say, it was delayed getting to Piccadilly and the Buxton stopper which should be behind it, arrived first. Just after that left, the dispatcher came along and told everyone the Norwich would now depart from Platform 2 just as a manual announcement was also being made.
Cue a tidal wave of passengers heading for the subway; at least in these situations they open the barriers and check that anyone who needs assistance is helped out. In these situations I have seen the departure delayed to ensure anyone who needs assistance manages to board the train.
P0 is planned to handle the EM Norwich and Northern Buxton stopper throughout the day though this doesn't always happen due to operational and staffing issues.
LRV3004
17 Mar 2015
It was indeed in use yesterday as myself and my partner were out on a GM Rail Ranger and we were at Stockport when platform 0 was closed.
Aside from the obvious of looking at Traksy, a big clue is when mass recorded announcements about platform alterations suddenly get broadcasted about services which will “now depart from platform 1”.
Some of the announcements were for services not due for another two hours! As mentioned in the thread, it’s the staffing levels that dictate whether platform 0 gets used or not.
lowe1409
6 Feb 2024
Cheshire
Seeing as Stockport station manages fine with just platforms 1-4 In its current layout, What's the point of using platform 0 at present?
There is a combination at the back end of the hour with the Alderley Edge, Norwich and Stoke where you'd need to do some reshuffling without 0.
apinnard
2 Aug 2017
Kettering
Railtrack’s mismanagement of Ansaldo (which itself provided a terrible product) didn’t help. Thankfully the Manchester South kit is being replaced back end of next year/early 2028.
LowLevel
26 Oct 2013
You end up putting a minute or two into the Norwich waiting for the Alderley Edge to clear and the Stoke runs on the fast into platform 2, usually. Not really a huge problem though the long speed restriction at Disley Tunnel also now eats into things too.
lowe1409
6 Feb 2024
Cheshire
Then if needed, just retime the alderley/Norwich by a couple minutes. Feels like it'd save on time and confusion in the long run
Starmill
18 May 2012
Bolton
going back a few years or even a decade was it classed as OOU (out of use)?
It was never closed.
It's simply that it isn't very useful. It brings only a very minimal positive effect on timings. Accordingly in March 2020 Avanti didn't have it open to passengers except where absolutely necessary for trains to run, which wasn't often back then. They ended up staying in the habit of not having it open.
Anyway, apparently Avanti are committed to staffing it now whenever it's necessary, although that doesn't mean it will be open all the time.
800001
24 Oct 2015
How easy is it to retime it?
You can't just retime a service as it will then interfere with something else further up the line eg Manchester Piccadilly
