Stations with a service in one direction only on bi-directional lines?
jaigee
6 Jan 2011
What stations are there with a service in one direction only, despite the line having bi-directional passenger services?
I know of only one, but maybe there are more.
Railsigns
15 Feb 2010
You mean somewhere like Chathill? Passenger trains pass through the station in both directions without stopping, but if you board a train that calls there, your only option is to go south.
jaigee
6 Jan 2011
Not the one I am thinking about.
To clarify, there are "Up and "Down" running lines through the station with passenger services on them but only "Down" trains stop. To travel in the "Up" direction you have to catch a "Down" train and change at the next station and come back through.
Sorry if that is as clear as mud.
I am not familiar with Chathill so I can not say if that is the case there, I assume you mean it has a bi-directional service and both go in southerly direction.
Railsigns
15 Feb 2010
Ah, right. You may be thinking of Polesworth then?
I am not familiar with Chathill so I can not say if that is the case there. I assume you mean it has a bi-directional service and both go in southerly direction.
Chathill is on the East Coast Main Line and most trains pass through without stopping. There's a stopping service from Newcastle that terminates at Chathill, then forms a service back to Newcastle. You can therefore only travel in the Up direction from Chathill.
jaigee
6 Jan 2011
Polesworth it is, ever since they took down the footbridge. Mind you, there is only one train a day anyway!
I see what you mean about Chathill, as the question was written at first that would have qualified.
Broken Viking
23 Oct 2006
some place west of France
Now for a bit of rule-bending...I'm going to try and throw Reddish South in for consideration. AFAIK there's only a single road running through the station (With only 1tpw in any direction!) but it's bi-directional. ;)
Oracle
19 May 2006
Near Ashurst New Forest Station
Totton has bi-di through the Down Platform 2 but apart from engineering works, trains do not stop there though they have been known to run through in the Up direction without stopping. Up platform P1 can be used [and has been recently] to reverse in, but is not bi-di beyond the limit of shunt.
Redbridge is also bi-di through the Down platform [2?] but only passed through by passenger trains in case of emergency..just once in living memory.
If I can stretch a point, Brockenhurst P4 is' bi-directional' in the platform as far as the east end (Southampton) end as there is a fixed red at the end. Trains can however enter it from the Southampton direction though it is only now in passenger service when there is engineering work and a need to reverse all trains at Brock.
steamybrian
26 Nov 2010
Kent
Bedwyn..
Only served by trains from the (east) London/Newbury direction.
If you wish to travel from Bedwyn westwards then travel east to Newbury before catching westbound train non-stop through Bedwyn
Track Basher
27 Nov 2010
Highlands of Scotland
Ribblehead (southbound) and Bromsgrove (northbound) used to only have one platform so trains could only call in one direction. Both have now had a second one built.
Crossover
4 Jun 2009
I could add to the rule bending by saying Denton also which is on the same line so would guess the line there was bi-directional
SteamontheMet
5 Mar 2010
In my nice Cosy Signal Box :)
I can think of one but it has been closed for years:
Ormside station on the S&C only had one platform on the Down Line *I Think?*
(I believe the station is now turned into a school trip accomodation facility with the platform boarded up so you can't see the trains but reduces the noise and vibrations of passing trains, haven't been there since 03)
imagination
3 Aug 2010
Bedwyn..
Not quite. There is the 13:30 (to Taunton), 18:24 (to Westbury), 19:24 (to Frome) and 19:35 (to Plymouth) on mondays-fridays and the 9:30 (to Exeter) and 13:29 (to Taunton) on Saturdays that head westbound from Bedwyn
Waddon
15 Sep 2009
Reeves Corner on Croydon Tramlink has trams passing in both directions but you can only board a tram heading into Croydon, not going the other way (except when it's used as a terminating place during engineering work)
Spaceflower
13 Jul 2007
Dunston on the Tyne Valley? Used to only have an early morning service in one direction, not sure if it still does
Statto
8 Feb 2011
At home or at the pub
Dont think the op's on about the Tram Network, just NR, however since you mentioned Trams, Mossley Street on the Manchester Metrolink, has a service in one direction[Southbound] only.
MCR247
7 Nov 2008
So why post Shenstone?
MidnightFlyer
16 May 2010
I will admit that the title if this thread had me confused initially, as 'bi-directional' to me means that trains can run either way down one track, see the GEML beyond Shenfield and single line sections anywhere on the network.
However, Shenstone is invalid, as, to the best of my knowledge, it has 4tph eastwards, and 4tph westards, I think it is one of only a couple of XCity stations where trains pass non-stop regularly (either there or Blake St).
MCR247
7 Nov 2008
I think the title means on lines where trains ( can) go both ways, but the station only has trains in one direction like Polesworth
