Station location from the 80s
WesternLancer
12 Apr 2019
Sorry, no it wasn't. "London Overground" as a brand did not exist until 2007. "Over ground" (two words) describes many stations that are not part of the "London Overground" network (including many on the London Underground!) And there was no service between Olympia and Willesden Junction until 1994
and Network Southeast as a brand didn't exist until 1986 IIRC - not the early 1980s - so to the passenger in the early 1980s it would have all looked like British Rail across the country - trains in all over dark blue or blue and grey paint scheme - not the red white and blue colour scheme of Network Southeast
Station paint scheme in the early 80s likely to be black and white in general terms (Network Southeast started repainting stations from c1986 in their brighter paint schemes with use of red including red lamp posts.
If any of that rings any bells to the OP.
parcel
19 Sep 2024
Wales
But was the name for all the local and suburban services in a very wide area around London: Overground was just the brand name for a bit. So did the train or station specifically say London Transport Overground, or was the train a Network South East one (*). Use or omission of capital letters is important here.
* - Others can explain the exact relationships if need be: I was elsewhere for much of this period.
I think it was a Network South East train.
busesrusuk
19 May 2020
Croxley Green?
urbophile
26 Nov 2015
Try Ladbroke Grove, Latimer Road or Goldhawk Road on the Hammersmith line. (And its other stations for good measure.)
On the Wimbledon line try Parson’s Green, Putney Bridge and Southfields…and the rest.
Parsons Green, Putney Bridge or East Putney possible. All of them are surrounded by terrace housing and possibly there were more small industrial units around in the 1980s. I'd rule out Southfields and Wimbledon Park as they are not on embankments.
The Hammersmith line is mostly on viaducts rather than embankments, but the OP might be misremembering the grassy bit. Worth looking.
parcel
19 Sep 2024
Wales
Croxley Green?
Looks too far outta London. This was definitely within the London area.
Agreed about the grassy section.
It was the 80s, long time ago...
Cannot remember the train, it seemed to be light an airy, not dark at all.
norbitonflyer
24 Mar 2020
SW London
Could it be somewhere on the Liverpool Street lines - Seven Sisters route for example? Much of that is elevated. Or maybe somewhere like Deptford?
parcel
19 Sep 2024
Wales
Well, this now opens a mass of possibilities. Using a tube means that you could have gone under London to just any about other terminal and then to any station served from it. Did you travel on one of the deep tube lines with small trains (only possible to stand up in the centre aisle) or normal size stock?
I do a certain amount of identifying photos of unknown locations, but I need at least one solid detail, even if it is obscure. We don’t seem to have that here.
You might be better trying to find out the identity of the drum case manufacturer and working back. Have you tried old trade or music magazines?
Factory is no longer there. All manufacturers of these products do not know of one that was in London in the 80s. However I went to one, after getting off the train at Paddington main station an picked up my case from this factory an took it all the way back home, also on the train.
There was no subway, only a high embankment off the rd.
No bridges or tunnels to go thro.
This is interesting, but it doesn't help me.https://en-gb.topographic-map.com/map-kffs8/London/
John Webb
5 Jun 2010
St Albans
Knowing both routes well, both are mainly on viaduct or through brick-lined cuttings rather than embankment. On the line through Deptford it is only after Maze Hill that grassed embankments and cuttings are present.
Likewise with the line through Seven Sisters, it's really only after that station that grassed embankments/cuttings start appearing.
parcel
19 Sep 2024
Wales
Thanks guys. Im still looking a station on a steep embankment, with a rd running along the bottom. None the suggestions seem to be showing that.
Fawkes Cat
8 May 2017
Might it have been a wholesalers or distributor that you collected from rather than the factory?
BrianW
22 Mar 2017
I support this suggestion.
'Googling' (other search engines available) on < vulcanised fibre case> took me to several images of such cases- do you recall what your case looked like- any size, colour, label, handle?
I imagine there my be some specialist/ collector/ association- though I don't know how you wold find them? How about an Auction House? BBC Antiques Roadshow/ Road Trip etc ...?
I did try adding 'London' or 'Middlesex' to the search to no avail, eg Shalford's a long way out near Guildford, and is flat, with a bridge nearby!
When was this? Kelly's Business Directory may help? I sense you need to use a range of research/ local history skills and/or people to assist you. Your local library? Wishing you well in your quest.
krus_aragon
10 Jun 2009
North Wales
Another avenue of investigation would be to find likely businesses in an old Yellow Pages. A large archive of these is available at the Berkshire Archives (https://www.royalberkshirearchives.org.uk/berkshires-past/yellow-pages-archive), but only in paper form - not digitised.
If you had a shortlist of possible business locations in London, some of our forum members might be able to think of nearby stations that might match your description.
parcel
19 Sep 2024
Wales
The case was blue, it was a large pack n roll rectangular case on large castor wheels. which contained a large kick pad an smaller pads in front of it with a lift out case for the brain.
Thanks for ur help anyway.
Is the “no bridges or tunnels” a description of the station you used or of the journey to get there?
Its means that when I got off the station, there was no bridges or tunnels on the rd. The road ran along the bottom of the station which was on a steep embankment.
Thats the part I cannot find. No suggestions so far seem to describe a station like that.
Yeh, had a look, they request a fee, to do a search, once u pay: They will continue searching until the payment u made runs out. Then to continue further searching...
"What do we charge for?​
If we need to look at records held at the RBA for you we need to charge a fee. Currently we charge £41.00 per hour with a minimum half hour charge of £20.50.
So that we can make effective use of the time you will be paying for, please provide us with as much information as you can. Please email or write to us using the guidance below:
  • Make your requirements as specific as possible
  • State exactly what information you are seeking
  • Give us any relevant details you already have.
We will then assess your enquiry and provide feedback as to how we may be able to help you together with a quote for any research we can do. If you then wish to proceed with the research, payment is required in advance. Please see our Make a Payment page for options on how to pay.
Searches will be carried out either until the time paid for has been used, or until the information requested has been found."
65477
30 Mar 2017
In your OP you say that you did find it on Google Maps once, apart from the clues you ha.ve given here can you remember anything else about how you found it that time? What search engine do you use and what terms ight you have entered? This may be of more help than a 30-40 year memory.
parcel
19 Sep 2024
Wales
I used Google maps at the time to find it.
30 Mar 2017
How about the Sussex Rubber Company, School Road, North Acton? Except the station is not NSE and in a cutting!
Its worth looking at this on Google Maps as the image has some very short trians, that is 1/4 carriage long.
parcel
19 Sep 2024
Wales
Google Maps only since 2005 so only 20 years old.
Not then, but a few years ago...
None of the suggestions so far show a steeped embankment with a rd running along the bottom.
I think Ill give up.
Thanks anyway, to all who replied..
Western Sunset
23 Dec 2014
Wimborne, Dorset
I assume you've contacted current British firms who make such cases (I found quite a few on Google); eg Wiseman Cases, Franklin Road, SE20? Weren't they able to help?
4069
8 Aug 2016
Sounds like South Greenford to me. On grassed embankment (then- overgrown now), lots of industry nearby, only problem is the road at the bottom is the A40 and runs at right angles to the railway.
parcel
19 Sep 2024
Wales
Yeh sent quite a few. Only one bothered to reply. They obviously dont work together... I'll try that one tho. They mite remember it.
30907
If I've got this right, you came into Paddington on the main line, took a tube, and then a suburban train.
South of the Thames, Nunhead and Catford (from Blackfriars) would fit your description, also Eltham and Welling (Charing X), Birkbeck or Carshalton (Victoria or London Br) and Barnes Bridge (Waterloo).
In NE London, Bruce Grove and Walthamstow St James St (Liverpool St) might fit.
DelW
15 Jan 2015
Some of the BR/NR stations south of the river were branded as "Overground Network" well before the TfL version was introduced. I remember such signage on the bridge at Barnes station, though it had gone by the time of the first Google Streetview photos in 2008 (presumably because TfL were using it by then).
I think it was probably used in the late 80s and/or 90s, but it's difficult to search for on line as results are swamped by the later version.
Edit: I'm wrong, it was used 2003 to 2006, so not relevant.
norbitonflyer
24 Mar 2020
SW London
South of the Thames, Nunhead and Catford (from Blackfriars) would fit your description.
Catford seems unlikely, as Catford Bridge is next door (but not on an embankment) and eassier to reach from Paddington (Tube to Charing Cross, whereas Blackfriars or Victoria need a change).
parcel
19 Sep 2024
Wales
From what
From what I can remember (from the 80s).
How many tube stations are on a steep embankment high up then, with a road running alongside it.
Yeh, its not the one, hasnt gotta a road running alongside it, neither is it on an steep embankment.
Fawkes Cat
8 May 2017
Just to clarify - was the factory that you collected from near a tube station - so you got the train to Paddington, then a tube*, and then walked to the factory to collect?
And if so, can you remember if you got a direct train to that tube station from Paddington?
If the answer to both questions is 'yes' that cuts down the search space that we're trying to help you with by quite a lot!
*I'm taking 'tube' to cover all London Underground services and not to exclude the sub-surface lines.
Peter Mugridge
8 Apr 2010
Epsom
What may help.... if someone could make a list of all the stations in the likely area and then strike through the ones we know it cannot be ( e.g. if they're on the level or in a cutting or something )?
We can then concentrate on the ones that are not struck through and strike through more as we go along and eliminate them.
Eventually, we will narrow it down to a manageable number that would be feasible to search older pictures of...
