MCR247
- Joined
- 7 Nov 2008
- Messages
- 10,292
1000 miles without re-fueling? You sure?
Indeed it's not.
But you also have to take into account fuel used whilst a diesel is idling as well, and I would say electrics are likely to be more efficient than a diesel overall.
I don't know about 165s, but I do know that HSTs can manage about 1,200 miles on one tank of fuel, and a 37 with extended fuel tanks can manage about 800 miles. So 1,000 miles for a DMU which has a much smaller engine than a loco sounds reasonable.
Yeah, I was keeping those facts in mind. A 165 has a much smaller fuel tank, but also a much smaller engine size, so should manage a better mpg figure. And remember that a 165 has 2 or 3 engines per unit, in the same way that a HST has two, but has much less weight to haul around.Don't forget the HST range is on two tanks of fuel, not one. There is also much more space on the underframe of a power car to put a big fuel tank than an underfloor-engined DMU.
At night the power station is kept running so that the power is instantly available for the morning rush hour.
"Efficiency" is notoriously difficult to define and calculate.
Actually, they're not. Only the ones that are needed to generate enough power are kept running. It is a huge waste to generate electricity that isn't needed as it can't be stored on the national grid. What they have is people watching the time, the day, what's happening on tv, what other events are happening, then predicting the amount of power that will be needed, so that power stations aren't running unnecessarily and wasting power. There are also a few around the UK that can be powered up within a couple of minutes for an instant increase in power when needed.
Actually - they are.............
I was going to mention that because I was half expecting that response - I saw that programme on BBC 4 as well ! Interesting but rather simplistic - all you need is a copy of the TV Times.......
They used to do tours of Dinorwig, don't know if they still do - worth a visit, an Amazing place.
"Steam" power stations (the overwhelming majority) have to be kept "hot". You cannot start one up from cold in a few minutes - it takes hours/days.
More power stations than are needed are kept running (not all generating - if there is no load you cannot actually produce much electricity - nowhere for it to go) overnight, perhaps on half load ("spinning or generating reserve") so that full output can be ramped up fairly quickly in response to expected demand.
A turbo generator is kept spinning on low load, as the load increases (ie: more output required) it is physically harder to turn the rotor, so more steam is fed to the turbine, which obviously requires more gas/oil/coal to be burnt - this all takes time, the whole generating loop HAS to be kept hot. If the steam cannot keep pace with the demand the generator will start to slow down. As it slows the frequency will drop, this is the critical feature, not the voltage. Voltages can vary by as much as 10%, frequency is normally kept to within 0.4%.
Because of their design, nuclear reactors are not as flexible as most other types of power station, so are kept on as high an output figure as possible - supplying a large percentage of the base load.
If we look at straightforward thermal efficiency, I believe that the best passenger vehicle in the country is rather surprising, the IC 225. Having only four motors probably helps. I can't remember the figure, but I think it's about 37%. An MTU-powered HST is about 32%, while a 9-car Meridian is about 28%. Duke of Gloucester with 10 MkIs comes in around 25%.
If anyone has better figures, please pass them on.
Daimler said:I remember reading - some time back - an extensive comparison between different forms of traction, but unfortunately I can't remember the exact figures. Suffice to say, steam was significantly less efficient than other forms of traction (and I seem to remember that even electric traction struggles to beat 40% efficiency).
The 5AT project website has some interesting figures for steam locomotive efficiency, which would appear to suggest that a standard steam locomotive such as those preserved today would struggle to achieve as much as 8% efficiency, since this is the figure quoted for the advanced (for steam as a mode of traction in general) Chinese 'QJ' class.
However, those involved in the 5AT project seem to think that a 'modern' steam locomotive (as opposed to Tornado, which in the most part is a replica of a 1940s steam locomotive) might be able to achieve as high as 16% efficiency - which might seem very poor, but is already a tremendous improvement!
I'm no expert on these things, but the 5AT project website would appear to suggest that efficiency for steam engines is rather lower:
Apologies for shamelessly quoting my own post!
EDIT: Here's the relevant page on the 5AT project website.
