At pretty much all terminus stations in the UK there isn't a run-around loop, so how does a steam-hauled train leave the station? Is there another locomotive that couples with the front engine uncoupling or is it something else?
Modern day steam specials tend to have a diesel loco attached to the rear to assist with shunting at the end of the journey and also as a back up if anything goes wrong en route.At pretty much all terminus stations in the UK there isn't a run-around loop, so how does a steam-hauled train leave the station? Is there another locomotive that couples with the front engine uncoupling or is it something else?
That is niche. Brilliant though.Or you got niche: Birmingham Moor St had traversers http://warwickshirerailways.com/gwr/gwrms1223.htm and one of the bays at Snow Hill had a sector table http://www.warwickshirerailways.com/gwr/gwrbsh70.htm
OK that's cool.Or you got niche: Birmingham Moor St had traversers http://warwickshirerailways.com/gwr/gwrms1223.htm and one of the bays at Snow Hill had a sector table http://www.warwickshirerailways.com/gwr/gwrbsh70.htm
No reason for it to be scary the departing train would be accelerating away and the loco would (should) be driven at low speed, ready to stop on sight. No reason for it to be more dangerous than a coupling move these days.One slightly scary thing was that usually the loco trapped against the buffers would follow a short distance behind the train as it left the platform, stopping at the far end to await a route into a siding.
Obviously it happened lots of times without incident but I do wonder what would have happened if the departing train had dumped the brakes suddenly.No reason for it to be scary the departing train would be accelerating away and the loco would (should) be driven at low speed, ready to stop on sight. No reason for it to be more dangerous than a coupling move these days.
Todays health and safety regime, what if? It happened numerous times every day without incident, a credit to the staff who knew their jobs and were alert. Problem today is we live in a what if society and place responsibility on others.Obviously it happened lots of times without incident but I do wonder what would have happened if the departing train had dumped the brakes suddenly.
I assume the driver would be instructed to only follow at a speed that would permit him to stop if the train hit a figurative concrete wall.Obviously it happened lots of times without incident but I do wonder what would have happened if the departing train had dumped the brakes suddenly.
I assume so but it still seemed rather scary to me (I was only about 9 when first witnessing this at Manchester Piccadilly). I think it was banned soon after the advent of DVTs meant it would only happen occasionally, presumably because drivers would be less familiar with it.I assume the driver would be instructed to only follow at a speed that would permit him to stop if the train hit a figurative concrete wall.
Engine release roads were common at terminal stations were the not? Doesn't Man Pic still have one?
Piccadilly has a release crossover in one pair of platforms (so the engine being released has to exit via the other platform track). A few termini had non-platform tracks between the platform tracks for the purposes of engine release, but most major stations didn't as they would have pilot engines available instead, and it would be a fairly unproductive use of expensive land. I think Piccadilly had these on some platforms until the re-building in the 1960s.It does.
Also happens all over the continent, without issues, in stations. Both with MU's and locos. The gap they use is always pretty large (you'd need some impressive coordination to start at the same time as the preceeding train...), and it's hard to understand how it could be unsafe.This practice can still happen in depots. I've entered a fuelling shed and the train in front has moved off the fuelling point, so I follow it into the shed. I am responsible for ensuring I follow at a speed and distance appropriate for the movement, and can stop in plenty of time if required.
