Steam heat coaches - How does it work?
colchesterken
How do steam heat systems work? Not as stupid as it sounds!
I know there two pipes brake and steam heat and that it runs through the coaches on the way via radiators under the seats. Where does the steam go? I spend hours watching the Bluebell cam and there is no steam exhaust from the last coach as there is no return pipe the steam must go somewhere?
Also are the coaches nearest the loco hotter as the steam cools on its way to the back?
peteb
30 Mar 2011
Not sure about the technicalities but in the front carriage it always seems warmer than the last, and I am in the front carriage of an SVR train at present!!! (Warmer than the last carriage of the previous train I rode on).
Ken H
11 Nov 2018
N Yorks
Surely the latent heat is given up converting the steam into water. So there must be a way of dumping that water somehow.
LowLevel
26 Oct 2013
The steam pipe runs under the train from the locomotive under pressure with a constant supply of steam. There are condensate valves under the coaches at the lowest point in the pipe where the pressure of the steam blows condensate out using a spirax valve. You increase the pressure with increasing train length.
Gloster
4 Sep 2020
Up the creek
A quick look at Keith Parkin’s HMRS book gives the following, if I have understood correctly. A one-and-a-half inch diameter pipe (possibly later two inch) distributed the steam through the train: there were traps at the end of each vehicle to allow water to escape and also drain cocks. The heaters in the toilets were fed directly off the main pipe, but the rest of the vehicle had a smaller subsidiary pipe. The problem of the front vehicles being stiflingly hot and the rear ones chilly lessened as trains generally became shorter.
Western 52
19 Jun 2020
Burry Port
Some people still think the front of a modern train is warmer! Recently my parents, who are nearly 90, wanted to sit at the front of a class 158 for that reason!
John Webb
5 Jun 2010
St Albans
Most coaches will vent a small amount of steam and water most of the time, so the steam moves down the train. The venting is very noticeable on North Yorkshire Moor Railway trains - see https://www.nymr.co.uk/goathland-webcam but only a couple of more times today (31st Oct) as it's the last day of running for a while!
Vespa
20 Dec 2019
Merseyside
I remember riding Irish Rail carriages in the 90s round the island, they were using steam heating, I presume they were using cascaded rolling stock from British Rail and regauged to Irish gauge.
If I recall they weren't that warm as I had expected when compared to modern British Rail stock at that time which used electric heating, from what I gathered they used latent heat from the steam heating unit to warm up the carriages which then condensed into water as it cooled down and drained off, I didn't think it was particularly effective.
hexagon789
2 Sep 2016
No, they would have been either the Park Royals built from kits (withdrawn 1994) or the Cravens, 10 delivered built, the rest supplied as kits (withdrawn 2006). Neither were BR designs (though the Cravens are Mk1-esque in some respects) neither were built by BR but both types were steam heat and vacuum braked.
They had the heating supplied from a boiler van they always ran with. Some of these heating vans were converted from BR Mk1s sent over in 1973 but none of the passenger coaches were. Other heating vans were of Dutch (Werkspoor) origin.
The only stock cascaded from BR to IR/IÉ were some Mk2z/a/b/c stock swapped with Vic Berry for some withdrawn C Class diesels and one ex-BR HST Mk3 TRUK converted to a push-pull Café-Bar car and the aforementioned ex-BR Mk1 steam heat vans.
All other stock was either built new, sent over as kits or built from scratch in Ireland for Irish Rail.
Even without venting, the steam contracting and condensing as it cools will create a partial vacuum to draw more steam down from the locomotive.
1955LR
11 Dec 2019
Hereford
I was on the Servern Valley railway last week and one could see water vapour venting from the heaters on each coach along the train.
Vespa
20 Dec 2019
Merseyside
It did look like MK1, that's where I got my assumption from, that said it didn't feel that warm to me.
kjsway
4 Jun 2019
If a steam locomotive boiler operated at 200+ psi, would there be a pressure reduction valve onboard to lower the pressure in the carriage supply pipe?
AndrewE
9 Nov 2015
from what is said in post #4, the driver or fireman can vary the pressure depending on train length, so there is definitely a variable pressure valve. Whether it has an upper "cut-off" / ceiling or limit I wouldn't know.
paul1609
28 Jan 2006
K
Yes it varies from Loco to loco on our tank locos on the K &ESR we generally maintain the steam heating pressure at around 25 to 35 psi.
hexagon789
2 Sep 2016
Very typical I understand, neither Park Royals nor Cravens had particularly effective heating by all accounts.
No wonder the Mk2D stock offered such a step-change in comfort when launched in December 1972.
Ken H
11 Nov 2018
N Yorks
of course all this was subject to freezing so all water had to be removed from the systems in very cold weather when the coaches were parked up, or there would have been bursts.
Rescars
25 May 2021
Recollections of travelling on Anglo-Scottish sleepers in the early 1980s. Each compartment had its own heating controls - and the default settings were to have these full on. So if you didn't want to be roasted in your berth then it was sensible to turn down the electric heating when getting aboard at the London end. But it was also important to turn off the steam heating valve as well or else you got the full sauna effect after the loco was changed for a steam heater at IIRC Carlisle or Edinburgh!
D6975
26 Nov 2009
Bristol
Not quite. There were also the 'International' coaches which were almost exclusively used on the Galway line.
hexagon789
2 Sep 2016
They were privately built by BREL as a sort of showcase train, rather than specifically as BR stock though.
torten
4 Sep 2017
One trick often used to get the heat to the back of the train quicker is to keep the steam cocks at the back of the train open for a few minutes, which blasts any condensate out.
rower40
1 Jan 2008
Does this tell us something about how warm the driver keeps the cab, relative to the passenger accommodation?
