Nice to have confirmation, thank you.I have a copy of the engine record for 8f 48218, it clearly states the coal capacity was 9 tons, water, 4,000 gallons if that helps at all?
Alas, no water troughs on the Southern.The Stanier tenders with 9 or 10 ton coal capacity only had 4000 gallon tanks. One of the reasons the deal to transfer surviving Duchesses to the SR in early 1964 fell through!
I have wondered why tenders measured coal in tons, but not water, the more significant load and which all other vehicle loads on the railway are measured in. 4,000 gallons of water is 18 tons.I have a copy of the engine record for 8f 48218, it clearly states the coal capacity was 9 tons, water, 4,000 gallons if that helps at all?
I've only seen reference to locomotives' water consumption in volume not by weight; and I've only seen reference to loco coal consumption by weight per mile.I have wondered why tenders measured coal in tons, but not water, the more significant load and which all other vehicle loads on the railway are measured in. 4,000 gallons of water is 18 tons.
Coal capacity for both Princess Royals and Princess Coronations given as 10 tons in my 1961 "Observers".I have wondered why tenders measured coal in tons, but not water, the more significant load and which all other vehicle loads on the railway are measured in. 4,000 gallons of water is 18 tons.
I suspect the tenders on the Duchesses had slightly less coal capacity than the rest, as they also had steam pushers fitted to push the remaining coal forward as the journey progressed.
Interestingly - aircraft load aviation fuel in kilos (or pounds) not by volume. I guess the weight matters more in terms of safety. Although not sure whether all the calcs are done by weight or whether its converted at some point.I've only seen reference to locomotives' water consumption in volume not by weight; and I've only seen reference to loco coal consumption by weight per mile.
Refilling a tender water tank, I presume, was easier to gauge by volume?
As a coal load is influenced by a) size of the lumps (if finely crushed = smaller air gaps, so in theory more will fit into the tender-hopper) and b) how high coal's piled above the tender hopper / coal rails, I presume "by weight" is more meaningful than "by volume".
Just my tuppenceworth.
The reason for that is that the volume depends on the temperature - it expands with heat. The mass will remain constant.Interestingly - aircraft load aviation fuel in kilos (or pounds) not by volume. I guess the weight matters more in terms of safety. Although not sure whether all the calcs are done by weight or whether its converted at some point.
Some Black 5 diagrams covered very long distances, sometimes with quite heavy loads.I was surprised to read that the tender attached to Black 5s had coal capacity of 9 tons. This seems remarkably large for a medium power locomotive. If this accurate, hy such a large capacity?
Yes, two types - one with an 8 ton capacity and one with an 8.5 ton capacity. So about 0.5 ton was lost to the weighing plate and mechanism.IIRC a handful of Black 5s were equipped with self-weighing tenders - as a means to monitor coal consumption more accurately. Didn't these have slightly reduced coal capacity - presumably to make room for the weighing mechanism? Anyone know more details?
For non-stop running between Waterloo and Bournemouth/Salisbury 4000 gallon tenders were not considered suitable. The King Arthurs, Lord Nelson’s and later the MN tenders all had 5000 gallon tanks, with coal capacity just 5 tons, although the latter was not an issue on the SR.Alas, no water troughs on the Southern.
I remember rumours at the time, but don't know if there were "official" proposals, or just rumour propagation by enthusiasts. Certainly, some of the Stanier Pacifics were still in good condition and finding a new home for them might have been sensible, but alas that never happened and underpowered Class 40s continued to haul heavy WCML expresses (often 13/14 coaches) for several years.I’ve never heard of this proposal - surprises me slightly as the SR wasn’t exactly short of Pacific type locomotives?
The 4,000 gallon and 9 ton tenders were an LMS standard and that railway swapped tenders around at works visits (tenders could be repaired much quicker than locomotives) it therefore made sense to have as many of them as possible, the alternative being the Fowler standard which was 3,500 gallon and 5.5 tons of coal (a little more when coal rails were fitted). There were the 50 Stanier 3,500 gallon on Jubilees, but these were not really standard in terms of swaps although a lot of parts were common. The Fowler was pushing it on coal for runs of any distance. Jubilees were supposed to have Stanier 4,000 tenders, but they were more useful on the Royal Scots, so Scot Fowler tenders were swapped with the Jubilees. Fowler tenders were also narrower than the cabs on newer LMS engines. For the Black 5s, dragging the extra 3.5 tons of coal wasn't here or there and the 500 gallons of water had its uses. Even if a particular journey wasn't that long, locomotives were diagrammed to work as much as possible during their day so could end up on several journeys and not having to visit a shed light engine to coal up was a significant saving.
Thank you for your most interesting comments. My original thoughts were that the last three tons of nine could be stuck in the back of the tender for some time and would eventually deteriorate. My guess is that most Black 5 diagrams would be less than 150 miles & thus would have their tenders replenished fairly frequently. Can't say whether this would have been important but I do remember reading that firemen would sometimes complain about the dross in the back of the tender.The 4,000 gallon and 9 ton tenders were an LMS standard and that railway swapped tenders around at works visits (tenders could be repaired much quicker than locomotives) it therefore made sense to have as many of them as possible, the alternative being the Fowler standard which was 3,500 gallon and 5.5 tons of coal (a little more when coal rails were fitted). There were the 50 Stanier 3,500 gallon on Jubilees, but these were not really standard in terms of swaps although a lot of parts were common. The Fowler was pushing it on coal for runs of any distance. Jubilees were supposed to have Stanier 4,000 tenders, but they were more useful on the Royal Scots, so Scot Fowler tenders were swapped with the Jubilees. Fowler tenders were also narrower than the cabs on newer LMS engines. For the Black 5s, dragging the extra 3.5 tons of coal wasn't here or there and the 500 gallons of water had its uses. Even if a particular journey wasn't that long, locomotives were diagrammed to work as much as possible during their day so could end up on several journeys and not having to visit a shed light engine to coal up was a significant saving.
Absolutely; and this article, on Sir Nigel Gresley Locomotive Trust's site, shows the myriad of "tender-to-engine pairings" for tenders which were allocated to each A4.So in English - some engines had several tenders whilst in service, and poorer one swapped out.
This thead, and this post in particular, has raised some issues I'd never thought of before, namely this tender issue must have been a devil for control and allocating loco diagrams in some cases. For example, a Jubilee with Fowler tender would, I presume, have been fine for a Euston - Wolverhampton working, Euston - Crewe or even Euston - Manchester?The 4,000 gallon and 9 ton tenders were an LMS standard and that railway swapped tenders around at works visits (tenders could be repaired much quicker than locomotives) it therefore made sense to have as many of them as possible, the alternative being the Fowler standard which was 3,500 gallon and 5.5 tons of coal (a little more when coal rails were fitted). There were the 50 Stanier 3,500 gallon on Jubilees, but these were not really standard in terms of swaps although a lot of parts were common. The Fowler was pushing it on coal for runs of any distance. Jubilees were supposed to have Stanier 4,000 tenders, but they were more useful on the Royal Scots, so Scot Fowler tenders were swapped with the Jubilees. Fowler tenders were also narrower than the cabs on newer LMS engines. For the Black 5s, dragging the extra 3.5 tons of coal wasn't here or there and the 500 gallons of water had its uses. Even if a particular journey wasn't that long, locomotives were diagrammed to work as much as possible during their day so could end up on several journeys and not having to visit a shed light engine to coal up was a significant saving.
From memory (and seen at Wigan), the daytime Birminham / Glasgow service was often a Stanier Pacific, so probably changed locos at Crewe. It could be a heavy train, sometimes conveying a West Country portion attached at Crewe (the portion travelled via Hereford & Shrewsbury).This thead, and this post in particular, has raised some issues I'd never thought of before, namely this tender issue must have been a devil for control and allocating loco diagrams in some cases. For example, a Jubilee with Fowler tender would, I presume, have been fine for a Euston - Wolverhampton working, Euston - Crewe or even Euston - Manchester?
But what about Birmingham - Glasgow? Was 5.5 tons enough coal for such a job? If not, then Saltley (I'm not sure, was Saltley the depot for LNW line trains back in the day) or whatever would have been fine with a 5X on a Euston train, but would need one with a larger coal capacity for a Glasgow turn.
I expect such turns would have normally be diagrammed for a Scot or Britannia, or perhaps had a loco change at Crewe if something smaller were provided, but in peak summer traffic, trying to find a suitable locomotive and be sure of its coal capacity could have caused issues, I'd imagine.
And perhaps on the Midland side of operations too? Not so far as Brum - Glasgow, but St Pancras - Leeds and Leeds - Glasgow St Enoch - both 200 miles plus, might be a struggle if Seahorse turned up with a 5.5 ton tender, perhaps?
As I recall (early 60s) the Plymouth portion attached to the Midday Scot leaving Crewe about 1600. But the Birmingham would have been a big train anyway.It could be a heavy train, sometimes conveying a West Country portion attached at Crewe (the portion travelled via Hereford & Shrewsbury).
