Station secrets - tips and tricks
Wolfie
17 Aug 2010
When alighting GA trains at Stratford and heading to the Jubilee line I seem to always end up having to use the escalators up and down across the DLR to get there. Presumably the trick is to continue walking along the platform and go down one of the later steps down to the subway?
Based on doing that change but off the Overground be towards the front of the train in trains out of central London/rear of the train for trains into London and use the nearest stairs to you. It is indeed via the subway.
davews
24 Apr 2021
Bracknell
I was talking about arriving at Stratford on a Greater Anglia train (not Overground) and changing to Jubilee. Presumably I need to be right at the front of the GA train to get into that subway.
pokemonsuper9
20 Dec 2022
Greater Manchester
Wolfie
17 Aug 2010
I know that you were but l believe that the tracks are pretty much parallel. Hence at the front going to London and the rear going from London.
davews
24 Apr 2021
Bracknell
Thanks for the map. So if leaving from platform 11 (or 12) which I will be tomorrow there is no way to avoid those escalators as you have to use subway B.
pokemonsuper9
20 Dec 2022
Greater Manchester
In theory you could walk along platform 3/5 (the other islands would work too but that one has both staircases facing each other) but that would still add two staircases.
sprunt
22 Jul 2017
Similarly, if arriving at KX by one of the 3 tube (as opposed to sub-surface) lines on your way to catch a train at KX (or StP), always exit from the "south" end [even though 2 of them are more east-west at that point]; in fact try to be in the southernmost carriage on your journey if you have time where you get on the tube. That way you quickly get to the escalators leading up to the old ticket hall, and up to the outside world. Then you can get your bearings, and be in the mainline station while people following the diversion (which in fact it is) through the newer tunnels from the tube platforms will still be struggling underground.
Rather than memorising directions, I just generally follow the signs for the sub-surface lines which will take you to by the quickest route whether you're arriving at or departing from King's X.
There's an unsignposted shortcut to the Central line at Tottenham Court Road that involves turning right when you're directed to go straight on at the bottom of the escalators. I think it's still there after the Crossrail station rebuild.
xotGD
4 Feb 2017
If travelling from (say) Bradford or Saltaire to Carlisle or Lancaster (or reverse) then changing at Bingley or Keighley rather than Skipton ensures a same platform change.
30907
Oh yes! (Assuming it's the exit at the top of the "bridge" and turn left?) And a glorious walk across the river awaits you, as do several pubs at the bottom!
No, I meant the internal footbridge towards the East end of the platforms, but your South side exit is worth the mention anyway.
AlbertBeale
16 Jun 2019
Yes, if you turn right and go where it says "no entry", you go down a short flight of stairs and you're on the eastbound platform. For the westbound, there's an archway connecting the two platforms just a few yards along the eastbound platform. Those same escalators are the quickest route to the Northern too, even though they're signposted just as the Central - turn sharp left at the bottom of the main escalators and there's another short escalator which feeds down to the north end of the two Northern Line platforms.
There are myriad "tricks" like that for interchanging between Underground lines. Such as a shortcut from the northbound Bakerloo at Piccadilly Circus to reach the Piccadilly Line.
The exile
31 Mar 2010
Somerset
However, since there's no way the trains can overtake one another on that journey, if they arrive at Bath in the right order, then you'd make the connection at either place.
It is theoretically possible, particularly if both are running late, for the stopper to be held in the throat. awaiting a platform while the fast is let straight in. If the stopper were then to be sent over to 1 with the fast in 12, then slower walkers might have a problem. Requires several unlikely situations all to stack up….
Hybrid
10 May 2024
Another trick I thought of, not strictly a station trick, is that it is possible to order food from Starbucks, McDonald's and maybe others (anyone know any?) via an app on your phone for collection in the station. So for example, if the train will be arriving in about five minutes, put an order in on the app, the order will be prepared, and collect your food immediately on the way though the station! Great stuff!
Jimini
8 Oct 2006
Reading
I remember back in the ‘90s reading about some geezer who was on a heavily delayed GNER service heading south, and phoned an order in to an Indian restaurant in Peterborough, who then duly dispatched his ruby and met him on the platform as the train arrived.
As an aside, my father in law’s favourite trick is to order a chinese for delivery from the shop opposite the pub he drinks in, and then ducks out and catches a lift home with his food. Bit cheeky!
davews
24 Apr 2021
Bracknell
So I managed to navigate myself, just missed the 1046 from platform 12 so then down and up stairs to platform 11 for the 1100...
I ended up at Angel underground at the end of my walk. Set myself a little exercise as to what was the quickest way back to Waterloo, Waterloo & City from Bank or Jubilee from London Bridge (or even via Kennington). Went via London Bridge and found the interchange Northern to Jubilee there just as long as the long trek to W&C at Bank.
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
I've used that trick a few times during tight turnarounds at Waterloo. Train in, pick up a pre-ordered drink and perhaps a bite to eat, and back out again all within about 10 minutes. Also saves queuing if you're due a PNB too.
Jimini
8 Oct 2006
Reading
One trick I pull fairly often when Stratford is rammed and the queues off the jubilee line platforms to the underpass is being held / moving slowly is to head up the escalator to the westbound central line platform, walk through the train when it arrives (the doors open both sides there), then use the eastern subway that’s always quiet to get an eastbound central line train back to South Woodford.
Hybrid
10 May 2024
That's brilliant! Will have to try that...!
But how does he know when his food will be ready to go, and how does he negotiate the "taxi" service???!?!
Hybrid
10 May 2024
Very good, what were your favourite places to order from?
AlbertBeale
16 Jun 2019
Most Jubilee interchanges east of Baker Street are pretty long, since the line didn't get woven alongside existing platforms in the way the Victoria did in many places.
duffield
31 Jul 2013
East Midlands
The southbound Thameslink platform at St. Pancras has a (general use) accessible toilet. It's only one cubicle with all facilities, but it seems to be little known and lightly used and can be a lot more convenient and pleasant than the main toilets upstairs, which often have long queues particularly for the Ladies. I assume there's one on the northbound platform too but I haven't had occasion to try to find it.
ChrisC
7 Oct 2018
Nottinghamshire
Changing trains at Chesterfield rather than Sheffield or Derby should mean a same platform connection.
I often used to do that and indeed the journey planners regularly gave a change at Chesterfield for journeys from Nottingham to the north. Unfortunately XC have decided to cut the number of trains calling at Chesterfield resulting in this not working so easily these days.
wilbers
10 Mar 2022
Penrith
Or for Corbridge from Newcastle or other intermediate stations there is this option, possibly unique in the country to take it a stage further.
duffield
31 Jul 2013
East Midlands
And it gets worse. Currently 10 XC services each way still stop there on weekdays, there are a couple of two hour gaps in the middle of the day. When the new timetable comes into effect from 2nd June, that reduces to 7 each way, with two four hour gaps in the middle of the day.
Like you I often used to find it convenient to change there (to/from Nottingham in my case) before they started cutting the stops.
ANDREW_D_WEBB
21 Aug 2013
The Tottenham Court Road shortcut is still there.
bspahh
5 Jan 2017
I like the London Underground for Android app.
Tube Map is the award-winning navigation app that includes the official TfL (Transport for London) Tube Map. Tube Map - London Underground works both on and offline and is the #1 Tube Map with over 22 million downloads!
Its free, but with unobtrusive adverts. On the tube map if you hover over a station a popup menu appears. Pick "Info" from this and it has an ASCII art view which shows where the exits are on the platform. It means that you can be close to the right exit when your train arrives. It can save a minute or two, which can help with tight connections.
Screenshot of the Info page from the London Underground app, showing platform information for Kings Cross underground station
BRX
20 Oct 2008
If you want to change between platforms 1 and 2 at Blackfriars, position yourself at the southern end of the train and switch between the platforms at the south bank end of the station, which (compared to the north end) saves you some walking distance and quite a few stairs and doesn't require going out & in the ticket barriers.
