Nottingham59
Can anyone answer a couple of questions on static frequency converters? I'm asking as I would like to understand the scope for using SFCs for isolated islands of electrification at places like Exeter or the Highlands. Note this thread is only for actual SFC capabilities - not for speculation about possible locations.
- Can an SFC be fed from a 33kV power line? The 33kV is the phase-to-phase voltage; from each phase to earth is just 19kV, which is less than the 25kV needed for OHLE. I don't think this would be sufficient to deliver +25kv/0/-25kV for AT lines without a transformer, but could an SFC deliver a single phase 25kV output from 33kV? I note that both Hambleton and Potters Carr feed from 132kV supplies.
- How much does an SFC cost? Say 10MVA capacity. (Potters Carr is 30MVA, I understand.) How does this compare to conventional grid feeders like at Braybrooke (2x80MVA from 400kV supply).
- What capacity would be needed for a BEMU line in a remote part of the rail network? Recharging, say, a 1MWh traction battery in 15mins would require 4MVA - so I'm thinking that 2 x 5MVA SFCs would be enough - one at each end of an isolated segment of OHLE to recharge two BEMUs at the same time, with some redundancy built in.
- In places where the local supply is not adequate for Megawatt recharging loads, is it feasible to use static grid batteries in conjunction with a SFC which can be trickle charged in advance of the BEMU arrival? Do any SFCs in the world do this already?
