Stations that are over a river in the UK?
GodAtum
11 Dec 2009
Is Blackfriars the only station in the UK that's over a river?
I think Blackfriars is going to be unique in having nearly the entire platform length over the river.
hexagon789
2 Sep 2016
Glasgow Central - the additional 'Ayrshire' platforms (11 and 12 back then) were extended over the river because there was simply no room otherwise at the time.
That was in the 1901-05 rebuild that increased the platforms from 9 to 13 and tracks over the river from 8 to 16 by building a second bridge immediately adjacent to the original.
Dr Hoo
10 Nov 2015
Hope Valley
The River Fleet ‘sewer’ passes under St Pancras, I understand.
The Porter Brook runs under Sheffield station.
Cambus731
19 Jul 2013
Chelmsford
I seem to recall Uckfield station being over a river. And sometimes the river is over Uckfield station.
Lemmy282
8 Apr 2021
Sheffield
Sheffield station is built on the confluence of the river Sheaf and the Porter brook, does that make it the only station built over two rivers?
Nigel L
tomuk
15 May 2010
Thanks. I think Blackfriars is the only one that nearly the entire platform is over a river.
Shrewsbury the south end of 4&7 are over the river, the 5&6 bays are over the river.
Here is a phto of the complex bridge over the river that carries the south end of the station
Basil Jet
23 Apr 2022
I don't have the means to check, but I wouldn't be surprised if the north end of Blackfriars is over the Fleet.
newtownmgr
2 Jan 2011
Cardiff Central has platforms that extend out over the river Taff. Admittedly not all the way over tho!
duncanp
16 Aug 2012
The platforms at Smethwick Galton Bridge (High Level) extend over the Birmingham to Wolverhampton canal.
tbtc
16 Dec 2008
Reston City Centre
To achieve this you need a wide river to start with - or put up with very short platforms! :D
Or, in the case of Sheffield, the south-north platforms manage this by being built on top of the flow of south-north Sheaf (whereas at Blackfriars the north-south platforms straddle the west-east path of the Thames, so they’d look quite different in “plans”)
Rotherham’s station is built on the path of the (previous) canal alignment, so was a historic waterway (and sometimes funds itself under water again…)
Northampton
Is there still a canal partially underneath the section of line around Chatham that used the canal tunnels?
