O L Leigh
Leaving the taps wide open when things are slippy is not the best way of getting a train up the hill. If the WSP keeps kicking in and cutting the power you tend to lose momentum. You are also spending less time applying power to the rail because the train isn't pulling when the power cuts, then starts to pull again until the limit of adhesion is exceeded and the wheels start to spin. It's better to try and put less power to the rail in the hope you don't spin up so that you get a constant pull.
one TN
one TN
